1 2 Previous Next 45 Replies Latest reply on Aug 18, 2012 7:03 AM by Neil Enns - Adobe
    Scrollable content inside an MSO bug
    Yves Apel - IC Level 2
      after some previous errors with the new v22 tools, I was now able to finaly continue my tests on my project.
      But now, scrollable content inside an MSO is shifted by 15px (iPad 1-2)/30px (iPad 3) to the right.
      Here are some screenshots:
      I have created new folios with the latest version of the plugins and InDesign CS6. The folio is v20!
      Does anybody have the same problem? Please help
      –Yves
        • 1. Re: Scrollable content inside an MSO bug
          Laubender Adobe Community Professional & MVP
          Hi, Yves!
          Does it make a difference, if you are doing PDF, PNG or JPEG folios?
          Can you see the same bug if using InDesign CS5.5?
          Uwe
          • 2. Re: Scrollable content inside an MSO bug
            Dear Uwe,
            It makes no difference if I create a different folio type.
            I did not try CS5.5 as I have not the time anymore to do beta tests today. It isn't neither possible to convert the project back to CS5.5 It are about 100 pages per orientation to review in this case.
            -Yves
            • 3. Re: Scrollable content inside an MSO bug
              toutoungi
              hi... also just tested the different formats... PDF, PNG, JPEG.... Automatic.... no difference
              i dont have CS 5.5 anymore!!!... or the time for these tests!!!
              ADOBE DO SOMETHING!!!
              • 4. Re: Scrollable content inside an MSO bug
                @Yves && toutoungi:
                I'll do some tests with MSOs and the v22 Folio Builder (v20 folios) together with CS5.5 and Overlay Creator v20 in the afternoon.
                I still hesitate using CS6 for production purposes until at least v8.0.1 is out.
                But I'm sorely tempted to do so…
                Though this totally seems to be a DPS issue…
                Just building a test scenario with an MSO and scrollable frames, that consist of table objects, scrolling direction: vertical.
                Just a question to Yves:
                Is the width of your scrollable frame container object smaller than the individual state in your MSO?
                Maybe you can provide a screen grab of your InDesign page where all frame borders of all objects are selected or made visible…
                Uwe
                • 5. Re: Scrollable content inside an MSO bug
                  toutoungi Level 1
                  hi.
                  thanks. looking forward to hearing from you about that.
                  like u said, this must be a DPS related issue... before the update i only had very bad performace issues on the new and old iPad(2).
                  with the update i just have more problems to deal with.
                  • 6. Re: Scrollable content inside an MSO bug
                    @Yves && toutoungi –
                    first tests with a really simple MSO and scrollable frames inside all states controlled by a button outside of the MSO are showing that there is NO shifting of contents.
                    My testing configuration:
                    InDesign CS5.5 v7.5.3 Build 333
                    OSX 10.6.8
                    MacBook Pro (MacBookPro5,1 from the end of 2008)
                    iPad3
                    Scenario 1:
                    Folio: JPEG Maximum Quality
                    Folio size 1024x768
                    Folio Page Direction: horizontal only
                    No of articles: 1 (no of pages: 1)
                    Scenario 2:
                    Folio: PDF
                    Folio size 1024x768
                    Scenario 3:
                    Folio: PDF
                    Folio size 1024x768
                    Folio Page Direction: horizontal and vertical
                    Tested in Adobe Content Viewer on the Mac
                    Tested in Adobe Content Viewer on the iPad3
                    (via USB cable attached)
                    The ACV on the iPad is the one that was freely released along with DPS v20.
                    Adobe DPS version:
                    plug-in version
                    7.5.5.20
                    folio format version
                    2.0.0
                    plist version
                    1.3.0
                    ExtensionBundleVersion
                    12.3.1.20120730_m_695362
                    Hope, that helps…
                    Uwe
                    • 7. Re: Scrollable content inside an MSO bug
                      Bob Bringhurst - Adobe Adobe Employee
                      Yves, do you have Use Document Position selected in the Overlays panel?
