Hello.
Assuming that there are two addon domains on the same server: /public_html/domain1.com and /public_html/domain2.com
I try to load XML file from domain2.com into domain1.com without using cross-domain policy file (since it doesn’t work on xml files in my case).
So the idea is to use php file in order to load XML and read it back to flash.
I’ve found an interesting scripts that seems to do the job but unfortunately I can't get it to work. In my opinion there is somewhere problem with AS3 part. Please take a look.
Here are the AS3/PHP scripts:
AS3 (.swf in www.domain1.com😞
// location of the xml that you would like to load, full http address
var xmlLoc:String = "http://www.domain2.com/MyFile.xml";
// location of the php xml grabber file, in relation to the .swf
var phpLoc:String = "loadXML.php";
var xml:XML;
var loader:URLLoader = new URLLoader();
var request:URLRequest = new URLRequest(phpLoc+"?location="+escape(xmlLoc) );
loader.addEventListener(Event.COMPLETE, onXMLLoaded);
loader.addEventListener(IOErrorEvent.IO_ERROR, onIOErrorHandler);
loader.load(request);
function onIOErrorHandler(e:IOErrorEvent):void {
trace("There was an error with the xml file "+e);
function onXMLLoaded(e:Event):void {
trace("the rss feed has been loaded");
xml = new XML(loader.data);
// set to string, since it is passed back from php as an object
xml = XML(xml.toString());
xml_txt.text = xml;
PHP (loadXML.php in www.domain1.com😞
<?php
header("Content-type: text/xml");
$location = "";
if(isset($_GET["location"])) {
$location = $_GET["location"];
$location = urldecode($location);
$xml_string = getData($location);
// pass the url encoded vars back to Flash
echo $xml_string;
//cURLs a URL and returns it
function getData($query) {
// create curl resource
$ch = curl_init();
// cURL url
curl_setopt($ch, CURLOPT_URL, $query);
//Set some necessary params for using CURL
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
//Execute the curl function, and decode the returned JSON data
$result = curl_exec($ch);
return $result;
// close curl resource to free up system resources
curl_close($ch);
I think you might be right about permissions/settings on the server for php. Unfortunately I'm not allowed to adjust them.
So I wrote my own script - this time I used file path instead of http address of the XML file. It works fine in my case.
Here it is:
XML file on domain2.com:
<?xml version="1.0" encoding="UTF-8"?>
<gallery>
<image imagePath="galleries/gallery_1/images/1.jpg" thumbPath="galleries/gallery_1/thumbs/1.jpg" file_name= "1"> </image>
...Copy link to clipboard
Do you get either of the two traces from your swf functions? If you get the one from the onXMLLoaded function, have you traced the loader.data? If you get the one from the onIOErrorHandler function, is the swf file in the same folder as the html page that embeds it?
I get trace from onIOErrorHandler function.
The swf file is in the same folder as the html page that embeds it (I've also tested .swf file without embedding)
What is the trace you get from the onIOErrorHandler?
There was an error with the xml file [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream error. URL: http://domain1.com/loadXML.php?location=http%3A//www.domain2.com/list.xml"]
I just recreated your scenario using your code as shown and the textfield displayed the xml file contents as expected.
You might need to look into the permissions for your php file or the settings on your server (I am assuming you are testing on a server - if not, do so).
Sometimes the easiest way to reconcile a problem is to limit the number of variables in it that are possible contributors. In your case, you could have the php file echo simple text instead of trying to load the xml file and see if that displays. If the php file doesn't echo the simple text, then the problem lies in something with your php file, though I would say it is not the code in the file unless your server uses an older version of php than your code.
Here it is:
<gallery>
<image imagePath="galleries/gallery_1/images/2.jpg" thumbPath="galleries/gallery_1/thumbs/2.jpg" file_name= "2"> </image>
<image imagePath="galleries/gallery_1/images/3.jpg" thumbPath="galleries/gallery_1/thumbs/3.jpg" file_name= "3"> </image>
</gallery>
swf on domain1.com:
var imagesXML:XML;
var variables:URLVariables = new URLVariables();
var varURL:URLRequest = new URLRequest("MyPHPfile.php");
varURL.method = URLRequestMethod.POST;
varURL.data = variables;
var MyLoader:URLLoader = new URLLoader;
MyLoader.dataFormat =URLLoaderDataFormat.VARIABLES;
MyLoader.addEventListener(Event.COMPLETE, XMLDone);
MyLoader.load(varURL);
function XMLDone(event:Event):void {
var imported_XML:Object = event.target.data.imported_XML;
imagesXML = new XML(imported_XML);
MyTextfield_1.text = imagesXML;
MyTextfield_2.text = imagesXML.image[0].attribute("thumbPath"); // sample reference to attribute "thumbPath" of the first element
php file on domain1.com:
<?php
$xml_file = simplexml_load_file('../../domain2.com/galleries/gallery_1/MyXMLfile.xml'); // directory to XML file on the same server
$imported_XML = $xml_file->asXML();
print "imported_XML=" . $imported_XML;
Regards
PS: for those who read the above discussion: the first and the second script work but you must test which one is better in your situation. The first script will also work between two domains on different servers. No cross domain policy file needed.
