12 Replies Latest reply on Aug 12, 2012 5:43 AM by DocPixel-BMW
    Help with tracing an image please
    simpson246 Level 1
      Hi all, I've got an image I got sent by someone as I'me looking to cut it out on my vinyl cutter.
      It's open in illustrator so I've selected it and click live paint - trace.
      Below is the image.
      When I trace it, all the straight edges go wonky and I'm unsure how to fix this.
      Please help.
      thanks,
        • 1. Re: Help with tracing an image please
          Monika Gause Adobe Community Professional & MVP
          don't use auto-trace on that one. Just construct it instead. Should be a matter of minutes.
          • 2. Re: Help with tracing an image please
            simpson246 Level 1
            Thanks for the reply.
            How would I do that please? Sorry, I'm still new to Illustrator and haven't built anything from scratch.
            thanks,
            • 3. Re: Help with tracing an image please
              Depends on if the client wants it cleaned up in that process, because that logo is so sloppily constructed it could need some straightening.
              In case you just want to have it vectorised: take the pen-tool and create some corner points, using the image as a guide. Read the manual on how to work with the pen-tool.
              You could crete the outmost octagon with the polygon tool. Looks like it might be a perfect octagon.
              1 person found this helpful
              • 4. Re: Help with tracing an image please
                simpson246 Level 1
                It needs to look how it does here really with the straight edges etc.
                Right first of all, i've got the graphics open in illustrator.
                I've just started drawing over the design with the straight line tool.
                A quick question I have is how would I delete parts? If I made the octagon, how would I delete the section?
                thanks,
                • 5. Re: Help with tracing an image please
                  Scott Falkner Level 6
                  Use the pen tool. Using Illustrator without knowing how to use the pen tool is like driving a race car and never changing gears. Search for Illustrator Pen Tutorials. There are thousands.
                  • 6. Re: Help with tracing an image please
                    Jacob Bugge MVP & Adobe Community Professional
                    Simpson,
                    You can just click each corner with the Pen Tool; with the Line Tool you get separate paths where you need full, closed paths.
                    If you have Smart Guides on, you can see that you get the right angles (literally and those halving them).
                    But I believe I would suggest a slightly different approach. Sorry have to leave.
                    • 7. Re: Help with tracing an image please
                      [scott] Level 6
                      Careful... get it wrong and the Robocop cyborgs will get you.
                      (The logo is from the series of Robocop movies)
                      • 8. Re: Help with tracing an image please
                        simpson246 Level 1
                        Cheers for the info, I actually did the entire thing with lines and has just cut the design and all is fine.
                        A quick question I have is how would I delete parts? If I made the octagon, how would I delete the section like in the image?
                        haha, oo I will be scott.
                        Cheers,
                        • 9. Re: Help with tracing an image please
                          DocPixel-BMW Level 2
                          @simpson246 - may I humbly ask how in the world you have a vinyl cutter and taking jobs to cut... where as you have no knowledge of vectors, pen-tools, etc.? That's  amazing... just plain sad...or  both.
                          • 10. Re: Help with tracing an image please
                            [Jongware] Most Valuable Participant
                            DocPixel, Learning By Mistake is a perfectly good way to learn -- and never ever to forget the lessons learned!
                            • 11. Re: Help with tracing an image please
                              simpson246 Level 1
                              Thanks for the replies and help, much appreciated.
                              In reply to DocPixel, I currently use Cutstudio to edit small parts of designs and 99% of the designs I have available are already in the correct format etc and ready to cut.
                              I'm now looking to trace designs (which I have now been able to do due to help on this post) and even start creating custom designs which I have also done.
                              Thanks for your input how ever useless it may have been.
                              • 12. Re: Help with tracing an image please
                                @simpson246 - I guess I'm a bit curious for a couple of reasons:
                                1) why you specifically came here to this forum, to ask for help about Illustrator. Besides the fact that Cutstudio also has an integrated tracing feature, your answer could have easily been found on say YouTube or through a Google search. Literally 1000's of tutorials on the web how to use the pen tool, manually or automatically tweak settings for Auto Trace and then do manual clean up.
                                2) the other point was that I was shocked (which is common the more often I visit these forums I must say), that while you have a vinyl cutter, you have no knowledge of how the designs or documents are created that you send to it. This has (as far as I know) always been done in one kind of vector software or another for almost a couple of decades now. Even the cutter software has a pen tool(s) to create the cut-line. So what made you decide to use a strange new program like Illustrator to do the job?
                                While I thoroughly enjoy teaching people new tricks or help troubleshooting problems, I do have a rather nasty pet peeve. That is when it appears that someone is too lazy to spend the time to search for an answer, or take the time to learn from the copious amount of information and tutorials freely available on the web, and posts a question instead.
                                I've been in this business now for 30+ years, and I can't tell you how many 1000's of hours I have given to learning my trade, whether software, art, or technology. I've done this on my time and my dollar for the vast majority of it. I never expected a "free simple ride", which means I also didn't ask questions until all other sources were exhausted.
                                Lastly, whether I should and do ignore it most days, the fact that so many people think that they can just purchase a couple of thousand dollars worth of equipment and software and now they are a "professional" business by just hitting the "print button".... irks me.
                                Over the years I've witnessed countless small businesses that invested literally 10s of thousands of dollars over the years, thus supporting the developers and moving the industry forward, with training and equipment... only to see them be undercut and sometimes wiped out be these "new kids on the block". The very same kids that come here now and ask "newbie" questions to do the job for 1/3 price. It is what it is and I can't change that and don't even attempt to, but it surely does get to me some days.
                                Yes, I realize I should be more disciplined and let it slide without comment then... but, ya know... I'm human and just as impulsive as the next guy/girl some times that posts the question rathing than waiting a minute or 2.
                                @Jongware - I agree fully with "Learning By Mistake is a perfectly good way to learn".
                                It's learning by "having some one else do all the work", or "learning on the free individually tailored training from others" that I disagree with. Google, YouTube, AdobeTV, Smashing Magazine, etc. etc. also offer "free", you just might have to apply yourself. Also there is fantastic and affordable online training from Lynda.com to boot.
                                Learning by mistake and experimentation is the only way some of us Old Dogs were able to learn at all. Now get off my lawn!
