28 Replies Latest reply on Dec 5, 2012 3:54 PM by hen3ry
    CS4 and CS6 design views
    AWP64
      When viewing the same index file I see significant differences between the design views of Dreamweaver CS4  and Dreamweaver CS6. The index file was created in CS5. My CS4  displays it correctly while CS6 design view is not even close. The live views are correct with both.
        • 1. Re: CS4 and CS6 design views
          Jon Fritz II Adobe Community Professional & MVP
          Yeah, they'll be different. There are things that DW6 knows that weren't invented when DW4 was out and other things that DW4 will still see that have been completely removed from HTML and are either ignored, or not rendered correctly by DW6.
          Do you have a specific question about something you're seeing?
          • 2. Re: CS4 and CS6 design views
            MurraySummers Level 8
            CS6 is a good deal stricter in its interpretation of your HTML than CS4 was.  Does the page validate?  The easiest way to get a hinky display in CS6 is to throw invalid code at it.  You can use the W3C's validator to determin the validity of the code -
            http://validator.w3.org
            • 3. Re: CS4 and CS6 design views
              AWP64 Level 1
              The index page is actually a .php file from Lynda.com. A file used in one of their online tutorials involving the editing of WordPress themes/templates in DreamWeaver. The W3C validation comes back as valid for HTML5.
              • 4. Re: CS4 and CS6 design views
                AWP64 Level 1
                It almost appears that the interpretation of the css is being handled differently between the two versions. I don't know how that would be when both versions display the live view and browser output correctly.
                • 5. Re: CS4 and CS6 design views
                  ALsp Adobe Community Professional
                  Dreamweaver Design View is a browser facsimile - at best.
                  • 6. Re: CS4 and CS6 design views
                    Rik Ramsay Level 4
                    What exactly are you seeing as the differences? There have been quite a few instances where some reset styling has been causing a design to look different from previous DW versions due to CS6 being stricter, as Murray mentioned.
                    Could you post the code or link to live page?
                    • 7. Re: CS4 and CS6 design views
                      AWP64 Level 1
                      Rik, Almost spot on with that suggestion to remove the reset code from the css. That corrected all but one heading centering issue while in design view. Any idea why that code only effects the design view and not the live view or browser output. Is reset code still commonly used? I have heard both pros and cons. I have not used the forums very much and when you mentioned posting the code or live page are you referring to a spot that Adobe has setup? Right now the file is only on my testing server, not live.
                      • 8. Re: CS4 and CS6 design views
                        Without seeing your code (both HTML and CSS) it would be hard to answer this.  The best way to show us would be to post a link to the live pages.
                        • 9. Re: CS4 and CS6 design views
                          Rik Ramsay Level 4
                          You are able to post the code in your reply  go to code view, select all, copy and then paste in here. Alternatively, you could use the "advanced editor" view and paste inside "syntax highlighting" but that gets tricky.
                          Your header might have moved because it was relying on something from the reset style. It should be easily fixed when the code is seen. As for the resets themselves, people have different views on this but I find they cause more issues than they are worth. They can be good as guidance on what you can include in your stylesheet though. I tend to write my CSS more or less from scratch and add my own reset into it - that way I know exactly what I am resetting!
                          • 10. Re: CS4 and CS6 design views
                            I would allow Murray to take you through this as he is using the more
                            logical path. The first thing you want to check is if your page is coded
                            correctly and to do that you need to allow Murray to see a live page. At
                            that point, if your code is valid, and works properly in browsers, but
                            still has problems, you must make a decision:
                            1. Use Design Time Style Sheets inside Dreamweaver to work around
                            Dreamweaver display bugs (of which there are many).
                            2. Dumb down your CSS to the point that Dreamweaver is capable of
                            displaying it like a modern browser.
                            Al Sparber - PVII
                            http://www.projectseven.com
                            The Finest Dreamweaver Menus | Galleries | Widgets
                            Since 1998
                            • 11. Re: CS4 and CS6 design views
                              AWP64 Level 1
                              Here is the original .php doc. (Does not contain any php because that was the exercise to insert it).
                              <!DOCTYPE html>
                              <html dir="ltr" lang="en-US">
                              <head>
                              <meta charset="UTF-8">
                              <title>Explore California</title>
                              <link rel="profile" href="http://gmpg.org/xfn/11">
                              <link rel="stylesheet" type="text/css" media="all" href="style.css">
                              </head>
                              <body class="home blog">
                              <div id="wrapper" class="hfeed">
                                <div id="header">
                                  <div id="masthead"> <a href="http://localhost/explore_ca/index.htm"><img src="images/logo.gif" width="192" height="237" alt="Explore California Home"></a></div>
                                  <!-- #masthead -->
                                </div>
                                <!-- #header -->
                                <div id="main">
                                  <div id="container">
                                    <div id="content" role="main">
                                      <div id="templateID" >
                                        <h1>Heading</h1>
                                      </div>
                                    </div>
                                    <!-- #content -->
                                  </div>
                                  <!-- #container -->
                                  <div id="primary" class="widget-area" role="complementary">
                                    <ul id="baseNav">
                                      <li><a href="http://www.explorecalifornia.org/tours.htm" title="Explore our tours" class="tours">Tours</a></li>
                                      <li><a href="http://www.exlorecalifornia.org/mission.htm" title="What we think" class="mission">Mission</a></li>
                                      <li><a href="http://www.explorecalifornia.org/contact.htm" title="Contact and support" class="contact">Contact</a></li>
                                      <li><a href="http://www.explorecalifornia.org/resources.htm" title="Guidance and planning" class="resources">Resources</a></li>
                                      <li><a href="http://www.explorecalifornia.org/explorers.htm" title="Join our community" class="explorers current">Explorers</a></li>
                                    </ul>
                                    <!--<ul class="xoxo">
                              <li id="search-2" class="widget-container widget_search"><form role="search" method="get" id="searchform" action="http://localhost/explore_ca/">
                                        <div><label class="screen-reader-text" for="s">Search for:</label>
                                        <input type="text" value="" name="s" id="s">
                                        <input type="submit" id="searchsubmit" value="Search">
                                        </div>
                                        </form></li>                    <li id="recent-posts-2" class="widget-container widget_recent_entries">                    <h3 class="widget-title">Recent Posts</h3>                    <ul>
        <li><a href="http://localhost/explore_ca/?p=4" title="Mountain Biking Rules">Mountain Biking Rules</a></li>
        <li><a href="http://localhost/explore_ca/?p=1" title="Hello world!">Hello world!</a></li>
        </ul>
                                                  </li><li id="archives-2" class="widget-container widget_archive"><h3 class="widget-title">Archives</h3>                    <select name="archive-dropdown" onchange="document.location.href=this.options[this.selectedIndex].value;"> <option value="">Select Month</option>           <option value="http://localhost/explore_ca/?m=201008"> August 2010 </option>
                              </select>
                              </li><li id="categories-2" class="widget-container widget_categories"><h3 class="widget-title">Categories</h3>                    <ul>
                                        <li class="cat-item cat-item-1"><a href="http://localhost/explore_ca/?cat=1" title="View all posts filed under Uncategorized">Uncategorized</a>
                              </li>
                                                  </ul>
                              </li>                              </ul>-->
                                  </div>
                                  <!-- #primary .widget-area -->
                                </div>
                                <!-- #main -->
                                <div id="footer" role="contentinfo">
