Hi All,
I am trying to configure LiveCycle Rights Management with Microsoft SharePoint. While Configure the LiveCycle server settings on the SharePoint site to enable SharePoint users to invoke LiveCycle processes from the SharePoint site.
Kindly reply me...
Amol
Total Likes
Which version of LiveCycle you are on and Which version of sharepoint server you are configuring it with?
What steps you have followed to install and activate the connector?
Total Likes
Thanks for your reply.
Lifecycle Rights Management Version : ES3
SharePoint Server : 2010
I have followed documents for installing (lifecycle_install_jboss.pdf Link: http://help.adobe.com/en_US/livecycle/10.0/InstallJBoss/livecycle_install_jboss.pdf) and configuration lc_sharepoint_config.pdf.
Total Likes
Can you please mention the steps in brief that you have followed? This will help me to identify the problem.
Also, where exactly you are facing the problem. on "security with adobe policy" operation or on "invoke adobe livecycle process".
Total Likes
I have followed below step.
While doing this configuration on SharePoint site setting on SharePoint server.
Amol
Total Likes
The steps you have followed look okay to me.
Please check whether you have all the below files in your web application directory.
AdobeLiveCycleConnector.de-DE.resx
AdobeLiveCycleConnector.de.resx
AdobeLiveCycleConnector.en-US.resx
AdobeLiveCycleConnector.en.resx
AdobeLiveCycleConnector.fr-FR.resx
AdobeLiveCycleConnector.fr.resx
AdobeLiveCycleConnector.ja-JP.resx
AdobeLiveCycleConnector.ja.resx
AdobeLiveCycleConnector.resx
AdobeLiveCycleFormsIntgr.de-DE.resx
AdobeLiveCycleFormsIntgr.de.resx
AdobeLiveCycleFormsIntgr.en-US.resx
AdobeLiveCycleFormsIntgr.en.resx
AdobeLiveCycleFormsIntgr.fr-FR.resx
AdobeLiveCycleFormsIntgr.fr.resx
AdobeLiveCycleFormsIntgr.ja-JP.resx
AdobeLiveCycleFormsIntgr.ja.resx
AdobeLiveCycleFormsIntgr.resx
AdobeLiveCycleTaskManager.de-DE.resx
AdobeLiveCycleTaskManager.de.resx
AdobeLiveCycleTaskManager.en-US.resx
AdobeLiveCycleTaskManager.en.resx
AdobeLiveCycleTaskManager.fr-FR.resx
AdobeLiveCycleTaskManager.fr.resx
AdobeLiveCycleTaskManager.ja-JP.resx
AdobeLiveCycleTaskManager.ja.resx
AdobeLiveCycleTaskManager.resx
AdobeLiveCycleWorkflow.de-DE.resx
AdobeLiveCycleWorkflow.de.resx
AdobeLiveCycleWorkflow.en-US.resx
AdobeLiveCycleWorkflow.en.resx
AdobeLiveCycleWorkflow.fr-FR.resx
AdobeLiveCycleWorkflow.fr.resx
AdobeLiveCycleWorkflow.ja-JP.resx
AdobeLiveCycleWorkflow.ja.resx
AdobeLiveCycleWorkflow.resx
The error that you are getting "liveCycleSettings.pageTitle" key not found. This key is available in the AdobeLiveCycleConnector.resx file. This file and it's localized versions should be available inside your web application directory's App_GlobalResources folder. For example, C:\inetpub\wwwroot\wss\VirtualDirectories\80\App_GlobalResources. These should have been copied there when you installed the connector.
Total Likes
Yes,
I have check all files are present in that folder (36 files).
Amol
Total Likes
Hi
Please check, because of this I am getting error while configuring Adobe LiveCycle setting in SharePoint console.
Total Likes
No, this is fine. You are getting this message because you are on a Standalone sharepoint 2010 server, where usually the SharePoint Admin service is in stopped state. The next line "Executing job-application-server-admin-service" does what should have been done by sharepoint admin service if it was runnning. So, this is not the cause of your problem.
Can you please try uninstalling the connector and then installing again.
For uninstallation :
1.) Deactivate the livecycle connector features from the site collection(s).
2.) install.bat -uninstall
3.) install.bat -retract
4.) install.bat -delete
For installation :
1.) install.bat -create
2.) install.bat -add
3.) install.bat -deploy
4.) install.bat -install
5.) goto the site collection and activate the adobe livecycle connector features.
Important : After every command please check to see whether the changes got updated. Run the command stsadm -o enumsolutions. You should get an xml output on the command prompt and make sure you don't see any tags like "<State>...</State>" in the output for your solution named "sharepointconnector.wsp", if you do , run the command again and wait until its gone, then run the next command.
You can also run this command in a seperate terminal.
Total Likes
HI,
I have done step which you send but still facing same issue and tell me where it is wrong. Video link
http://www.4shared.com/file/_Tzau24l/SharePoint_Configuration1.html
Amol
Total Likes
Can you just try to use some other browser? It might be some security issue also. I have seen the attached video and the steps you do are fine.
Total Likes
Yes i have tried and also tried to open from diffent system.
Is this bug or what because we have followed all step properly....
Amol
Total Likes
