37 Replies Latest reply on Jul 5, 2016 6:00 AM by James Prout
    Mac Dreamweaver CS6 very slow to open files
    Rob Miller
      Hi
      My Mac Dreamweaver CS6 opens html files in about 1-2 minutes! It is very very slow. It all works when the file is open but it is the actual opening that is slow.
      I have turned off external files but no change.
      Any ideas??
      Mac Pro
      Processor  2 x 2.8 GHz Quad-Core Intel Xeon
      Memory  4 GB 800 MHz DDR2 FB-DIMM
      Graphics  ATI Radeon HD 2600 XT 256 MB
      Software  Mac OS X Lion 10.7.4 (11E53)
        • 1. Re: Mac Dreamweaver CS6 very slow to open files
          AllDayDev Adobe Employee
          Does this occur with all files?
          To test for sure, please create a new document using one of the preset layouts (e.g. 3 column fixed), save the file, quit/restart Dreamweaver, and then try opening that file.
          If it's not happening with the new file, can you share a link to a page you are having this issue with? Or at least the code from the page if it's not yet live?
          • 2. Re: Mac Dreamweaver CS6 very slow to open files
            Rob Miller Level 1
            Hi Carey
            Thanks for you answer.
            It seems that Dreamweaver struggles with anything it thinks is 'complicated'.
            It opened the above (your suggestion) pretty quickly. However, when I opened this index page (http://www.digitaldeluxe.net) it took approx 30 seconds.
            Also when I changed site from the Files page, changing from one site to another takes a long time too. Like 30-60 seconds if the site is reasonably big (I am a web developer with 10 year experience with Dreamweaver).
            It's fine in CS5.5 but terrible in CS6.
            Rob
            • 3. Re: Mac Dreamweaver CS6 very slow to open files
              mpsoden
              I am having the same issues concerning speed. Large take a long time to open or switching between sites. Also when I drag files to the remote server, it sometimes will delete the file or tell me I have a permissons issue. No issues in CS5. This has been a very diappointing upgrade.
              Processor  2 x 2.4 Intel Core I7
              Memory  16GB 1333 MHz DDR3
              Graphics  AMD Radeon HD 6770M 1024 MB
              • 4. Re: Mac Dreamweaver CS6 very slow to open files
                MuckyDog
                I too have been running into this problem. Would appreciate hearing of any fixes coming up. Also, don't know if it's related, but I've also had a number of spontaneous crashes of DW, always occur just after I've selected a command of some sort in DW.
                DW6 (build 5842)
                Mac OS X 10.7.4
                2.2 GHz Intel Core i7
                8 GB 1333 MHz DDR3
                • 5. Re: Mac Dreamweaver CS6 very slow to open files
                  OlsVer
                  I am having the same problem. The file seems to start to open and the file tab starts to form but then hangs for up to 10minutes. For the first 20 times this happened I would open the file in another program and copy and paste the code in to a new document but this was a little tedious. Now I have learnt you just have to wait and so I go away and make a coffee (or write this comment on the forum) and by the time I get back it is done.
                  The only pattern I can see is that they were files that predate CS6 and are .asp.
                  Is there going to be an update that fixes this?
                  Best wishes,
                  Oliver
                  • 6. Re: Mac Dreamweaver CS6 very slow to open files
                    c41 Level 1
                    wow, i thought my copy of DW6 was slow taking 5-6 seconds to open files.
                    and its taking minutes for you guys. wow.
                    Does anyone know of an html editor (other than Dreamweaver) that has autocomplete of user defined css class/id names when editing html? as in, css classnames from a linked or open css file...
                    have tried ST2 and Chocolat with no success
                    • 7. Re: Mac Dreamweaver CS6 very slow to open files
                      mpsoden Level 1
                      The speed is still a big issue. I installed the updater for 12.01 and all my issues except speed went away. Today I am having the same put issues as before. It says that it put the files. yet it actually deleted the file on the remote server. Very frustrating
                      • 8. Re: Mac Dreamweaver CS6 very slow to open files
                        mytaxsite.co.uk Adobe Community Professional & MVP
                        Have you tried Microsoft Expression Web 4?  If not then try their trial version and you will be amazed as to how smooth it is and a pleasure to work with.  Color schemes may be not to your liking but pretty good in other ways.