                              <div id="footerContent">
                                  <div id="footerMenu">
                                <h3>Quick Nav</h3>
                                  <ul id="quickNav">
                                    <li><a href="../tours.htm" title="Explore our tours">Tours</a></li>
                                    <li><a href="../mission.htm" title="What we think">Mission</a></li>
                                    <li><a href="../contact.htm" title="Contact and support">Contact</a></li>
                                    <li><a href="../resources.htm" title="Guidance and planning">Resources</a></li>
                                    <li><a href="../explorers.htm" title="Join our community">Explorers</a></li>
                                  </ul>
                              </div>
                                <div id="footerBody">
                                <div id="footerMidCol">
                                    <h3><a href="../resources/faq.htm">FAQ</a></h3>
                                    <p>Find out more about our tours</p>
                                    <h3><a href="../contact/support.htm">Support</a></h3>
                                    <p>Need help? It's just a click away!</p>
                                    <h3><a href="../resources/legal.htm">Legal Disclaimer</a></h3>
                                  </div>
                                  <div id="footerRightCol">
                                    <h1>Explore California</h1>
                                    <p>5605 Nota Street<br />
                                      Ventura, CA 93003</p>
                                    <p class="phone">866.555.4310</p>
                                  </div>
                                  </div>
                              </div>
                                        <p class="support clearBoth">Explore California &copy; 2010 All Rights Reserved
                                        </p>
                              </div>
                                <!-- #footer -->
                              </div>
                              <!-- #wrapper -->
                              </body>
                              </html>
                              And here is the related css with reset code
                              Theme Name: Explore California
                              Theme URI: http://explorecalifornia.org/
                              Description: A new theme.
                              Author: Joe Lowery for Lynda.com
                              Version: 1.0
                              Tags: Western
                              /* =Reset default browser CSS. Based on work by Eric Meyer: http://meyerweb.com/eric/tools/css/reset/index.html
                              html, body, div, span, applet, object, iframe,
                              h1, h2, h3, h4, h5, h6, p, blockquote, pre,
                              a, abbr, acronym, address, big, cite, code,
                              del, dfn, em, font, img, ins, kbd, q, s, samp,
                              small, strike, strong, sub, sup, tt, var,
                              b, u, i, center,
                              dl, dt, dd, ol, ul, li,
                              fieldset, form, label, legend,
                              table, caption, tbody, tfoot, thead, tr, th, td {
                                        background: transparent;
                                        border: 0;
                                        margin: 0;
                                        padding: 0;
                                        vertical-align: baseline;
                              body {
                                        line-height: 1;
                              h1, h2, h3, h4, h5, h6 {
                                        clear: both;
                                        font-weight: normal;
                              ol, ul {
                                        list-style: none;
                              blockquote {
                                        quotes: none;
                              blockquote:before, blockquote:after {
                                        content: '';
                                        content: none;
                              del {
                                        text-decoration: line-through;
                              /* tables still need 'cellspacing="0"' in the markup */
                              table {
                                        border-collapse: collapse;
                                        border-spacing: 0;
                              a img {
                                        border: none;
                              /* =Layout
                              LAYOUT: Two columns
                              DESCRIPTION: Two-column fixed layout with one sidebar right of content
                              #container {
                                        float: right;
                                        margin: 0 -260px 0 0;
                                        width: 100%;
                              #content {
                                        margin: 0 280px 0 20px;
                              #primary,
                              #secondary {
                                        float: left;
                                        overflow: hidden;
                                        width: 250px;
                              #secondary {
                                        clear: right;
                              #footer {
                                        clear: both;
                                        width: 100%;
                              LAYOUT: One column, no sidebar
                              DESCRIPTION: One centered column with no sidebar
                              .one-column #content {
                                        margin: 0 auto;
                                        width: 640px;
                              LAYOUT: Full width, no sidebar
                              DESCRIPTION: Full width content with no sidebar; used for attachment pages
                              .single-attachment #content {
                                        margin: 0 auto;
                                        width: 900px;
                              /* =Fonts
                              body,
                              input,
                              textarea,
                              .page-title span,
                              .pingback a.url {
                                        font-family: Georgia, "Bitstream Charter", serif;
                              h3#comments-title,
                              h3#reply-title,
                              #access .menu,
                              #access div.menu ul,
                              #cancel-comment-reply-link,
                              .form-allowed-tags,
                              #site-info,
                              #site-title,
                              #wp-calendar,
                              .comment-meta,
                              .comment-body tr th,
                              .comment-body thead th,
                              .entry-content label,
                              .entry-content tr th,
                              .entry-content thead th,
                              .entry-meta,
                              .entry-title,
                              .entry-utility,
                              #respond label,
                              .navigation,
                              .page-title,
                              .pingback p,
                              .reply,
                              .widget-title,
                              .wp-caption-text,
                              input[type=submit] {
                                        font-family: "Helvetica Neue", Arial, Helvetica, "Nimbus Sans L", sans-serif;
                              pre {
                                        font-family: "Courier 10 Pitch", Courier, monospace;
                              code {
                                        font-family: Monaco, Consolas, "Andale Mono", "DejaVu Sans Mono", monospace;
                              /* =Structure
                              /* The main theme structure */
                              #access .menu-header,
                              div.menu,
                              #colophon,
                              #branding,
                              #main,
                              #wrapper {
                                        margin: 0 auto;
                                        width: 930px;
                              #wrapper {
                                        background: #fff;
                                        margin-top: 25px;
                                        padding: 0;
                              /* Structure the footer area */
                              #footer-widget-area {
                                        overflow: hidden;
                              #footer-widget-area .widget-area {
                                        float: left;
                                        margin-right: 20px;
                                        width: 220px;
                              #footer-widget-area #fourth {
                                        margin-right: 0;
                              #site-info {
                                        float: left;
                                        font-size: 14px;
                                        font-weight: bold;
                                        width: 700px;
                              #site-generator {
                                        float: right;
                                        width: 220px;
                              /* =Global Elements
                              /* Main global 'theme' and typographic styles */