                      • 8. Re: Scrollable content inside an MSO bug
                        toutoungi Level 1
                        Hi Bob,
                        im also having the same problems with MSO since the last update. I am not using document position. Its set to top left. Also its not only the content of the scrollable frame that is shifting. The whole MSO is shifting except for the frame in which the scrollable content is placed in - the content is shifted.
                        • 9. Re: Scrollable content inside an MSO bug
                          toutoungi Level 1
                          Hi bob,
                          just changed the settings to "Use Documet Position". Still shifting.
                          The shift is not only in Scrollabel MSO's - i have similar shift problems in MSO with simple buttons that change the staus of the MSO. In that case it shifts one of these buttons up 6 px when you tap it and back down when u go to the next status (in some of the MSO's with 4 status)
                          These MSO's all used to work fine untill the update - CS6 with the latest DPS updates (08.08.2012) on both a windows PC and a Mac.
                          Versions:
                          8.0.8.22
                          Hope you have some infos for us...
                          thanks
                          mo
                          • 10. Re: Scrollable content inside an MSO bug
                            Is this happening on both the iPad viewer and the desktop viewer?
                            • 11. Re: Scrollable content inside an MSO bug
                              Sorry, I have to finish a project here. I will answer your questions in 1/2 hour.
                              • 12. Re: Scrollable content inside an MSO bug
                                toutoungi Level 1
                                hi
                                it is... or beter said it was.... the last test i could not upload...
                                • 13. Re: Scrollable content inside an MSO bug
                                  Hi all,
                                  I was speaking today with the customer support (multiple times) and they did tests and its working for them but not if they take my original file. At the end now I still had an folio uploaded that was made before the update and it is OK. All new folios are not.
                                  I shared now this old folio with the customer support and are waiting what they say.
                                  @Bob: If you are interestet, I can also share this old and a new folio with you!
                                  An info that has not passed before: I have a document size of 2048 x 1536 and upload it to a 1027 x 768 folio / PDF / v20.
                                  I think the problem happens there since the plugin update. I have no iPad 3 for testing here and will not until the week of 27.08.
                                  To answer the questions:
                                  The container is smaller than the the MSO. But the Content in the scrollable container has the same size.
                                  Yes, I do
                                  • 14. Re: Scrollable content inside an MSO bug
                                    @Bob – for my tests in InDesign CS5.5 where all went fine for "Scrollable Contents" * inside an MSO I used:
                                    "Vertical scrolling only" * and
                                    "Document Position" *
                                    selected,
                                    "Scroll bars visible" *
                                    not selected.
                                    *I'm on the german tools, so cannot tell exactly the right terms…
                                    The following screen grab shows:
                                    1. the frame for "Scrollable Contents" is selected
                                    2. the green frame is just a position indicator in the background of the page
                                    3. the huge frame not filled with color is the MSO
                                    4. the cyan frame is the button that controls the MSO
                                    Hey, I really don't mind, but don't confuse me with Yves ;-)
                                    I will do more tests with scrollable frames, where the width of the contents is smaller than the container frame itself.
                                    Maybe that could be the culprit?
                                    Uwe
                                    • 15. Re: Scrollable content inside an MSO bug
                                      Here are my prefs:
                                      @Uwe: Who got you confused with me?
                                      • 16. Re: Scrollable content inside an MSO bug
                                        @Yves:
                                        Bob in #7  replying to me (#6) and addressing you ?!
                                        Uwe
                                        • 17. Re: Scrollable content inside an MSO bug
                                          I think, I give up testing for a  bug that is not there (CS5.5)…
                                          @Yves – what you could try is exporting your InDesign CS6 file to IDML, reopen it, building a new Folio and testing again.
                                          In one strange case, I cannot recall exactly (it was a file by one of my students), that was the remedy for a problem…
                                          Uwe
                                          • 18. Re: Scrollable content inside an MSO bug
                                            toutoungi Level 1
                                            hi.
                                            just tried using "go to next status" and "go to prevus status"...
                                            still the same issue. On both the new iPad and the iPad 2.
                                            I use automatic and not PDF to export the folios although it is not recomended. But with PDF format i had major problems already before the updates. That is a seperate case that i have already filed 2 weeks ago with the european support team.
                                            Bob, have you been able to reconstruckt the problem?
                                            Im going to continue testing....