                        Unfortunately, it is only for the Windows system AFAIK.
                        • 9. Re: Mac Dreamweaver CS6 very slow to open files
                          Sideways Design Level 1
                          I'm running the 5842 build (ostensibly 12.01), and the first HTML file to open after launch is still ridiculously slow, around 2 minutes. That is just for HTML files, with no associated website. Subsequent HTML files open as quickly as expected.
                          Does it really take months to fix this stuff?
                          • 10. Re: Mac Dreamweaver CS6 very slow to open files
                            OlsVer Level 1
                            This is still a big problem for me. Will Adobe come back to us about this?
                            • 11. Re: Mac Dreamweaver CS6 very slow to open files
                              Fergumungus2
                              Did anyone ever resolve this issue?  I am having the same problem.  Switching between sites and opening files in CS6 takes forever!
                              • 12. Re: Mac Dreamweaver CS6 very slow to open files
                                OlsVer Level 1
                                It is just as bad as ever. I thought an update would come along any day but
                                it is now getting ridiculous.
                                I have stopped taking regular breaks but instead take my breaks when
                                Dreamweaver is having a long think. I have had much longer breaks as a
                                result.
                                I guess it is a delay caused by DW taking a look at the whole site before
                                loading a file but I wish It wouldn't. It has caused me quite a lot of
                                embarrassment at meetings already.
                                • 13. Re: Mac Dreamweaver CS6 very slow to open files
                                  LarryRamp
                                  I usually go on breaks too when I open Dreamweaver C6.... another annoying feature is no html tool bars and all the deprecated tags are removed intentionally.... it just so happens there are some sites we manage that do not want us to charge them to change the format of their sites.... almost all the html is missing. there are not even <h1> tags, or <p> tags...didnt know those were deprecated... if you plan on buying this version....keep your CS4 so you can edit older sites....very disappointed in Adobe. They rushed this to market to suck more cash out of your pocket.... incomplete program ...worst one they put out in years.
                                  • 14. Re: Mac Dreamweaver CS6 very slow to open files
                                    Nancy O. Adobe Community Professional & MVP
                                    I have quite the opposite experience.  I have several older sites I maintain in CS6 without any problems.  If <h1> and <p> tags suddenly go missing, I guarantee there's an underlying problem with your code that CS6 is trying to resolve but can't.
                                    Use the W3C code validator to discover what that might be.
                                    http://validator.w3.org/
                                    Nancy O.
                                    • 15. Re: Mac Dreamweaver CS6 very slow to open files
                                      LarryRamp Level 1
                                      The tags are not missing from the page they are missing from the Dreamweaver tool bars... and they are not available to select or add in the favorite/custom toolbar either.
                                      It is like a scaled down version of CS4 but with some new features...in CS4 there was a text tab that had html tags... the text tab is missing... no html tags... I am using a PC for this application. Maybe Mac works different????
                                      • 16. Re: Mac Dreamweaver CS6 very slow to open files
                                        Tags are still in the HTML properties panel, the same as before.  See screenshot.
                                        Nancy O.
                                        • 17. Re: Mac Dreamweaver CS6 very slow to open files
                                          LarryRamp Level 1
                                          Ok, Good spot for them but when you have the editor in full screen it is nice to use the toolbars on top... the text too bar is gone and you cant add the tags to the favorites tool bar either.see this video to see what I am talking about...
                                          http://screencast.com/t/eco0N9uN0ZN
                                          • 18. Re: Mac Dreamweaver CS6 very slow to open files
                                            ethayer777
                                            This app has a ton of issues. Takes 2-3 mins to open anything with a ton of code. I'm permanently switching to Coda.
                                            • 19. Re: Mac Dreamweaver CS6 very slow to open files
                                              chaos_avatar
                                              I've been strugling with this issue for  a long time.
                                              I've found that Dreamweaver takes  about 2 minutes to open  CSS files with @import url for  font face.
                                              for example:
                                              @import url(http://fonts.googleapis.com/css?family=Oswald:400,300);
                                              i've never had problem with  big files but if i place this line into my 20k css file,  it takes for ever to load.
