1 2 3 Previous Next 104 Replies Latest reply on Oct 25, 2015 7:34 PM by grahamw22862525 Go to original post
      • 40. Re: Adobe Bridge CS6 will not open
        Ashtree25
        Thanks Curt - I take it you mean I should definitely not uninstall CS2?
        • 41. Re: Adobe Bridge CS6 will not open
          Level 5
          How much more clearly do you want Curt to state it?  That is exactly what he wrote in the very first sentence of his post #39.
          • 42. Re: Adobe Bridge CS6 will not open
            Curt Y Level 6
            Confusion, yes too many potential problems on uninstalling an older version.  So keep CS2.
            • 43. Re: Adobe Bridge CS6 will not open
              Ashtree25 Level 1
              Station_two, Curt's first sentence was "I would definately NOT install CS2. "  which is why I asked him to clarify that he mean uninstall, not install .  I realised it was probably a typo, but just wanted to be sure .  (with apologies if you were just having a joke here - sorry, lack of body language and all that, haha!)
              • 44. Re: Adobe Bridge CS6 will not open
                Level 5
                Ouch, my bad!  I misread that.  You are 100% correct, sorry.
                • 45. Re: Adobe Bridge CS6 will not open
                  ChunXiaYang Level 2
                  Please check your system TEMP folder path. And please set it back to %USERPROFILE%\AppData\Local\Temp if it is not this, and try to launch Bridge again.
                  How to chec and change the TEMP folder:
                  1.  open Control Panel\System and Security\System
                  2. Click Advanced System Settings
                  3. Click Enviroment Variables
                  4. You will see the Temp and TMP folder settings
                  Bridge Quality Engineer
                  Chun Xia
                  • 46. Re: Adobe Bridge CS6 will not open
                    Ashtree25 Level 1
                    Thanks Chun Xia for your suggestion.  I've just checked the TEMP and TMP folder paths and they are already exactly as you've noted,  so unfortunately this isn't the solution
                    Ashtree25
                    • 47. Re: Adobe Bridge CS6 will not open
                      ChunXiaYang Level 2
                      Do you have time now? Can we setup a connection and let me check your computer?
                      • 48. Re: Adobe Bridge CS6 will not open
                        ChunXiaYang Level 2
                        Please refer to http://feedback.photoshop.com/photoshop_family/topics/bridge_cs6_wont_open_running_on_win7.
                        Can you try to create a new account user (with adm rights) and install PS/Bridge again? Please let me know the result.
                        Thanks for the time!
                        • 49. Re: Adobe Bridge CS6 will not open
                          ChunXiaYang Level 2
                          Besides create a new account, you can also try:
                          1. Find the folder C:\Users\[your user name]\AppData\Roaming\Adobe\Bridge CS6
                          2. If you have import settings in Bridge, please back up this folder. Then delete all the stuff in this folder.
                          3. Launch Bridge again.
                          • 50. Re: Adobe Bridge CS6 will not open
                            Ashtree25 Level 1
                            Hi Chun Xia
                            Sorry for delay - been away from the computer.  So, update:  I set up a new User Account with admin rights and hey presto, I have Bridge working! Thank you so much!
                            I'm still trying to work out, though, what impact this has on all my stuff - do I have to port everything across to this new user?  Or can I just leave everything as it is?
                            Once again, thanks for your help - I'm just so grateful to have found a solution to this!
                            Ashtree25
                            • 51. Re: Adobe Bridge CS6 will not open
                              ChunXiaYang Level 2
                              If deleting C:\Users\[your user name]\AppData\Roaming\Adobe\Bridge CS6 cannot resolve this issue, but only creating new account can, I am afraid that you need to port your settings to the new user. Because we did not find what cause this issue exactly. Sorry for this.
                              Anyway, I'm gald you can use Bridge now. Thanks for supporting Adobe products and Bridge!