                                            ciao
                                            • 19. Re: Scrollable content inside an MSO bug
                                              toutoungi Level 1
                                              nothing seems to be working with these MSO anymore... Is there way to avoid these MANDATORY UPDATES!!!! or can i at least there a way to re-install the older version!!!!!
                                              I can basicly throw the last 4 weeks of work in the trash!
                                              i am definalty not happy with this!
                                              THANK YOU ADOBE!!!!
                                              • 20. Re: Scrollable content inside an MSO bug
                                                Neil Enns - Adobe Adobe Employee
                                                Toutoungi,
                                                You can set your folio version in the Foilo Builder Panel to v21, which will give you folio output that matches the previous version.
                                                For this specific shifting issue, what document units are you using for the InDesign document? Are you in points/picas or pixels?
                                                Neil
                                                • 21. Re: Scrollable content inside an MSO bug
                                                  I just tested:
                                                  Saving file as IDML --> Open IDML in CS6 again --> Result: Same Error
                                                  Saving file as IDML --> Open IDML in CS55 --> The scrollable content option is not activated anymore --> Reactivating scroll. cont. --> Result: Same Error
                                                  Redoing the MSO objects is not an option. They are already verified by the customer and the complete Issue (+100 pages per orientation) are 99.5% final.
                                                  • 22. Re: Scrollable content inside an MSO bug
                                                    @Yves – hm. You tested in InDesgn CS5.5 and the bug was still there… Not good at all…
                                                    Let's break that down to a reasonable test case.
                                                    Note (from my knowledge of scripting overlays):
                                                    1. To "inject" an overlay effect to a page object a method is used that is exactly or is similar to apply "labels" with the JavaScript method insertLabel("keystring","valuestring") to that object.
                                                    2. You cannot see thiese "labels" in the UI (unlike the script labels you can apply with the UI; that's a totally different thing)
                                                    3. The "labels" stick to the object until you choose to click the "trash bin" in the "Scrollable Frame" palette of the Overlay Creator.
                                                    4. The Folio Builder is reading out the "valuestring" part by extractLabel("keystring") and acting upon the values to build the overlay effects
                                                    5. The key/value pairs still stick to the object even when exported to IDML or to IDMS.
                                                    Trying a solution for InDesign CS5.5 assuming the bug is not there:
                                                    Note: This is highly speculative or are  assumptions, I  still have to verify:
                                                    1. If you open the IDML exported from InDesign CS6 in CS5.5 the overlays do not work anymore, because InDesign CS5.5 works with different key/value pairs, even if you work in the same version of DPS of FolioBuilder and OverlayCreator
                                                    2. Important here: the key/value pairs are still there, they were never trashed!
                                                    3. If you apply new key value pairs (did you use the "trash bin" of your overlay panel in InDesign CS5.5 or CS6 before? If not:) you send new key/value pairs of properties to the object (the scrollable frame) on top of those which are already there (from the toolset of InDesign CS6)
                                                    4. Now, and this is really a wild guess, DPS on CS5.5 is reading both and acting on both: the old key/value-pairs (CS6) and the new ones (CS5.5)
                                                    => The bug is still there!
                                                    Conclusion for a new test case with a single MSO:
                                                    CS6:
                                                    Use the "trash bin" of your "Scrollable Frame" Palette to strip all key/value-pairs from the container frames of the scrolling contents.
                                                    Then export that MSO to IDML or try IDMS (Snippet)
                                                    CS5.5
                                                    Open the IDML or place the IDMS,
                                                    apply the appropriate features with your "Scrollable Frame" Palette
                                                    If the bug is still there, we can make the wake assumption, that the bug is also present in CS5.5 DPS FolioBuilder v22.
                                                    I say "wake", because it could be that using the "trash bin" does not strip out all possible "key/value" pairs of the object, but only a few, so that the Overlay Creator cannot recognize the object as an overlay.
                                                    If you like, you can send me a test case of a not working single MSO in InDesign CS5.5 (an IDML or better a IDMS snippet) by E-Mail. Strip out all text values out of the MSO, if you like.
                                                    I will test the thing in my own configuration and will look more deeply into the IDML for "key/value" pairs present.
