unable to install Extension Manager 6.1 update on my Mac. Running Lion
What error message are you receiving when you try to install? What have you tried so far to resolve your difficulties?
Installation failed. Error Code: U44M2P7
Rebooted computer, downloaded another copy of patch. No difference. I am not exactlyan expert here! What else should I try?
Thank you Enny1f. The reason which I inquire is users often will turn around after suggestions are offered and then tell us they have already completed those steps. This helps give a clear picture on how to proceed.
First I would recommend checking your version of the Adobe Application Manager. It is located in Applications/Utilties/Adobe Application Manager/core. If it is not version 6.2.77 or later then please obtain the update from the bottom right hand corner of our download page. The download page is located at http://www.adobe.com/downloads/.
Hi jeff
Thank you. I did update the App Manager, 6.2.77, but still cannot install the patch. I get the same error message.
Are you able to manually download and install the update from http://www.adobe.com/downloads/updates/?
No. Tired that, and still smae error message.
May this help :-
Thanks, Sharma. I note that it was a problem back in 2010, so this may not be the same but worth a try. I will see how I manage it, but sounds a bit advanced for my simple brain.
Hi Sharma
I have updated PS on my other computer, and it has installed the patch OK. So, do I just copy the Extension Manager folder from the successful to the unsuccessful computer, and will it automatically replace; or do I have to uninstall the non-functioning Ext Manager first? I don't want to screw things up.
btw, not sure why this happened, as I have always updated regularly.