                              • 52. Re: Adobe Bridge CS6 will not open
                                mjw5997
                                I've had this same exact problem.  I also tried all the suggestions, including checking settings, deleting C:\Users\[your user name]\AppData\Roaming\Adobe\Bridge CS6 (including the directory itself).  No luck.   Adding a new user, then using it to start Bridge worked great, but that is not really a solution.  One added piece of info:  Bridge did recreate the above directory before dying, although it remains empty.  I haven't found any logfiles that might help understand how far it got.   Is there a log file or a registry setting that will enable detailed logging to help diagnose this?
                                There is obviously something in my normal user's profile or environment that is getting in the way of startup.  You (Adobe) have the code and the startup can't be that convoluted.  Someone should be able to walk the code, figure out what things are checked between creating the above directory and the next externally detectable step (like creating a file in this directory or logging something into a log file), then reply here with a list of specific things to check.
                                I got into a chat with Adobe support several days ago, where I went through several steps of ensuring I was using a properly licensed version only to be told that he didn't know Bridge and asked that I call during the day on Monday.  The sign off message to that chat was funny - they mentioned 24x365 support :-)  Luckily, I've worked support in my past and I have a sense of humor.
                                • 53. Re: Adobe Bridge CS6 will not open
                                  canadianego
                                  If anyone knew what to be looking for it sounds like you'd be the one. After giving up on Bridge and all of the current 'solutions', I've still had an interest in what went wrong, but not enough to deal with people telling me to come back when somebody competant decides to come around. I'm thinking this problem has been popular enough to become almost a priority now, so best of luck! (:
                                  • 54. Re: Adobe Bridge CS6 will not open
                                    mjw5997 Level 1
                                    Actually, I'd love to work for Adobe for a few days to dig in and fix this issue ;-)  I'm a software engineer turned product manager in my day job for a company down the road from Adobe (in a non-competing industry) and greatly admire most of what Adobe has produced.  Actually, I guess I'd love to work for Adobe in general - it would be nice to work on my toys as a day job :-)
                                    These little problems can be extremely tricky to solve until you get enough information to recreate.  I can recreate it at will but don't have the tools to dig in.  I'm sure Adobe would love to solve this, but they obviously haven't recreated it themselves.  All they can do is try to make good suggestions or provide tools or debug procedures that we can use to provide them better info.
                                    • 55. Re: Adobe Bridge CS6 will not open
                                      Ashtree25 Level 1
                                      Adobe, are you listening to mjw5997?  He wants to work for you and fix this problem.  From all I've seen and read, it sounds like an embarrassing percentage of your customers (who've spent, in many cases, an obscene amount of money for this software) are simply not getting the goods they paid for.
                                      I reckon, if you value your reputation, you'd be pretty dumb not to take on someone who is prepared to dig you out of this pit - you don't seem to have anyone else working for you who knows how to do it, so what have you got to lose?
                                      • 56. Re: Adobe Bridge CS6 will not open
                                        mjw5997 Level 1
                                        I'd bet it's actually a very tiny percentage of customers - many thousands of happy quiet customers, and a few having troubles and posting here.
                                        • 57. Re: Adobe Bridge CS6 will not open
                                          Curt Y Level 6
                                          I tend to agree.  Not an Adobe employee, or even a computer whiz, but dealing with thousands of complaints I have seen a pattern.
                                          There are those problems that are true bugs and affect everyone.  Adobe can easily reproduce the problem in the lab and eventually write a fix.
                                          Then there are the bugs that affect a small percentage of users, like this issue, that are not easy to reproduce in the lab.  For whatever reason it is some combination of OS, hardware, software, permission levels, installation (programs work best on C drive), and user errors that results in the program not working on that particular computer.   Because there are slight variations in all computer configurations a fix for one may not result in a fix for another.  One also has the added complexity of the user practices, such as did the user just delete a program so there are bits and pieces left over to complicate things, have they moved pieces of the program to other locations "to make it look more organized", was there a glitch in the install process or uninstall of old programs, are the OS, drivers, software up to date?