                              body {
                                        background: #e1d8b9 url(images/page_background.jpg) repeat-x left top;
                              body,
                              input,
                              textarea {
                                        color: #666;
                                        font-size: 12px;
                                        line-height: 18px;
                              hr {
                                        background-color: #e7e7e7;
                                        border: 0;
                                        clear: both;
                                        height: 1px;
                                        margin-bottom: 18px;
                              /* Text elements */
                              p {
                              ul {
                                        list-style: square;
                                        margin: 0 0 18px 1.5em;
                              ol {
                                        list-style: decimal;
                              ol ol {
                                        list-style: upper-alpha;
                              ol ol ol {
                                        list-style: lower-roman;
                              ol ol ol ol {
                                        list-style: lower-alpha;
                              ul ul,
                              ol ol,
                              ul ol,
                              ol ul {
                                        margin-bottom: 0;
                              dl {
                                        margin: 0 0 24px 0;
                              dt {
                                        font-weight: bold;
                              dd {
                              strong {
                                        font-weight: bold;
                              cite,
                              em,
                              i {
                                        font-style: italic;
                              big {
                                        font-size: 131.25%;
                              ins {
                                        background: #ffc;
                                        text-decoration: none;
                              blockquote {
                                        font-style: italic;
                                        padding: 0 3em;
                              blockquote cite,
                              blockquote em,
                              blockquote i {
                                        font-style: normal;
                              pre {
                                        background: #f7f7f7;
                                        color: #222;
                                        line-height: 18px;
                                        padding: 1.5em;
                              abbr,
                              acronym {
                                        border-bottom: 1px dotted #666;
                                        cursor: help;
                              sup,
                              sub {
                                        height: 0;
                                        line-height: 1;
                                        position: relative;
                              sup {
                                        bottom: 1ex;
                              sub {
                                        top: .5ex;
                              input[type="text"],
                              textarea {
                                        background: #f9f9f9;
                                        border: 1px solid #ccc;
                                        box-shadow: inset 1px 1px 1px rgba(0,0,0,0.1);
                                        -moz-box-shadow: inset 1px 1px 1px rgba(0,0,0,0.1);
                                        -webkit-box-shadow: inset 1px 1px 1px rgba(0,0,0,0.1);
                                        padding: 2px;
                              a:link {
                                        color: #0066cc;
                              a:visited {
                                        color: #743399;
                              a:active,
                              a:hover {
                                        color: #ff4b33;
                              /* Text meant only for screen readers */
                              .screen-reader-text {
                                        position: absolute;
                                        left: -9000px;
                              /* =Header
                              #header {
                                        padding: 30px 0 0;
                                        background: url(images/blog_banner.jpg) no-repeat;
                                        height: 187px;
                                        position: relative;
                              #masthead {
                                        position: absolute;
                                        left: 42px;
                                        top: -20px;
                              #site-title {
                                        float: left;
                                        font-size: 30px;
                                        line-height: 36px;
                                        margin: 0 0 18px 0;
                                        width: 700px;
                              #site-title a {
                                        color: #000;
                                        font-weight: bold;
                              #site-description {
                                        clear: right;
                                        float: right;
                                        font-style: italic;
                                        margin: 14px 0 18px 0;
                                        width: 220px;
                              /* This is the custom header image */
                              #branding img {
                                        border-top: 4px solid #000;
                                        border-bottom: 1px solid #000;
                                        clear: both;
                                        display: block;
                              /* =Menu
                              #access {
                                        background: #000;
                                        display: block;
                                        float: left;
                                        margin: 0 auto;
                                        width: 940px;
                              div.menu {
                                        font-size: 13px;
                                        margin-left: 12px;
                                        width: 928px;
                              #access .menu-header ul,
                              div.menu ul {
                                        list-style: none;
                                        margin: 0;
                              #access .menu-header li,
                              div.menu li {
                                        float: left;
                                        position: relative;
                              #access a {
                                        color: #aaa;
                                        display: block;
                                        line-height: 38px;
                                        padding: 0 10px;
                              #access ul ul {
                                        box-shadow: 0px 3px 3px rgba(0,0,0,0.2);
                                        -moz-box-shadow: 0px 3px 3px rgba(0,0,0,0.2);
                                        -webkit-box-shadow: 0px 3px 3px rgba(0,0,0,0.2);
                                        display: none;
                                        position: absolute;
                                        top: 38px;
                                        left: 0;
                                        float: left;
                                        width: 180px;
                                        z-index: 99999;
                              #access ul ul li {
                                        min-width: 180px;
                              #access ul ul ul {
                                        left: 100%;
                                        top: 0;
                              #access ul ul a {
                                        background: #333;
                                        line-height: 1em;
                                        padding: 10px;
                                        width: 160px;
                                        height: auto;
                              #access li:hover > a,
                              #access ul ul :hover > a {
                                        background: #333;
                                        color: #fff;
                              #access ul li:hover > ul {
                                        display: block;
                              #access ul li.current_page_item > a,
                              #access ul li.current-menu-ancestor > a,
                              #access ul li.current-menu-item > a,
                              #access ul li.current-menu-parent > a {
                                        color: #fff;
                              * html #access ul li.current_page_item a,
                              * html #access ul li.current-menu-ancestor a,
                              * html #access ul li.current-menu-item a,
                              * html #access ul li.current-menu-parent a,
                              * html #access ul li a:hover {
                                        color: #fff;
                              /* =Content
                              #main {
