25 Replies Latest reply on Dec 4, 2016 12:05 AM by stevem89033964
    Script for making an object the artboard size.
    kinderdm357
      I am looking for some help on trying to make an object the exact size of the artboard.  This is something I do on a daily basis for several different reasons and it would be very helpful if this can happen automatically for whatever size the artboard may be.  As I understand it the only way is with a script but I have no experience with making illustrator scripts, im definately no programmer.  I have set up quickkeys in the past to copy from the artboard inputs when you are on the artboard tool but these round to the nearest .01 and this is not accurate enough for what I am working with.  Also if I do this with multiple pages open illustrator is very slow to respond to the artboard tool.  If anyone has any idea where to start or has seen other such scripts I would greatly appreciate it.  Thank you.
      Below is a script that I saw on here that I believe may contain what I need but now knowing programming I have no idea where to start on editing.  All I need is the part where an object is placed on the artboard that is the exact same size as the artboard.  If anyone can advise on editing I would greatly apprecaite it.
      #target illustrator
      function main() {
           if (app.documents.length == 0) {
                alert('Open a document before running this script');
                return; // Stop script here no doc open…
           } else {
                var docRef = app.activeDocument;
                with (docRef) {
                     if (selection.length == 0) {
                          alert('No items are selected…');
                          return; // Stop script here with no selection…
                     if (selection.length > 1) {
                          alert('Too many items are selected…');
                          return; // Stop script here with selection Array…
                     } else {
                          var selVB = selection[0].visibleBounds;
                          var rectTop = selVB[1] + 36;
                          var rectLeft = selVB[0] - 36;
                          var rectWidth = (selVB[2] - selVB[0]) + 72;
                          var rectHeight = (selVB[1] - selVB[3]) + 72;
                          selection[0].parent.name = 'CC';
                          selection[0].filled = false;
                          selection[0].stroked = true;
                          var ccColor = cmykColor(0, 100, 0, 0);
                          var ccCol = spots.add()
                          ccCol.name = 'CC';
                          ccCol.color = ccColor;
                          ccCol.tint = 100;
                          ccCol.colorType = ColorModel.SPOT;
                          var cc = new SpotColor();
                          cc.spot = ccCol;
                          selection[0].strokeColor = cc;
                          selection[0].strokeWidth = 1;
                          var tcLayer = layers.add();
                          tcLayer.name = 'TC';
                          var padBox = pathItems.rectangle(rectTop, rectLeft, rectWidth, rectHeight, false);
                          padBox.stroked = false;
                          padBox.filled = true;
                          var tcColor = cmykColor(0, 100, 90, 0);
                          var tcCol = spots.add()
                          tcCol.name = 'TC';
                          tcCol.color = tcColor;
                          tcCol.tint = 100;
                          tcCol.colorType = ColorModel.SPOT;
                          var tc = new SpotColor();
                          tc.spot = tcCol;
                          padBox.fillColor = tc;
                          padBox.move(docRef, ElementPlacement.PLACEATEND);
                          artboards[0].artboardRect = (padBox.visibleBounds);
                          redraw();
                          rectWidth = (rectWidth-72)/72;
                          rectWidth = roundToDP(rectWidth,1);
                          rectHeight = (rectHeight-72)/72;
                          rectHeight = roundToDP(rectHeight,1);
                          var textString = rectWidth + ' x ' + rectHeight;
                          prompt('Copy Me', textString);
      main();
      function roundToDP(nbr, dP) {
           dpNbr = Math.round(nbr*Math.pow(10,dP))/Math.pow(10,dP);
           return dpNbr;
      function cmykColor(c, m, y, k) {
           var newCMYK = new CMYKColor();
           newCMYK.cyan = c;
           newCMYK.magenta = m;
           newCMYK.yellow = y;
           newCMYK.black = k;
           return newCMYK;
        • 1. Re: Script for making an object the artboard size.
          CarlosCanto Adobe Community Professional & MVP
          is the object proportional to the artboard? if it is not, then do you need your object to be proportional? or can it be distorted to fit the artboard?