                                                    Another observation with an older version of DPS (I think it was v19):
                                                    I had a crash with InDesign CS5.5 when using tables in an complex MSO. But that crash is not happening any more with the newer version (v20 and above). Still – your bug could be triggered by using tables with certain properties (maybe cell styles). But this is really a wild guess…
                                                    Uwe
                                                    • 23. Re: Scrollable content inside an MSO bug
                                                      toutoungi Level 1
                                                      tried that also--- v20, v21, and v22 - although 22 only on the desktop ACV.
                                                      My publication also has over a hundred MSO's that have all been approved by our client! changing everything is not an option!
                                                      here some screen shots of how it should be (in indesign):
                                                      and here is what they look like in the content viewer (desktop):
                                                      Note that the Button is shifted to the right. The content of the scrolable frame is also shifted to the right, but the scrolable frame itself is the right position. The content of the scrolable frame extrudes out of the frame it is in on the right side. See next screen shot:
                                                      This started happening after the last manditory update.
                                                      • 24. Re: Scrollable content inside an MSO bug
                                                        toutoungi Level 1
                                                        Hi Neil,
                                                        to your question about the units - im using pixel as the document units. Have always had that setting...
                                                        Are we the only two people (Yves and me) having this problem?
                                                        One more thing... that no one has mentioned - the Bug is not related to scrolable frames. Normall scrolable frames funktion properly. It only occurs in MSO regardles of them being scrollable or not. I did some test with empty frames and there was no problem... as soon as i added text in to the buttons (open and close) that controll the MSO's the error occured again.
                                                        • 25. Re: Scrollable content inside an MSO bug
                                                          @toutoungi – interesting! Are the buttons inside or outside the MSO?
                                                          I will test again with CS5.5 with text inside the buttons…
                                                          Uwe
                                                          • 26. Re: Scrollable content inside an MSO bug
                                                            I tried the few scenarios of Uwe and none is working! The file is on its way to you.
                                                            I was reinstalling also another machine with the v21 Plugins. And it is working again!
                                                            It is a bug in the v22 plugins and not a design error from my site that the customer support is telling me all the time since yesterday.
                                                            The problem is that the plugins are not separate anymore in CS6 (Why Adobe, Why? You did the separation because of this problems in the past).
                                                            I can get the overlays in the old plugins working. But as the the folio builder web access is mandatory, I can't upload it anymore.
                                                            (@Neil: Thats why your answer will not work).
                                                            Saving back to CS5.5 is not an option as the text has been verified for hyphens, etc.
                                                            Adobe sorry to tell, but you have to release an hotfix until end of next week. I have to send the App (single issue) on 20.08 to Apple. If this is not possible, Adobe is responsible for the concequences, whatever they are.
                                                            Thats the end of my tests. It's now on Adobe!
                                                            • 27. Re: Scrollable content inside an MSO bug
                                                              Johannes Eckert Level 4
                                                              Sorry to hear that, Yves. It is really bad that this is introduced with the
                                                              newest tools, and there is no way to go back with cs6, yes, that separation
                                                              was introduced to et around all this.
                                                              Looks like what Neil was suggesting saving as v21 is not working either.
                                                              Somewhere above you mentioned to use a 2048px indesign document. I am
                                                              guessing that this might break the producer tools who are responsible for
                                                              downsizing and folio creation. Is the same happening if you scale down the
                                                              document yourself?
                                                              If course, this might not an option as well because you cannot scale down
                                                              an indesign document the simple way.
                                                              —Johannes
                                                              • 28. Re: Scrollable content inside an MSO bug
        @Yves – what can I say, your files are working in CS5.5. For my configuration see post #6 in this thread.
        An E-Mail with the working folios (2048x1536px AND 1024x768px) is sent to you…
        Of course, I had a missing font error after opening the IDML from you (CS6) and did  not substitute with the original fonts, but that hardly could be the culprit…
        Uwe
        • 29. Re: Scrollable content inside an MSO bug
        @Johannes. Yes I was also trying to create a 1024x768 px file. The result is the same.
        No, this could not work as the Folio Builder Panel Update was mandatory. And with the new tools came the new problem in CS6.