                                        clear: both;
                                        overflow: hidden;
                                        padding: 40px 0 0 0;
                              #content {
                                        margin-bottom: 36px;
                              #content,
                              #content input,
                              #content textarea {
                                        color: #333;
                                        font-size: 16px;
                                        line-height: 24px;
                              #content p,
                              #content ul,
                              #content ol,
                              #content dd,
                              #content pre,
                              #content hr {
                                        margin-bottom: 24px;
                              #content ul ul,
                              #content ol ol,
                              #content ul ol,
                              #content ol ul {
                                        margin-bottom: 0;
                              #content pre,
                              #content kbd,
                              #content tt,
                              #content var {
                                        font-size: 15px;
                                        line-height: 21px;
                              #content code {
                                        font-size: 13px;
                              #content dt,
                              #content th {
                                        color: #000;
                              #content h1,
                              #content h2,
                              #content h3,
                              #content h4,
                              #content h5,
                              #content h6 {
                                        color: #000;
                                        line-height: 1.5em;
                                        margin: 0 0 20px 0;
                              #content table {
                                        border: 1px solid #e7e7e7;
                                        margin: 0 -1px 24px 0;
                                        text-align: left;
                                        width: 100%;
                              #content tr th,
                              #content thead th {
                                        color: #888;
                                        font-size: 12px;
                                        font-weight: bold;
                                        line-height: 18px;
                                        padding: 9px 24px;
                              #content tr td {
                                        border-top: 1px solid #e7e7e7;
                                        padding: 6px 24px;
                              #content tr.odd td {
                                        background: #f2f7fc;
                              .hentry {
                                        margin: 0 0 48px 0;
                              .home .sticky {
                                        margin-left: -20px;
                                        margin-right: -20px;
                                        padding: 18px 20px;
                              .single .hentry {
                                        margin: 0 0 36px 0;
                              .page-title {
                                        color: #000;
                                        font-size: 14px;
                                        font-weight: bold;
                                        margin: 0 0 36px 0;
                              .page-title span {
                                        color: #333;
                                        font-size: 16px;
                                        font-style: italic;
                              .page-title a:link,
                              .page-title a:visited {
                                        color: #888;
                              .page-title a:active,
                              .page-title a:hover {
                                        color: #ff4b33;
                              #content .entry-title {
                                        color: #000;
                                        font-size: 21px;
                                        font-weight: bold;
                                        line-height: 1.3em;
                                        margin-bottom: 0;
                              .entry-title a:link,
                              .entry-title a:visited {
                                        color: #000;
                              .entry-title a:active,
                              .entry-title a:hover {
                                        color: #ff4b33;
                              .entry-meta {
                                        color: #888;
                                        font-size: 12px;
                              .entry-meta abbr,
                              .entry-utility abbr {
                                        border: none;
                              .entry-meta abbr:hover,
                              .entry-utility abbr:hover {
                              .entry-content,
                              .entry-summary {
                                        clear: both;
                                        padding: 12px 0 0 0;
                              #content .entry-summary p:last-child {
                                        margin-bottom: 12px;
                              .entry-content fieldset {
                                        margin: 0 0 24px 0;
                                        padding: 24px;
                              .entry-content fieldset legend {
                                        background: #fff;
                                        color: #000;
                                        font-weight: bold;
                                        padding: 0 24px;
                              .entry-content input {
                                        margin: 0 0 24px 0;
                              .entry-content input.file,
                              .entry-content input.button {
                                        margin-right: 24px;
                              .entry-content label {
                                        color: #888;
                                        font-size: 12px;
                              .entry-content select {
                                        margin: 0 0 24px 0;
                              .entry-content sup,
                              .entry-content sub {
                                        font-size: 10px;
                              .entry-content blockquote.left {
                                        float: left;
                                        margin-left: 0;
                                        margin-right: 24px;
                                        text-align: right;
                                        width: 33%;
                              .entry-content blockquote.right {
                                        float: right;
                                        margin-left: 24px;
                                        margin-right: 0;
                                        text-align: left;
                                        width: 33%;
                              .page-link {
                                        color: #000;
                                        font-weight: bold;
                                        margin: 0 0 22px 0;
                                        word-spacing: 0.5em;
                              .page-link a:link,
                              .page-link a:visited {
                                        background: #f1f1f1;
                                        color: #333;
                                        padding: 0.5em 0.75em;
                              .home .sticky .page-link a {
                                        background: #d9e8f7;
                              .page-link a:active,
                              .page-link a:hover {
                                        color: #ff4b33;
                              body.page .edit-link {
                                        clear: both;
                                        display: block;
                              #entry-author-info {
                                        clear: both;
                                        font-size: 14px;
                                        line-height: 20px;
                                        margin: 24px 0;
                                        overflow: hidden;
                                        padding: 18px 20px;
                              #entry-author-info #author-avatar {
                                        background: #fff;
                                        float: left;
                                        height: 60px;
                                        margin: 0 -104px 0 0;
                                        padding: 11px;
                              #entry-author-info #author-description {
                                        float: left;
                                        margin: 0 0 0 104px;
                              #entry-author-info h2 {
                                        color: #000;
                                        font-size: 100%;
                                        font-weight: bold;
                                        margin-bottom: 0;
                              .entry-utility {
                                        clear: both;
                                        color: #888;
                                        font-size: 12px;
                                        line-height: 18px;
                              .entry-meta a,
                              .entry-utility a {