          • 2. Re: Script for making an object the artboard size.
            kinderdm357 Level 1
            Object can be distorted.  I want it to be the exact size of the artboard in both dimensions so if i say have a 4x5 artboard then I want my object to be 4x5.  I currently plan on creating a new object each time I use this as Im essentially making a border for my artwork that fits inside of the artboard.  Thank you for any help you can provide.
            • 3. Re: Script for making an object the artboard size.
              here you go, select one object before running, if your art has more than one object, make a group first.
              #target Illustrator
              //  script.name = fitObjectToArtboardBounds.jsx;
              //  script.description = resizes selected object to fit exactly to Active Artboard Bounds;
              //  script.required = select ONE object before running; CS4 & CS5 Only.
              //  script.parent = carlos canto // 01/25/12;
              //  script.elegant = false;
              var idoc = app.activeDocument;
              selec = idoc.selection;
              if (selec.length==1)
                                  // get document bounds
                                  var docw = idoc.width;
                                  var doch = idoc.height;
                                  var activeAB = idoc.artboards[idoc.artboards.getActiveArtboardIndex()]; // get active AB
                                  docLeft = activeAB.artboardRect[0];
                                  docTop = activeAB.artboardRect[1];
                                  // get selection bounds
                                  var sel = idoc.selection[0];
                                  var selVB = sel.visibleBounds;
                                  var selVw = selVB[2]-selVB[0];
                                  var selVh = selVB[1]-selVB[3];
                                  var selGB = sel.geometricBounds;
                                  var selGw = selGB[2]-selGB[0];
                                  var selGh = selGB[1]-selGB[3];
                                  // get the difference between Visible & Geometric Bounds
                                  var deltaX = selVw-selGw;
                                  var deltaY = selVh-selGh;
                                  sel.width = docw-deltaX; // width is Geometric width, so we need to make it smaller...to accomodate the visible portion.
                                  sel.height = doch-deltaY;
                                  sel.top = docTop; // Top is actually Visible top
                                  sel.left = docLeft; // dito for Left
              else
                                  alert("select ONE object before running");
              • 4. Re: Script for making an object the artboard size.
                kinderdm357 Level 1
                Ahh, very awesome.  It works perfectly.  I can't thank you enough for helping me out with this.  I know a couple of people that will be very happy to have this.  And this will help me out a lot.  Finally I can get the detail that is needed by automation.  As much as I use quickeys and Apple's automator I really do need to learn how to write scripts.  This just shows how much more powerful and elegant they can be.  And once again, thank you very much.
                • 5. Re: Script for making an object the artboard size.
                  you're welcome, glad to help
                  • 6. Re: Script for making an object the artboard size.
                    felipelisboa
                    That's really great, thank you.
                    But my objects cannot be distorted. Is it possible to do that?
                    Thank you in advance.
                    • 7. Re: Script for making an object the artboard size.
                      it is possible, but if the art is not proportional to the artboard it will only fit either the width or the height
                      • 8. Re: Script for making an object the artboard size.
                        Stan Kumak
                        HI,
                        @Carlos - Great work.
                        Maybe you can help me a little more, I have a few artboards for example A5 A4 A3 ... , on every of them I have one visible object, I want to scale all at once to the sizes of artboards.
                        Your script works great but I have almost 100 artboards and using script 100 times is killer for me  .
                        I think something like loop for every visible object could help but I'm not a programmer.
                        • 9. Re: Script for making an object the artboard size.
                          dbburgess
                          Thanks to CarlosCanto for the original script, it was very a very helpful starting point to optimize one of our workflows. We customized it a bit to maintain the aspect ratio (just takes the greater of the width / height and scales proportionally to the artboard size), and also center up the object in the middle of the artboard once scaling is complete. I hope it is helpful to someone:
                          #target Illustrator
                                  if (sel.width > sel.height) {
                                      var newWidth = docw-deltaX;
                                      var ratio = sel.width / newWidth;
                                      sel.width = newWidth; // width is Geometric width, so we need to make it smaller...to accomodate the visible portion.
                                      sel.height = sel.height * ratio;
                                  } else {
                                      var newHeight = doch-deltaY;
                                      var ratio = sel.height / newHeight;
                                      sel.height = newHeight;
                                      sel.width = sel.width / ratio;
                                  sel.top = (doch / 2) - (sel.height / 2);
                                  sel.left = (docw / 2) - (sel.width / 2);
                              else
                          • 10. Re: Script for making an object the artboard size.