        If course, this might not an option as well because you cannot scale down an indesign document the simple way.
        Oh, you have only to ask the Adobe Support. They are telling you to create an alternate layout with scalling option. Done in 5 min.
        You know, I know and the rest of the world probably knows that this is not as simple as it sounds. At least it was a good joke from the support.
        @Uwe: I was trying the InDesign file that you sent back. Here is the result:
        I have the impression that the newest version of the CS6 plugins have introduced an error in a common used file, when CS6 and CS5.5 are installed together.
        • 30. Re: Scrollable content inside an MSO bug
        toutoungi Level 1
        Hi all.
        after a few more tests... beter results but not fixed...
        I converted all text elements in buttons to outlines (vectors) and the result is that the Shifting is now -1px!
        I am using v20 at the moment (CS 6 and the last manditory DPS update)
        like i said beter but not FIXED!
        @ Uwe - the Buttons are inside the MSO's.
        I hope ADOBE gets a HOT FIX for this problem!!!
        This is going to put a lot of us in troubel! I have a major presentation on Wednessday and the realeas a few days after that!!!
        @ Niel (or anyone from Adobe) - When can we expect a FIX!
        talk to you all soon!
        mo
        • 31. Re: Scrollable content inside an MSO bug
        @Yves – I'm sure you tested my folios that came along with the IDML, and they are showing no shifting…
        That's very strange…
        So, I think we have to look for differences in:
        1. Installed 3rd party PlugIns or Extensions on your side; I have some installed, but obviously they do not affect DPS:
        In-Tools "Create Hex Swatch" and "ScriptBay" and a not activated version of Rorohiko's "FramedWeb" together with the free APID ToolAssistant.
        Oh, and btw. according to Adobe Extension Manager my Digital Publishing plugIn of CS5.5 is on version 7.2.9.
        2. Other system differences (I'm on a MacBook Pro with OSX 10.6.8), what is your OS exactly?
        3. I'm using the German version of CS5.5 7.5.3 build 333, you are working on a different language version…
        Hm, You think it's the installation of InDesign CS6 together with CS5.5. Currently I have CS6 8.0.0 Trial installed, but still not used that, so I did not installed the latest DPS tools for InDesign CS6…
        Could that really be the culprit?
        If that's true, I really should not use InDesign CS6 for DPS workflows until the bug is fixed…
        Uwe
        • 32. Re: Scrollable content inside an MSO bug
        Hi Uwe,
        1. I'm using 3rd party plugins, but not on all machines. The only extension that I have installed, that has something directly to do with DPS is SuperOverlays. But I was not using it for this project.
        K4 without DPS module is also installed (not all machines).
        2. OSX 10.7.4 on all machines (also before the update of the plugins)
        3. I'm using an English System. My working InDesign CS6 (8.0.0.370) is also English (International). One of my second CS6 test InDesigns is German. My test CS5.5 (7.5.3 build 333) installs were English.
        (My CS5.5 DPS plugin shows in Extension Manager 7.5.8.22 - I the folio Builder Panel: 12.3.1.20120730_m_695362 / 7.5.8.22)
        (My CS6 DPS plugin shows 12.3.1.20120730_m_695362 / 8.0.8.22)
        This brings me to the questions. If you have version 7.2.9, this is an older version of the plugin. Did you make the complete update of Folio Builder and Overlay Creator and how do you have acces to digitalpublishing.acrobat.com. Your Folio Builder Panel should show to make the update!
        • 33. Re: Scrollable content inside an MSO bug
        @Yves – Hm. For InDesign CS5.5 I had v20 of DPS installed (both Folio Builder and Overlay Creator), switched to other tasks not involving DPS, did not updated when DPS v21 came out and finally installed DPS v22 (Folio Builder only).
        In that period of time until now I did not uploaded any folio to my acrobat.com account or even made connection through folio builder to acrobat.com. I  never checked the "Angemeldet bleiben (Stay logged in ??)" button of the login procedure in Folio Builder…
        Currently my focus of work is not on DPS, but on re-designing a "paper-version" of a magazine and scripting a catalog production workflow. I did a bit scripting of creating MSO workflows regarding DPS, but that did not involve using acrobat.com. The last weeks I always tested with local folios and the iPad3 connected by USB.