                                        color: #888;
                              .entry-meta a:hover,
                              .entry-utility a:hover {
                                        color: #ff4b33;
                              #content .video-player {
                                        padding: 0;
                              /* =Asides
                              .home #content .category-asides p {
                                        font-size: 14px;
                                        line-height: 20px;
                                        margin-bottom: 10px;
                                        margin-top: 0;
                              .home .hentry.category-asides {
                                        padding: 0;
                              .home #content .category-asides .entry-content {
                                        padding-top: 0;
                              /* =Gallery listing
                              .category-gallery .size-thumbnail img {
                                        border: 10px solid #f1f1f1;
                                        margin-bottom: 0;
                              .category-gallery .gallery-thumb {
                                        float: left;
                                        margin-right: 20px;
                                        margin-top: -4px;
                              .home #content .category-gallery .entry-utility {
                                        padding-top: 4px;
                              /* =Attachment pages
                              .attachment .entry-content .entry-caption {
                                        font-size: 140%;
                                        margin-top: 24px;
                              .attachment .entry-content .nav-previous a:before {
                                        content: '\2190\00a0';
                              .attachment .entry-content .nav-next a:after {
                                        content: '\00a0\2192';
                              /* =Images
                              #content img {
                                        margin: 0;
                                        height: auto;
                                        max-width: 640px;
                                        width: auto;
                              #content .attachment img {
                                        max-width: 900px;
                              #content .alignleft,
                              #content img.alignleft {
                                        display: inline;
                                        float: left;
                                        margin-right: 24px;
                                        margin-top: 4px;
                              #content .alignright,
                              #content img.alignright {
                                        display: inline;
                                        float: right;
                                        margin-left: 24px;
                                        margin-top: 4px;
                              #content .aligncenter,
                              #content img.aligncenter {
                                        clear: both;
                                        display: block;
                                        margin-left: auto;
                                        margin-right: auto;
                              #content img.alignleft,
                              #content img.alignright,
                              #content .wp-caption {
                                        line-height: 18px;
                                        margin-bottom: 20px;
                                        padding: 4px;
                                        text-align: center;
                              #content .wp-caption img {
                                        margin: 5px 5px 0;
                              #content .wp-caption p.wp-caption-text {
                                        color: #888;
                                        font-size: 12px;
                                        margin: 5px;
                              #content .wp-smiley {
                                        margin: 0;
                              #content .gallery {
                                        margin: 0 auto 18px;
                              #content .gallery .gallery-item {
                                        float: left;
                                        margin-top: 0;
                                        text-align: center;
                                        width: 33%;
                              #content .gallery img {
                                        border: 2px solid #cfcfcf;
                              #content .gallery .gallery-caption {
                                        color: #888;
                                        font-size: 12px;
                                        margin: 0 0 12px;
                              #content .gallery dl {
                                        margin: 0;
                              #content .gallery br+br {
                                        display: none;
                              #content .attachment img { /* single attachment images should be centered */
                                        display: block;
                                        margin: 0 auto;
                              /* =Navigation
                              .navigation {
                                        color: #888;
                                        font-size: 12px;
                                        line-height: 18px;
                                        overflow: hidden;
                              .navigation a:link,
                              .navigation a:visited {
                                        color: #888;
                              .navigation a:active,
                              .navigation a:hover {
                                        color: #ff4b33;
                              .nav-previous {
                                        float: left;
                                        width: 50%;
                              .nav-next {
                                        float: right;
                                        text-align: right;
                                        width: 50%;
                              #nav-above {
                                        margin: 0 0 18px 0;
                              #nav-above {
                                        display: none;
                              .paged #nav-above,
                              .single #nav-above {
                                        display: block;
                              #nav-below {
                                        margin: -18px 0 0 0;
                              /* =Comments
                              #comments {
                                        clear: both;
                              #comments .navigation {
                                        padding: 0 0 18px 0;
                              h3#comments-title,
                              h3#reply-title {
                                        color: #000;
                                        font-size: 20px;
                                        font-weight: bold;
                                        margin-bottom: 0;
                              h3#comments-title {
                                        padding: 24px 0;
                              .commentlist {
                                        list-style: none;
                                        margin: 0;
                              .commentlist li.comment {
                                        border-bottom: 1px solid #e7e7e7;
                                        line-height: 24px;
                                        margin: 0 0 24px 0;
                                        padding: 0 0 0 56px;
                                        position: relative;
                              .commentlist li:last-child {
                                        border-bottom: none;
                                        margin-bottom: 0;
                              #comments .comment-body ul,
                              #comments .comment-body ol {
                              #comments .comment-body p:last-child {
                                        margin-bottom: 6px;
                              #comments .comment-body blockquote p:last-child {
                              .commentlist ol {
                              .commentlist .avatar {
                                        position: absolute;
                                        top: 4px;
                                        left: 0;
                              .comment-author {
                              .comment-author cite {
                                        color: #000;
                                        font-style: normal;
                                        font-weight: bold;
                              .comment-author .says {
                                        font-style: italic;
                              .comment-meta {
                                        font-size: 12px;
                                        margin: 0 0 18px 0;
                              .comment-meta a:link,
                              .comment-meta a:visited {
                                        color: #888;
                              .comment-meta a:active,
                              .comment-meta a:hover {
                                        color: #ff4b33;
                              .commentlist .even {
                              .commentlist .bypostauthor {
                              .reply {
                                        font-size: 12px;
                                        padding: 0 0 24px 0;
                              .reply a,