                                          In complex cases that affect a small number of users, from my experience, the best bet for success is to have the users with the problems start comparing notes.  Anti-virus programs are always first on the list of potential problems, then come programs that "handle" certain issues, remapping keys, storing fonts, and so forth.
                                          I don't mean to pass the buck, or give excuses for Adobe, but waiting for Adobe "to just fix it" will never happen if the issue can not be reproduced in the lab.  And to get it reproduced will require a lot of work from the users.  There are some really smart users out there and it may be someone like mjw5997 that identifies the problem.
                                          I post user fixes all the time as Adobe has not rewritten the code to address the problem of these particular issues.
                                          • 58. Re: Adobe Bridge CS6 will not open
                                            mjw5997 Level 1
                                            I have no idea if the following is helpful (I suspect only Adobe can use this):
                                            In Uses/[me]/AppData/Local/Temp, the following file is generated by Bridge momentarily during startup, then it is deleted when it fails to start.  I quickly grabbed and edited it so I could post the contents here:
                                            The file is: WERF095.tmp.WERInternalMetadata.xml
                                            The contents:
                                            <?xml version="1.0" encoding="UTF-16"?>
                                            <WERReportMetadata>
                                                <OSVersionInformation>
                                                    <WindowsNTVersion>6.1</WindowsNTVersion>
                                                    <Build>7601 Service Pack 1</Build>
                                                    <Product>(0x1): Windows 7 Ultimate</Product>
                                                    <Edition>Ultimate</Edition>
                                                    <BuildString>7601.17835.amd64fre.win7sp1_gdr.120503-2030</BuildString>
                                                    <Revision>1130</Revision>
                                                    <Flavor>Multiprocessor Free</Flavor>
                                                    <Architecture>X64</Architecture>
                                                    <LCID>1033</LCID>
                                                </OSVersionInformation>
                                                <ParentProcessInformation>
                                                    <ParentProcessId>2672</ParentProcessId>
                                                    <ParentProcessPath>C:\Windows\explorer.exe</ParentProcessPath>
                                                    <ParentProcessCmdLine>C:\Windows\Explorer.EXE</ParentProcessCmdLine>
                                                </ParentProcessInformation>
                                                <ProblemSignatures>
                                                    <EventType>APPCRASH</EventType>
                                                    <Parameter0>Bridge.exe</Parameter0>
                                                    <Parameter1>5.0.0.399</Parameter1>
                                                    <Parameter2>4f5ec28e</Parameter2>
                                                    <Parameter3>Bridge.exe</Parameter3>
                                                    <Parameter4>5.0.0.399</Parameter4>
                                                    <Parameter5>4f5ec28e</Parameter5>
                                                    <Parameter6>c0000005</Parameter6>
                                                    <Parameter7>000000000036ae49</Parameter7>
                                                </ProblemSignatures>
                                                <DynamicSignatures>
                                                    <Parameter1>6.1.7601.2.1.0.256.1</Parameter1>
                                                    <Parameter2>1033</Parameter2>
                                                    <Parameter22>dca5</Parameter22>
                                                    <Parameter23>dca5eef3eb4639786ac397e2f866e6e1</Parameter23>
                                                    <Parameter24>cde9</Parameter24>
                                                    <Parameter25>cde994f1594c84823c9c1be215d1d32c</Parameter25>
                                                </DynamicSignatures>
                                                <SystemInformation>
                                                    <MID>C1C89176-2E22-457C-8B68-F9633BDBDBAB</MID>
                                                    <SystemManufacturer>System manufacturer</SystemManufacturer>
                                                    <SystemProductName>System Product Name</SystemProductName>
                                                    <BIOSVersion>0303</BIOSVersion>
                                                </SystemInformation>
                                            </WERReportMetadata>
                                            Nothing shows up in amt3.log, of course.