        Uwe
        • 34. Re: Scrollable content inside an MSO bug
        @Yves – what's really crazy, that not more people see this bug with MSOs. At times it seems it's only toutoungi and you…
        And totoungi had a different amount of shifting pixels than you.
        Uwe
        • 35. Re: Scrollable content inside an MSO bug
        toutoungi Level 1
        Hi Guys.
        i spoke with support yesterday. they said they had a few other customers with the problems. They also said the only "work around" at the moment was to use CS5. The tests i did looked sucessfull when i converted all text in buttons to vectors the shift went from 6-7px down to 1px. But as soon as i applied these changes to the rest of the document, the problem came back...
        I am basicly sitting here with my team converting all our documents (over 200) back down to CS 5.5!!! and thats not all... a lot of interactivity seetings are not working anymore - need to check every single thing and with most they did not convert properly!
        We are very HAPPY right now!!!
        mo
        • 36. Re: Scrollable content inside an MSO bug
        @toutoungi – was it CS5 or CS5.5 they recommended?
        And how about the bug experience Yves had even in CS5.5 (as you can see in his little movie at #29)?
        Note: in converting a CS6 file to CS5.5 or CS5 by using IDML you do not get any DPS functionality with overlays.
        This is due to the different scripting labels.
        I digged deep in the IDML Yves sent me for testing.
        Labels ("Keystring","Valuestring") applied to a Scrolling Content frame in CS6 by Yves after opening the IDML in CS5.5:
        kAdobeDPSInteractivity_ScrollDirection    0
        kAdobeDPSInteractivity_WebViewOverlayContainer    false
        kAdobeDPSInteractivity_ShowScrollIndicators    true
        kAdobeDPSInteractivity_UseInitialDesignView    false
        I don't know, but I think Yves tried to reset all values in the Overlay Creator panel and used the "trash bin" icon before sending over the IDML.
        But that did NOT eliminated the key/value pairs but set their properties differently.
        C'mon Adobe, you could do better! Using the "trash bin" for overlay features should result in removing all relevant key/value pairs and not in setting some values in a different way…
        I then applied new values to the Scrollable Content frame in CS5.5 and got the following key/value pairs:
        //Comment by Uwe Laubender:
        //AFTER reapplying the overlay in CS5.5:
        //Keystring<tab>Valuestring
        Type    WebView
        ScrollableFrameScrollDirection    2
        SS_WebViewOverlayContainer=    true
        ScrollableFrameUseInitialDesignView    true
        ScrollableFrameShowScrollIndicators    false
        The last five key/value pairs define the overlay functionality in CS5.5, the first four are leftovers from CS6.
        So, if you will open the CS5.5 file  in CS6 the first four key/value pairs define the overlay. Since you can hardly spot them in CS5.5 or even delete them alltogether or cannot change them so easily in CS5.5 (not without scripting or exporting to IDMS and strip them out with a text editor) you got something like a "time bomb" here, exploding when you like to work on in CS6 in the future… You can see that effect in the movie by Yves in #29.
        That is the biggest drawback when "labels"  are used for triggering effects and there is no mechanism to really delete them altogether!
        IMPORTANT:
        We can conclude now, that you cannot retain DPS overlay functionality when you switch between CS6 and CS5.5, even if you have the "same" tools installed.
        So it's definitely a very big decision to use inDesign CS6 over CS5.5:
        you cannot go back without loosing functionality!
        Uwe
        • 37. Re: Scrollable content inside an MSO bug
        @toutoungi – Did customer support tell you, what exactly causes the issue?
        Before proceeding with installing anything new or updating or signing in, I'd like to know, if I possibly will be affected, too.
        Uwe
        • 38. Re: Scrollable content inside an MSO bug
        toutoungi Level 1
        Hi Uwe,
        im using CS 5.5 - version 7.5.3.
        Like i said i have to do all Overlay setting again.
        Grüße
        mo
        • 39. Re: Scrollable content inside an MSO bug
        toutoungi Level 1
        @ Uwe
        Support said they are working on it - HIGH Priority! No timeline - will inform me....
        1 2 Previous Next