                              a.comment-edit-link {
                                        color: #888;
                              .reply a:hover,
                              a.comment-edit-link:hover {
                                        color: #ff4b33;
                              .commentlist .children {
                                        list-style: none;
                                        margin: 0;
                              .commentlist .children li {
                                        border: none;
                                        margin: 0;
                              .nopassword,
                              .nocomments {
                                        display: none;
                              #comments .pingback {
                                        padding-bottom: 18px;
                              .commentlist li.comment+li.pingback {
                                        margin-top: -6px;
                              #comments .pingback p {
                                        color: #888;
                                        display: block;
                                        font-size: 12px;
                                        line-height: 18px;
                                        margin: 0;
                              #comments .pingback .url {
                                        font-size: 13px;
                                        font-style: italic;
                              /* Comments form */
                                        color: #333;
                              #respond {
                                        margin: 24px 0;
                                        overflow: hidden;
                                        position: relative;
                              #respond p {
                                        margin: 0;
                              #respond .comment-notes {
                                        margin-bottom: 1em;
                              .form-allowed-tags {
                                        line-height: 1em;
                              .children #respond {
                                        margin: 0 48px 0 0;
                              h3#reply-title {
                                        margin: 18px 0;
                              #comments-list #respond {
                                        margin: 0 0 18px 0;
                              #comments-list ul #respond {
                                        margin: 0;
                              #cancel-comment-reply-link {
                                        font-size: 12px;
                                        line-height: 18px;
                              #respond .required {
                                        color: #ff4b33;
                                        font-weight: bold;
                              #respond label {
                                        color: #888;
                                        font-size: 12px;
                              #respond input {
                                        margin: 0 0 9px;
                                        width: 98%;
                              #respond textarea {
                                        width: 98%;
                              #respond .form-allowed-tags {
                                        color: #888;
                                        font-size: 12px;
                                        line-height: 18px;
                              #respond .form-allowed-tags code {
                                        font-size: 11px;
                              #respond .form-submit {
                                        margin: 12px 0;
                              #respond .form-submit input {
                                        font-size: 14px;
                                        width: auto;
                              /* =Widget Areas
                              .widget-area ul {
                                        list-style: none;
                                        margin-left: 0;
                              .widget-area ul ul {
                                        list-style: square;
                                        margin-left: 1.3em;
                              .widget_search #s {/* This keeps the search inputs in line */
                                        width: 60%;
                              .widget_search label {
                                        display: none;
                              .widget-container {
                                        margin: 0 0 18px 45px;
                              .widget-title {
                                        color: #3B6B91;
                                        font-weight: bold;
                              .widget-area a:link,
                              .widget-area a:visited {
                              .widget-area a:active,
                              .widget-area a:hover {
                                        text-decoration: underline;
                              .widget-area .entry-meta {
                                        font-size: 11px;
                              #wp_tag_cloud div {
                                        line-height: 1.6em;
                              #wp-calendar {
                                        width: 100%;
                              #wp-calendar caption {
                                        color: #222;
                                        font-size: 14px;
                                        font-weight: bold;
                                        padding-bottom: 4px;
                                        text-align: left;
                              #wp-calendar thead {
                                        font-size: 11px;
                              #wp-calendar thead th {
                              #wp-calendar tbody {
                                        color: #aaa;
                              #wp-calendar tbody td {
                                        background: #f5f5f5;
                                        border: 1px solid #fff;
                                        padding: 3px 0 2px;
                                        text-align: center;
                              #wp-calendar tbody .pad {
                                        background: none;
                              #wp-calendar tfoot #next {
                                        text-align: right;
                              .widget_rss a.rsswidget {
                                        color: #000;
                              .widget_rss a.rsswidget:hover {
                                        color: #ff4b33;
                              .widget_rss .widget-title img {
                                        width: 11px;
                                        height: 11px;
                              /* Main sidebars */
                              #main .widget-area ul {
                                        margin-left: 0;
                                        padding: 0 20px 0 0;
                              #main .widget-area ul ul {
                                        border: none;
                                        margin-left: 1.3em;
                                        padding: 0;
                              #primary {
                              #secondary {
                              /* Footer widget areas */
                              /* =Footer
                              #footer {
                                        background: url(images/footer_back.gif) no-repeat center top;
                                        height: 600px;
                              #colophon {
                                        overflow: hidden;
                                        padding: 45px 0;
                                        font-weight: bold;
                                        color: #FFF;
                                        text-align: center;
                              #site-info {
                                        font-weight: bold;
                              #site-info a {
                                        color: #000;
                              #site-generator {
                                        font-style: italic;
                                        position: relative;
                              #site-generator a {
                                        background: url(images/wordpress.png) center left no-repeat;
                                        color: #666;
                                        display: inline-block;
                                        line-height: 16px;
                                        padding-left: 20px;
                              #site-generator a:hover {
                              img#wpstats {
                                        display: block;
                                        margin: 0 auto 10px;
                              /* =Mobile Safari ( iPad, iPhone and iPod Touch )
                              pre {
                                        -webkit-text-size-adjust: 140%;
                              code {
                                        -webkit-text-size-adjust: 160%;
                              #access,
                              .entry-meta,
                              .entry-utility,
                              .navigation,
                              .widget-area {
                                        -webkit-text-size-adjust: 120%;
                              #site-description {
                                        -webkit-text-size-adjust: none;
                              /* =Print Style
                              @media print {
                                        body {
                                                  background: none !important;
                                        #wrapper {
                                                  clear: both !important;
