I want to make a back button, but I'm not really sure how to do this. I did some research and some people said you need an array. I've never made an array before. Everyone of my frames have a label and multiple ways to get to that frame. Can anyone help me with this? Any help would be appreciated, thank you.
yes, you must add to each button, the array is a stack and added in the order they arrive, to "back" you will always take the last.
The pop method, gets the last value and delete it
gotoAndStop(myBackList.pop())
The array will be a list of your steps
define the array:
var myBackList:Array=new Array();
now every time it you change to another frame, add to the list (array) the label name of the frame
i.e.
myButtonGoToFirstSection.addEventListener(MouseEvent.CLICK, gotoFirstSection)
function gotoFirstSection(e:MouseEvent):void{
gotoAndStop("FirstSeccion")
myBackList.push("FirstSeccion") //this add the the label to the array
then the code to the back button is:
myBackButton.addEventListener(MouseEvent.CLICK, goBack)
function goBack(e:MouseEvent):void{
So I have to add this myBackList.push("FirstSeccion") to everyone of my buttons. How does it know the order of the frames in the array? And does it remove them from the array when call upon or overwritten with "myBackButton"?
Ok I have a problem with the back button.
Example frame 1, frame 2, frame 3, frame 4, frame 5
I start at frame 1 and go to 2, 3, 4, and then 5. It will only let me go back to frame 2. So if I start going forward again from frame 2 and go to 3, 4, and then 5. I can only go back to frame 3.
I think the problem is it removes the frames before entering the current frame. How do I fix this?
Thanks in advance - John
You are not using the same code above, can you show your code?
stop();
bioBut.addEventListener(MouseEvent.CLICK, gotoBiographies);
overviewBut.addEventListener(MouseEvent.CLICK, gotoOverview);
commemorationBut.addEventListener(MouseEvent.CLICK, gotoCommemoration);
GettingStartedButt.addEventListener(MouseEvent.CLICK, gotoAboutTheLesson);
myBackButton.addEventListener(MouseEvent.CLICK, goBack);
function gotoBiographies(event:MouseEvent):void
gotoAndStop("bios");
myBackList.push("bios");
function gotoOverview(event:MouseEvent):void
gotoAndStop("overview");
myBackList.push("overview");
function gotoCommemoration(event:MouseEvent):void
gotoAndStop("commemorationFrame");
myBackList.push("commemorationFrame");
function gotoAboutTheLesson(event:MouseEvent):void
gotoAndStop("aboutTheLesson");
myBackList.push("aboutTheLesson");
gotoAndStop(myBackList.pop());
stop();
function gotoBiographies(event:MouseEvent):void {
trace(myBackList)
function gotoOverview(event:MouseEvent):void {
trace(myBackList)
function gotoCommemoration(event:MouseEvent):void {
trace(myBackList)
function gotoAboutTheLesson(event:MouseEvent):void {
trace(myBackList)
function goBack(e:MouseEvent):void {
trace(myBackList);
var frameGo:String=myBackList.pop();
(currentLabel==frameGo)?gotoAndStop(myBackList.pop()):gotoAndStop(frameGo);
trace(myBackList);
trace("---------");
Thanks for your help, kglad came up with a slightly different solution with booleans. Again thank you for your help. Heres what he came up with:
stop();
var backFrame:*;
var forwardFrame:* = 1;
var addForwardBool:Boolean = false;
var addBackBool:Boolean = false;
myBackList.push(1);
addForwardBool=true;
addFrameF();
forwardFrame="bios";
addFrameF();
forwardFrame="overview";
addFrameF();
forwardFrame="commemorationFrame";
addFrameF();
forwardFrame="aboutTheLesson";
backFrame=myBackList.pop();
if(backFrame)
addBackBool=true;
gotoAndStop(backFrame);
function addFrameF():void
if (forwardFrame && addForwardBool)
myBackList.push(forwardFrame);
if (backFrame && addBackBool)
myBackList.push(backFrame);
addBackBool=false;
addForwardBool=false;