                                              if i  remove it, it opens  fast  as usual.
                                              Please don't tell me  that it could be a  Google problem  thatis loading slow  because it's not.
                                              the font file isnt  big enough either.
                                              Of course i have deativated the "load things from external urls" setting.
                                              any ideas on how could this be  fixed withoput changing my work style ?
                                              • 20. Re: Mac Dreamweaver CS6 very slow to open files
                                                Here's the thing.  Links to external scripts on other servers often look for a user agent (browser identifier).  DW is not a browser so it can't send user agent info.  When it tries to connect with the external site and doesn't get an immediate reply, it hangs.
                                                A few options:
                                                1. Comment out the offending code until you're ready to publish the site.
                                                2. Disable CSS.  View > Style Rendering > untick Display Styles.
                                                3. Use a Design Time Style sheet without the @ import rules.
                                                The latter 2 will not effect Live View or Preview in browsers.
                                                Nancy O.
                                                • 21. Re: Mac Dreamweaver CS6 very slow to open files
                                                  chaos_avatar Level 1
                                                  Thank you very much  for your time and thoughts Nancy!
                                                  i would like you to help me  finding the option  you mention here:
                                                  i could not find it in my spanish  dreamweaver (i never meant to have a spanish  dreamweaver  but it happened), tried to  find an option  similar to "display Styles"
                                                  http://screencast.com/t/EPwy7uLXh
                                                  in my particular case i always work in code view, i always code CSS in code view. Never use / nevwe will use design view. I wish a  way to  get DW  to NEVER try to connect to the external source because i  will never want to  see the work on DW itself.
                                                  btw... The options  1 and 3  semms to me pretty uncoonfortable because they mean a lot of extra work.
                                                  • 22. Re: Mac Dreamweaver CS6 very slow to open files
                                                    See screenshot:
                                                    Nancy O.
                                                    • 23. Re: Mac Dreamweaver CS6 very slow to open files
                                                      Thank you very much for your time! Very  apreciated.
                                                      For the record,  option 2 does not work. Since the problem happens  when opening the  css file directly.
                                                      I work  with  hundreds of sites and i have to be  constantly and wildly opening and modifying many of them , many times a day.  so option  1 is completely out of the  posibilities  for me .
                                                      Perhaps these  solutions  could  help other  people that works with less sites and don't mind adding extra steps to their workflow.
                                                      i think  there must be a 4th option  to add:
                                                      4.- go and make a cofee while DW opens the file.
                                                      • 24. Re: Mac Dreamweaver CS6 very slow to open files
                                                        c41 Level 1
                                                        I was hoping the latest update to Dreamweaver CC would improve this but alas, no. This is still a problem.
                                                        To simply *open a single html file*, nothing else, (with 'Enable Related Files' turned OFF in prefs),
                                                        ... takes 10 seconds in Dreamweaver CS6 (v12.2)
                                                        ... takes 14 seconds in Dreamweaver CC (v13.1)
                                                        Computer is a 27" iMac 2.8GHz Intel Core i7, running OSX 10.8.4 with 12GB of Ram.
                                                        Adobe, I have zero interest in new features. Unless the new feature is making the app run faster.
                                                        • 25. Re: Mac Dreamweaver CS6 very slow to open files
                                                          c41 Level 1
                                                          And in an effort to help Adobe, if I remove links to local css files within my project from the html file I'm trying to open (no @import font-face links in the css), the I can get the html file to open within 1-2 seconds.
                                                          So to me - the "Enable Related Files" setting is not doing what I'd expect. When I open a file (with Enable Related Files set to OFF) it's still taking a look at linked files and checking stuff, which is slowing it down. I just want DW to open the file, and display it quickly. Perhaps lazy-load in whatever logic/checking you are doing to linked files after I open it.
                                                          • 26. Re: Mac Dreamweaver CS6 very slow to open files
                                                            Thiago Ghilardi
                                                            In case people haven't found the answer, I was having the same problem with files that had links to large css files.