                                                  display: block !important;
                                                  float: none !important;
                                                  position: relative !important;
                                        #header {
                                                  border-bottom: 2pt solid #000;
                                                  padding-bottom: 18pt;
                                        #colophon {
                                                  border-top: 2pt solid #000;
                                        #site-title,
                                        #site-description {
                                                  float: none;
                                                  line-height: 1.4em;
                                                  margin: 0;
                                                  padding: 0;
                                        #site-title {
                                                  font-size: 13pt;
                                        .entry-content {
                                                  font-size: 14pt;
                                                  line-height: 1.6em;
                                        .entry-title {
                                                  font-size: 21pt;
                                        #access,
                                        #branding img,
                                        #respond,
                                        .comment-edit-link,
                                        .edit-link,
                                        .navigation,
                                        .page-link,
                                        .widget-area {
                                                  display: none !important;
                                        #container,
                                        #header,
                                        #footer {
                                                  margin: 0;
                                                  width: 100%;
                                        #content,
                                                  margin: 24pt 0 0;
                                                  width: 100%;
                                        .wp-caption p {
                                                  font-size: 11pt;
                                        #site-info,
                                        #site-generator {
                                                  float: none;
                                                  width: auto;
                                        #colophon {
                                                  width: auto;
                                        img#wpstats {
                                                  display: none;
                                        #site-generator a {
                                                  margin: 0;
                                                  padding: 0;
                                        #main {
                                                  display: inline;
                                        .home .sticky {
                                                  border: none;
                              /* -------- sidebar region --------*/
                              #sidebar .sidebarContent {
                                        padding-left: 45px;
                              /* base navigation */
                              ul#baseNav {
                                        float: left;
                                        list-style: none;
                                        margin:0;
                                        padding:0;
                                        margin-bottom: 30px;
                              ul#baseNav li {
                                        margin: 0;
                                        padding: 0;
                              ul#baseNav li a{
                                        display: block;
                                        width: 272px;
                                        height: 70px;
                                        text-indent: -1000em;
                              ul#baseNav li a.tours {
                                        background: url(images/tours_main.gif) no-repeat left top;
                              ul#baseNav li a.mission{
                                        background: url(images/mission_main.gif) no-repeat left top;
                              ul#baseNav li a.contact {
                                        background: url(images/contact_main.gif) no-repeat left top;
                              ul#baseNav li a.resources {
                                        background: url(images/resource_main.gif) no-repeat left top;
                              ul#baseNav li a.explorers {
                                        background: url(images/explorers_main.gif) no-repeat left top;
                              ul#baseNav li a.current, ul#baseNav li a.current:hover {
                                        background-position: right top;
                                        border: none;
                                        cursor: default;
                              ul#baseNav li a:hover {
                                        background-position: -272px 0;
                                        border: none;
                              /* ------- footer region ------- */
                              #footer h1 {
                                        padding: 0;
                              #footer h3 {
                                        font: normal 1.3em Arial, Helvetica, sans-serif;
                                        color: #fff;
                                        margin-bottom: 0.5em;
                                        letter-spacing: 0.1em;
                                        margin-top: 0px;
                              #footer p{
                                        font: normal 1em Georgia, "Times New Roman", Times, serif;
                                        color: #fff;
                              #footer p.support {
                                        font-size: 0.8em;
                                        text-align: center;
                                        padding-top: 250px;
                              #footer p.support a{
                                        color: #147;
                              #footer p.support a:hover{
                                        color: #147;
                                        border-bottom: 1px dashed #147;
                                        text-decoration:none;
                              #footer ul#quickNav {
                                        list-style: none;
                                        margin: 0;
                                        padding: 0;
                              #footer ul#quickNav li {
                                        margin: 0 0 .5em 0;
                                        padding: 0 ;
                              #footer ul#quickNav li a{
                                        color: #fff;
                                        font-size: 1em;
                                        font-family: Georgia, "Times New Roman", Times, serif;
                              #footer ul#quickNav li a:hover {
                                        color: #193742;
                                        border-bottom-color: #193742;
                              #footer #footerMenu {
                                        float: left;
                                        width: 230px;
                              #footer #footerBody {
                                        float: right;
                                        width: 540px;
                              #footer #footerBody a {
                                        color: #fff;
                              #footer #footerBody a:hover {
                                        color: #193742;
                              #footer #footerBody #footerMidCol {
                                        float: left;
                                        width: 270px;
                              #footer #footerBody #footerMidCol p {
                                        margin-bottom: 2em;
                              #footer #footerBody #footerRightCol {
                                        float: right;
                                        width: 270px;
                              #footer #footerBody #footerRightCol h1{
                                        font: bold 1.6em Georgia, "Times New Roman", Times, serif;
                                        color: #fff;
                                        letter-spacing:.1em;
                                        text-align:right;
                                        margin-bottom: .25em;
                              #footer #footerBody #footerRightCol p{
                                        color: #fff;
                                        line-height: 1.2;
                                        text-align:right;
                                        margin-bottom: 1em;
                              #footer #footerBody #footerRightCol p.phone{
                                        color: #fff;
                              /* Page template rules */
                              #templateID h1 {
                                        text-align: center;
                                        font: 4em "Trebuchet MS", Arial, Helvetica, sans-serif;
                              #footer #footerContent {
                                        padding: 45px 30px 0px;
                                        overflow: hidden;
                              • 12. Re: CS4 and CS6 design views
                                Don't suppose you have a link to the live page, do you?
