13 Replies Latest reply on Aug 10, 2012 8:08 AM by manojb05
    PHP form submission Problem
    manojb05 Level 1
      Dear all,
      PHP enquiry form submission some error is comes
      "Parse error: syntax error, unexpected T_STRING in /home/newtocli/public_html/en45/send_form_email.php on line 11"
      Please help me
      WEBLINK
      PHP goes like this
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
      <title>PHP Form</title>
      </head>
      <body><?php
      if(isset($_POST['email'])) {
          // EDIT THE 2 LINES BELOW AS REQUIRED
          $email_to = "xyz@xyz.co.in";
          $email_subject = "Your email subject line";
          function died($error) {
              // your error code can go here
              echo "We are very sorry, but there were error(s) found with the form you submitted. ";
              echo "These errors appear below.<br /><br />";
              echo $error."<br /><br />";
              echo "Please go back and fix these errors.<br /><br />";
              die();
          // validation expected data exists
          if(!isset($_POST['first_name']) ||
              !isset($_POST['email']) ||
              !isset($_POST['telephone']) ||
                          !isset($_POST['company_name']) ||
              !isset($_POST['comments'])) {
              died('We are sorry, but there appears to be a problem with the form you submitted.');
          $first_name = $_POST['first_name']; // required
          $email_from = $_POST['email']; // required
          $telephone = $_POST['telephone']; // not required
                $last_name = $_POST['company_name']; // required
          $comments = $_POST['comments']; // required
          $error_message = "";
          $email_exp = '/^[A-Za-z0-9._%-]+@[A-Za-z0-9.-]+\.[A-Za-z]{2,4}$/';
        if(!preg_match($email_exp,$email_from)) {
          $error_message .= 'The Email Address you entered does not appear to be valid.<br />';
          $string_exp = "/^[A-Za-z .'-]+$/";
        if(!preg_match($string_exp,$first_name)) {
          $error_message .= 'The First Name you entered does not appear to be valid.<br />';
        if(!preg_match($string_exp,$company_name)) {
          $error_message .= 'The Last Name you entered does not appear to be valid.<br />';
        if(strlen($comments) < 2) {
          $error_message .= 'The Comments you entered do not appear to be valid.<br />';
        if(strlen($error_message) > 0) {
          died($error_message);
          $email_message = "Form details below.\n\n";
          function clean_string($string) {
            $bad = array("content-type","bcc:","to:","cc:","href");
            return str_replace($bad,"",$string);
          $email_message .= "First Name: ".clean_string($first_name)."\n";
          $email_message .= "Email: ".clean_string($email_from)."\n";
          $email_message .= "Telephone: ".clean_string($telephone)."\n";
                $email_message .= "Company Name: ".clean_string($company_name)."\n";
          $email_message .= "Comments: ".clean_string($comments)."\n";
      /* Redirect visitor to the thank you page */
      header('Location:gt.html');
      exit();
      // create email headers
      $headers = 'From: '.$email_from."\r\n".
      'Reply-To: '.$email_from."\r\n" .
      'X-Mailer: PHP/' . phpversion();
      @mail($email_to, $email_subject, $email_message, $headers);
      <!-- include your own success html here -->
      Thank you for contacting us. We will be in touch with you very soon.
      <?php
      </body>
      </html>
        • 1. Re: PHP form submission Problem
          osgood_ Most Valuable Participant
          2 issues manojb
          1) You have $last_name instead of $company_name in your php script (should be as below)
          $company_name = $_POST['company_name']; // required
          2) If you position the redirect where you have the form will not send the information as the php stops running at that point and never gets to the @mail command
          exit();
          Position it AFTER the @mail command.
          Also the php script doesnt need the html wrapped around it. It can just go in a document without that.
          • 2. Re: PHP form submission Problem
            manojb05 Level 1
            osgood thanks for your reply. i am go with your recommend now error come like this
            Parse error: syntax error, unexpected T_STRING in /home/newtocli/public_html/en45/send_form_email.php on line 4
            • 3. Re: PHP form submission Problem
              Have your removed the html tags from around the form script?
              <head>
              </head>
              <body>
              </body>
              </html>
              • 4. Re: PHP form submission Problem
                manojb05 Level 1
                sorry i am testing the code, anyway now error is something like
                • 5. Re: PHP form submission Problem
                  If the form works you can turn error reporting off - just add the below after the opening <?php tag
                  error_reporting(0);
                  The form works ok for me.
                  • 6. Re: PHP form submission Problem
                    manojb05 Level 1
                    something wrong from my side i dont know where it is gone wrong now error is
                    Parse error: syntax error, unexpected T_STRING in /home/newtocli/public_html/send_form_email.php on line 12
                    I am really sorry osgood
                    PHP Code Updated
                    <head>
                    </head>
                    <body><?php
                    error_reporting(0);
                        $email_to = "xyz@rty.co.in";
                            die();
                    exit();
                    <?php
                    </body>
                    </html>
                    • 7. Re: PHP form submission Problem
                      You still have not removed the html code from around the php script...try removing that.
                      <head>
                      </head>
                      <body>
                      </body>
                      </html>
                      • 8. Re: PHP form submission Problem
                        manojb05 Level 1
                        osgood something like this
                        <?php
                        error_reporting(0);
                                die();
                        exit();
                        <?php
                        • 9. Re: PHP form submission Problem
                          Yes,
                          I don't know why you are getting the T_String error. If I copy what you paste and test it with your form everything works fine for me.
                          • 10. Re: PHP form submission Problem
                            manojb05 Level 1
                            some error now
                            Parse error: syntax error, unexpected T_STRING in /home/newtocli/public_html/send_form_email.php on line 5
                            My form like this
                            <form name="contactform" method="post" action="send_form_email.php">
        <div class="field text">
        <input  type="text" name="first_name" maxlength="50" size="30" value="Name*:">
        </div>
        <input  type="text" name="email" maxlength="80" size="30" value="E-mail*:">
        </div>
        <div class="clear"><!-- --></div>
        <input  type="text" name="telephone" maxlength="30" size="30" value="Phone.:">
        </div>
        <input  type="text" name="company_name" maxlength="50" size="30" value="Company:">
        </div>
        <div class="field textarea"><div>
        <textarea  name="comments"></textarea>
                                                        </div></div>
        <div class="submit">
        <p>* - Required fields</p>
        <input type="submit" value="Send" />
        </div>
        </form>
                            • 11. Re: PHP form submission Problem
                              manojb05 Level 1
                              i am save as a php code its working thanks osgood
                              • 12. Re: PHP form submission Problem
                                What was it saved as before then manojb?
                                Your form action says:
                                send_form_email.php
                                • 13. Re: PHP form submission Problem
                                  manojb05 Level 1
                                  send_form_email.php i am changed file name to send.php its working.
