Show 4 replies
1. Re: Fade Image
hatstead Aug 14, 2012 4:54 PM (in response to Mayfield36)http://www.pixentral.com/show.php?picture=1hiSRZOJ6XPQtE2cqeIFsFCqXoqAWZ0
- Duplicate the background layer
- Place a blank layer between the background and the background copy layers, and fill it with white
- On the top layer (background copy) make an oval selection with the Elliptical marquee tool
- Go to Select>inverse
- Go to Select>feather 25-40px (experiment)
- Hit delete on keyboard
- Press CTRL+D
- Access the Type tool (T) and type your message
- Access the Effects palette, select Bevels>Emboss. Apply
- Access the Visibility options and select Hide. Apply
Optional - to place a simple border around the picture:
- Open a blank layer at the top of the stack and press CTRL+ALT+SHIFT+E
- Go to Select>all
- Go to Edit>stroke(outline)selection, place stroke:inside, width 4-6 px
2. Re: Fade Image
photodrawken Aug 14, 2012 7:47 PM (in response to Mayfield36)I don't have PSE7, but if it has a Text Panel effect, you can use it -- see this discussion:
http://forums.adobe.com/message/3895733#3895733
Ken
4. Re: Fade Image
MECS Oct 3, 2012 6:22 AM (in response to Mark Sand)Why not just use the white layer as the background?
