Hi- I'm very new to actionScript 3. My project starts out by plying one movie clip(startPage), then onClick, moviecip startPage disappears and a random movieclip(sc01-sc03) loads and plays. Once each random movieclip plays, I want to remove it from the stage and reload startPage. I have the random part figured out using an array, but I can't figure out how to remove the random sc movieClip once it is loaded. I tried using removeChild, but Flash isn't recognizing that I have added and of the sc movieclips as childen. Help!
My current code below:
package
import flash.display.MovieClip;
import flash.events.MouseEvent;
import flash.events.Event;
public class Main extends MovieClip
var startPage:StartPage;
var sc01:Sc01;
var sc02:Sc02;
var sc03:Sc03;
private var _scenario:Array;
public function Main()
startPage = new StartPage();
sc01 = new Sc01();
sc02 = new Sc02();
sc03 = new Sc03();
_scenario = new Array();
MC.addChild(startPage);
//Add Scenes to array
_scenario[0] = sc01;
_scenario[1] = sc02;
_scenario[2] = sc03;
//Add Event Listeners
startPage.boxButton.addEventListener(MouseEvent.CLICK,onBoxButtonClick);
startPage.addFrameScript(startPage.totalFrames - 1, stopPageFunc);
sc01.addEventListener(Event.ENTER_FRAME, everyFrame01);
sc02.addEventListener(Event.ENTER_FRAME, everyFrame02);
sc03.addEventListener(Event.ENTER_FRAME, everyFrame03);
//stop at end of startPage timeline
function stopPageFunc()
startPage.stop();
function onBoxButtonClick(event:MouseEvent):void
MC.removeChild(startPage);
MC.addChild(_scenario[Math.floor(Math.random()*_scenario.length)]);
function everyFrame01():void
if (sc01.currentFrame == 50)
MC.removeChild(sc01);
startPage.gotoAndPlay(1);
else
{sc01.play();
function everyFrame02():void
if (sc02.currentFrame == 50)
MC.removeChild(sc02);
else
{sc02.play();
function everyFrame03():void
if (sc03.currentFrame == 50)
MC.removeChild(sc03);
else
{sc03.play();
//go to startPage when scenario done
replace line 44 with:
MC.removeChild(MovieClip(e.currentTarget));
use:
package
_scenario[0] = new Sc01();
_scenario[1] = new Sc02();
_scenario[2] = new Sc03();
shuffle(_scenario);
startPage.boxButton.addEventListener(MouseEvent.CLICK, onBoxButtonClick);
this.addEventListener(Event.ENTER_FRAME, everyFrame;
startPage.stop();
if(startPage.stage){
if(_scenario.length>0){
MC.addChild(_scenario[0]);
function everyFrame():void
if(_scenario[0].currentFrame==_scenario[0].totalFrames){
MC.removeChild(_scenario[0]);
_scenario.shift();
if(_scenario.length==0){
// startPage.gotoAndPlay(1); ???
function shuffle(a:Array) {
var i:int;
var j:int;
var e:*;
var len:int = a.length;
for (i = len-1; i>=0; i--) {
j=Math.floor((i+1)*Math.random());
e = a;
a = a
; a
= e; }
Thank you!
I keep getting this error though:
ArgumentError: Error #2025: The supplied DisplayObject must be a child of the caller.
at flash.display::DisplayObjectContainer/removeChild()
at Function/<anonymous>()
I get this error when Flash tries to remove the random sc movieclip from the stage. I got this a bunch using my other code too. Any idea what is causing this? Is this because I have called up my sc movieclips with an array and Flash doesn't know where to find it?
Also, when my sc movieclips play on the stage, they don't play from the beginning. It's as if they were already playing before they were added to the stage. Do you know how to fix this?
Thanks so much for your help!
use:
package {
public class Main extends MovieClip {
public function Main() {
scenarioF();
function scenarioF():void{
shuffle(_scenario);
function stopPageFunc() {
startPage.stop();
function onBoxButtonClick(event:MouseEvent):void {
if (startPage.stage) {
if (_scenario.length>0) {
_scenario[0].addEventListener(Event.ENTER_FRAME,everyFrame);
function everyFrame(e:Event):void {
if (e.currentTarget.currentFrame==e.currentTarget.totalFrames) {
MC.removeChild(e.currentTarget);
e.currentTarget.removeEventListener(Event.ENTER_FRAME,everyFrame);
_scenario.shift();
if (_scenario.length==0) {
// repopulate _scenario? if yes, call scenarioF();
var i:int;
var j:int;
var e:*;
var len:int=a.length;
e=a;
a=a
; a
=e; }
I get an error 1118: Implicit coercion of a value with static typr Object to a possible unrelated type flash.DisplayObject on line 57: var j:int;
Any ideas?
there's no error on that line of code.
attach a screenshot of the error and a screenshot of your actions panel at the frame mentioned in the error message.
I get the error at line 44 and 57. Thanks for all your help!
Thanks- I'm not getting any errors any more and playing random scenes is working once the boxButton is clicked, but it's still not behaving how I would like. Once, each random scene is done playing, I want startPage to play again from the beginning, and start the whole process over again. Currently, once the randomly added sc finishes playing, the screen goes blank. ???
read the comments:
use:
package {
private var _scenario:Array=[];
scenarioF();
shuffle(_scenario);
startPage.stop();
_scenario.shift();
scenarioF();
var i:int;
var j:int;
var e:*;
e=a;
a=a
; a
=e; }
p.s. please mark helpful/correct responses.
That doesn't make a difference. I'm still not getting any errors and still not returning to startPage once random sc plays.
what's the trace function reveal:
package {
scenarioF();
shuffle(_scenario);
startPage.stop();
trace(_scenario.length,_scenario[0]);
_scenario.shift();
scenarioF();
trace("startPage added",startPage,startPage.stage)
var i:int;
var j:int;
var e:*;
e=a;
a=a
; a
=e; }
Nada. The output window shows up blank.
use:
package {
scenarioF();
function scenarioF():void {
shuffle(_scenario);
startPage.stop();
_scenario.shift();
scenarioF();
} else {
var i:int;
var j:int;
var e:*;
e=a;
a=a
a