                                • 13. Re: CS4 and CS6 design views
                                  I wouldn't have the temerity to suggest that Joe Lowery could write invalid HTML or CSS!  Luckily both HTML and CSS validate (nominally).
                                  And for what it's worth I agree with Rik about the resets.  I rarely (if ever) use them.
                                  Can you explain what you are seeing with regard to the heading centering issue in the two versions of DW?
                                  • 14. Re: CS4 and CS6 design views
                                    AWP64 Level 1
                                    The positioning issue was with the h1 head in div#content. rather than being centered on the it looks positioned to the right. If by chance you have access to Lynda.com the file is used in 'Dreamweaver and WordPress Core Concepts series, chapter 5 lesson one. I have to run a errand and will be away from my station for awhile. I want to thank all for the input, its much appreciated.
                                    • 15. Re: CS4 and CS6 design views
                                      osgood_ Level 8
                                      EEEK! whenever I see anything which Eric Meyers is involved in I'm not surprised it doesn't work. I dunno what the guy is doing now, probably playing his banjo (I believe he was in some kind of country band). He only ever produced css which was way ahead of what any current browser could interpret let alone a software program. Enough said. Personally I'd try to learn css yourself and not rely on other peoples interpretation of how to write it. There is more than one way to skin a cat and the more advanced the css the less likely it is that Dreamweaver will render it correctly. You can achieve the same results that will render in Dreamweaver with far less convoluted css in my opinion.
                                      • 16. Re: CS4 and CS6 design views
                                        Eric doesn't deserve this criticism.
                                        His involvement in this template is likely only that Joe chose to use Eric's reset CSS.  There's nothing bleeding edge there.
                                        • 17. Re: CS4 and CS6 design views
                                          John Waller Adobe Community Professional & MVP
                                          He certainly pushed the envelope in the early days of CSS but he also pushed standards and usable CSS.
                                          His approach is as pragmatic as much as it is experimental.
                                          • 18. Re: CS4 and CS6 design views
                                            osgood_ Level 8
                                            Fair enough, everyones entitled to their opinion.
                                            Was just saying it seems the more of an 'expert' people claim to be the more likely that they will try and confuse those that aren't by using techniques which aren't really required. i guess its their way of feeding their ego.
                                            • 19. Re: CS4 and CS6 design views
                                              osgood_ Level 8
                                              I don't thing Eric ever create a 'real world' site or was that bothered about creating one. Only lectured and published a few books about css. The two are worlds apart.
                                              • 20. Re: CS4 and CS6 design views
                                                All I can say is I learned plenty of real world CSS from Eric in my early days.
                                                Eric's Wordpress blog http://meyerweb.com is still being updated for those interested in his activities.
                                                • 21. Re: CS4 and CS6 design views
                                                  osgood_ Level 8
                                                  John Waller wrote:
                                                  http://meyerweb.com is still going strong.
                                                  I wouldn't call it much of a commercial site myself. A playground for Eric, yes.
                                                  • 22. Re: CS4 and CS6 design views
                                                    Eric wasn't feeding his ego.
                                                    He was experimenting with advanced CSS and inspiring many people along the way.
                                                    • 23. Re: CS4 and CS6 design views
                                                      I certainly took inspiration from him as well!  He's a great guy....
                                                      • 24. Re: CS4 and CS6 design views
                                                        I changed the wording of my post because I changed what I wanted to say.
                                                        His blog is there for those who want to visit. It's not a commercial venture as far as I can see.
                                                        • 25. Re: CS4 and CS6 design views
                                                          osgood_ Level 8
                                                          That's my point. Often those without commercial experience have little in common with those that do.  There's room for all of course.......you just need to work out who to rely on in different senarios. Eric, fortunately for me wasn't one of them.
                                                          • 26. Re: CS4 and CS6 design views
                                                            Rik Ramsay Level 4
                                                            Getting back to your question, you could try and leave the reset as it is but remove all instances of "background: transparent;" or "background-image:transparent;" from your CSS and see if it clears up your issue. This has been the main culprit for CS6 design view looking different from previous versions.
                                                            Live View shows your design using a web browser engine to give the page a more accurate appearance, whereas Design View is just showing the code more or less as is and without many of the CSS styles applied - especially if you have used CSS3. It goes without saying but you should not rely on Design View to give an accurate representation of your site - that is what Live View is for.
                                                            • 27. Re: CS4 and CS6 design views
                                                              AWP64 Level 1
                                                              Very good. Thanks for the info Rik, its much appreciated!
                                                              • 28. Re: CS4 and CS6 design views
        hen3ry Level 1
        I just installed DW CS6.  So far I have not seen any particular issues with Design View being totally different than what I saw in DW CS5 --or radically strange.   I upload and view my pages on the server early and often in my workflow, so I'm not too worried about Design View.  Generally, I view Design View as 1)  a sanity check and 2) a tool which enables me to find particular places I want to add or correct markup,  usually faster than in Code View.
        I may change my mind about CS6 Design View after I get more experience with it.
        Specifically about  your "...good deal stricter..." point:
        If invalid code causes no more than a hinky display, I can sort-of live with that, per my comments above.    I'm more concerned with the implied possibility that DW CS6 is more susceptible to becoming internally confused due to invalid
        code.
        (I have seen some problems of  "internal confusion"  in earlier DW versions, for example:  deleting characters works correctly, but at some distance from the current cursor position. Or: text entry resulting in a chunk of nearby content
        text disappearing, apparently erased.    In most cases, it seems these problems resulted from insufficiently enclosed content.  I could usually un-confuse DW by being more generous with DIVs.)
        My concern is this:  I'm pretty sure very few people write perfect code the first time.   During development, enclosure problems seem like a common mishap. It isn't exactly a Class 1 Felony.    If DW CS6 is more susceptible to common missteps during early development, well, ummmm......