                            Stan, if you have CS5 it might be kind of easy, if you have CS4 it might be kind of hard.
                            • 13. Re: Script for making an object the artboard size.
                              Hi Stan, I posted version 2 of this script over the regular forum. I does what you need.
                              http://forums.adobe.com/thread/1044937
                              • 14. Re: Script for making an object the artboard size.
                                digisli
                                Great scripts. Thanks.
                                But i am looking for fit object to artboard PROPORTIONAL to the max. size of the artboard.
                                - Create new artboard size value X by Y or Change artboard size to value X by Y (value edit in script or popup field)
                                - Select all objects
                                - Scale object to max. arboard size (proportional)
                                Option:
                                - Rotate 90dec.
                                example:
                                artboard is 400x600
                                object is 100x100
                                new object is 400x400
                                example 2:
                                artboard is 400x600
                                object is 200x100
                                new object is 400x200
                                rotated opbject is 100x200 new rotated opject is 300x600
                                • 15. Re: Script for making an object the artboard size.
                                  ok, let me work on it...
                                  • 16. Re: Script for making an object the artboard size.
                                    digisli Level 1
                                    Ok thanks i waiting for it...
                                    greetz
                                    • 17. Re: Script for making an object the artboard size.
                                      ...stay tuned, I'll work on it as soon as I have a chance...I haven't forgotten you.
                                      • 18. Re: Script for making an object the artboard size.
                                        cjamesrun Level 1
                                        I have been using the script as well. But I too was looking for something proportional. I tried digging into the code to see if I could figure out the math, but it is a little beyond my capabilities. Digisli, CarlosCanto, did you find a solution?
                                        • 19. Re: Script for making an object the artboard size.
                                          cjamesrun Level 1
                                          I have an incling that it would have to follow:
                                          // find landscape or portrait (width - margins > height - margins = landscape)  (Width - margin   < Height -margin = portrait)
                                          // if portrait scale to height - margins with aspect ratio to desired height
                                          // if landscape scale to width - margins with aspect ratio
                                          // center object
                                          • 20. Re: Script for making an object the artboard size.
                                            cjamesrun Level 1
                                            Okay, CarlosCanto, I messed with your script, please correct me if I am wrong but this seems to maintain aspect ratio, and leave the margins (defaulted to 10)
                                            http://pastebin.com/AY7cvuQw
                                            • 21. Re: Script for making an object the artboard size.
                                              no problem messing with my script, it works ok with objects taller than wider, check with objects wider than taller
                                              • 22. Re: Script for making an object the artboard size.
                                                klemango
                                                Hello,
                                                This is a very interesting topic for me.  Is there any way to modify the script to fill areas other than squares or rectangles?  I've been able to scale artwork to this shape based on percentages of width/height but only if the artwork is square or rectangular.  I've never been able to account for "round" artwork because of the control handles vs. visible art.  Is there some way to account for the decreasing area in this shape when the artwork is a circle?
                                                • 23. Re: Script for making an object the artboard size.
                                                  GA_Cent
                                                  Sorry to resurrect this however I am looking to add one step before auto resizing the art to the artboard which is to specify the artboard size. I have a bunch of art that I need to specify the artboard to be exactly 10cmx10cm prior to resizing the art to the artboard. How do i execute this from a Javascript? I found a few posts that show how to expand the artboard size slightly but not how to specify exact dimensions to resize to.
                                                  • 24. Re: Script for making an object the artboard size.
                                                    Babymac08 Level 1
                                                    Question re: this thread... Can you take the elements of this script (resizing Proportionally) and instead of doing it by the size of the artboard... Make it a set size.. (ie: if Larger than 7"w x 5"h) Scale down to fit Proportionally to which ever direction will fit?? - Thanks
                                                    • 25. Re: Script for making an object the artboard size.
                                                      stevem89033964 Level 1
                                                      This stuff doesn't work for me. Maybe it's because I'm using CS2. I wish someting worked for me.