                                                            I replaced <link rel="stylesheet" type="text/css" href="/testa2/css/compiled/theme.css">
                                                            for
                                                            <link rel="stylesheet" type="text/css" href="../testa2/css/compiled/theme.css">
                                                            for all external css files and the problem went away. Hope that helps.
                                                            The ".." probably helps DW find the files faster.
                                                            2 people found this helpful
                                                            • 27. Re: Mac Dreamweaver CS6 very slow to open files
                                                              Preran Adobe Employee
                                                              Hi Thiago,
                                                              Thank you for sharing your solution with us.
                                                              Preran
                                                              • 28. Re: Mac Dreamweaver CS6 very slow to open files
        Kees van Surksum Level 1
        Hi Thiago and all others,
        your "solution" is working on local files. But as soon as you sync the index file on a remote server, it doesn't load the related style sheets anymore. So, this can't be a proper solution.
        I experience the slow page loading only since recently. Right after the first time I put a site under construction on the business catalyst site. Before I had no problems. So I guess, there is a relation to this issue. Putting the remote site on my own hosting server again, didn't change anything BTW.
        I looked at the general settings in Dreamweaver (CS6/CC) and unchecked the related files option completely. That solved the problem on my system. Now pages are loaded for editing fast as ever before. But on the minus side I miss of course the related file option. I can live with that ... or check it, whenever I need it.
        • 30. Re: Mac Dreamweaver CS6 very slow to open files
        joejourneys
        I agree, CS6 is massively slower on my Macbook Pro - it struggles and often get Application not responding.
        • 31. Re: Mac Dreamweaver CS6 very slow to open files
        EdwardN5 Level 1
        Brilliant. thanks - I have been having this issue on CC 2014 and this fixed it. Also I found disconnecting the computer from the network worked too. Been driving me mad - taking over 15 minutes to open the first file on a complicated website, with lots of includes.
        1 person found this helpful
        • 32. Re: Mac Dreamweaver CS6 very slow to open files
        zolgreen
        My Dreamweaver speedup when i comment all google resourses in meta tags. Before that, index.php of my site (6 kb) open in 1:30 - 2 minutes. Now its open about 5 - 8 sec.
        • 33. Re: Mac Dreamweaver CS6 very slow to open files
        It helps DW performance to put GA tracking code into a separate physical file -- either a .js or a server-side include.
        Nancy O.
        • 34. Re: Mac Dreamweaver CS6 very slow to open files
        James Prout
        I have a similar issue, except that Dreamweaver always hangs up when I either save a file or try to switch between one of the many sites I maintain.  One particular site is giving me more issues than others.  But I have two other people in this department that do not have any issues with that same site at all.  I got on with support and they told me having all my files not directly on my desktop computer but rather on a remote server was the issue.  Hogwash!
        I need this fixed as it is slowing down the business!
        Jim
        • 35. Re: Mac Dreamweaver CS6 very slow to open files
        Jon Fritz II Adobe Community Professional & MVP
        It's an easy out for support to blame the user, it's just the way of CS in general. Though, over the years, DW has seemed to have intermittent issues with saving files to network drives. It does tend to like local files better and odd set-ups can cause more issues.
        What version of the program are you running?
        What OS?
        Have you conducted any of the standard troubleshooting steps (clearing program cache, restore prefs, reinstall using Cleaner Tool, etc)?
        • 36. Re: Mac Dreamweaver CS6 very slow to open files
        Hi Jon,
        We have seen many cases where performance issues with Dreamweaver were related to working from remote servers. There are many reasons as to why this can happen, and we are checking with the product team to see if there is anything in Dreamweaver needs to be fixed to improve this experience.
        Preran
        • 37. Re: Mac Dreamweaver CS6 very slow to open files
        James Prout Level 1
        I am currently on Mac OS El Capitan 10.11.5 (15F34) and am using Dreamweaver CC 2015.  I've tried all the standard troubleshooting tips in the hopes it would make loading and saving files quicker but it has had no affect so far.  I've had to work this condition into my daily routines and at times is frustrating.  We are a department with several designers and having each designer saving and uploading files directly to their local machine is not a viable solution.
        I thought the new upgrade would solve this dilemma but it has not.
        Jim
