RH9 | WebHelp
Is it possible to show the TOC in the topic pane? You can use a design-time control to do this in HTML Help, but it doesn't work in WebHelp.
Jonathan
There is no similar option for WebHelp.
The scripts for the TOC are specifically made for the tri-pane format. I doubt that an iframe pointing to whtdhtml.htm will work, but you can always try.
Greet,
Willam
You could create a topic and drag the topics from the TOC to the topic, adding headings for book titles.