                                            If anyone else wants to do this, sort the directory by Date Modified and be ready to right click->edit before it disappears.
                                            I tried to do the same with the working userid, but the file neveer showed up (went by this step too fast for dir to show file, I imagine).
                                            • 59. Re: Adobe Bridge CS6 will not open
                                              ChunXiaYang Level 2
                                              Hi mjw5997 and all,
                                              Thanks all for the information!
                                              Can you tell me your email address? I want to tell you how to enable dmp file generation. If your system can already generate dmp files, please check your dmp file folder and see whether there is any dmp file generated after the launch failure.
                                              Best Regards,
                                              Chun Xia
                                              • 60. Re: Adobe Bridge CS6 will not open
                                                mjw5997 Level 1
                                                Hi Chun Xia,
                                                my email is mike2@koda.net.
                                                Mile
                                                • 61. Re: Adobe Bridge CS6 will not open
                                                  mjw5997 Level 1
                                                  I couldn't connect to your ftp server for some reason, so I attached to my email reply to you.  The dmp is only about 1.5 MB.
                                                  Let me know if you need more.
                                                  Mike
                                                  • 62. Re: Adobe Bridge CS6 will not open
                                                    ChunXiaYang Level 2
                                                    Thanks mjw5997 for sending me the dmp file! We have checked it and found that this is a Brige code bug.
                                                    This launch issue happens when installing Bridge CS6 on a machine with Bridge CS2 installed.
                                                    We can fix it, but I am not sure when the fix can be released. Currently, we have a workaround: create an empty folder in C:\Users\[your user name]\AppData\Roaming\Adobe\.
                                                    Best Regards,
                                                    Chun Xia
                                                    • 63. Re: Adobe Bridge CS6 will not open
                                                      mjw5997 Level 1
                                                      Hi Chun Xia,
                                                      No luck.
                                                      I renamed my exising c:\users\[me]\AppData\Roaming\Adobe to Adobe2 to get it out of the way, then created a new empty Adobe directory. When I started Bridge, it created a Bridge CS6 directory and stopped as always. The Bridge CS6 directory is empty.
                                                      Mike
                                                      • 64. Re: Adobe Bridge CS6 will not open
                                                        ChunXiaYang Level 2
                                                        Sorry, my bad. I miss-typed and missed the most important thing.
                                                        The workaround is: create an empty folder named 'Bridge CS2' in folder C:\Users\[your user name]\AppData\Roaming\Adobe\.
                                                        Best Regards,
                                                        Chun Xia
                                                        1 person found this helpful
                                                        • 65. Re: Adobe Bridge CS6 will not open
                                                          mjw5997 Level 1
                                                          That did it. Thanks so much for your help. I'll reply on the forum how you've helped.
                                                          Mike
                                                          • 66. Re: Adobe Bridge CS6 will not open
                                                            gletter19
                                                            Thanks for the work around.
                                                            • 67. Re: Adobe Bridge CS6 will not open
                                                              alty33000
                                                              Hi Chun Xia Yang
                                                              I am having the same problem with Bridge that does not open...with my recent purchase of PS CS6 Extended student version.....whenever I try to open Bridge it does nothing but generating the following report to Apple....This is a new Mac OS X laptop so no previous CS of any kind.....Please let me know how to go about it....As I would like to have the full benefit of this software....Thank you in advanced.
                                                              Here is the report I am getting:
                                                              Process:         Adobe Bridge CS6 [897]
                                                              Path:            /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/Adobe Bridge CS6
                                                              Identifier:      com.adobe.bridge5
                                                              Version:         5.0.0.399 (5.0.0.399)
                                                              Code Type:       X86-64 (Native)
                                                              Parent Process:  launchd [134]
                                                              User ID:         501
                                                              Date/Time:       2012-12-06 00:30:20.359 -0500
                                                              OS Version:      Mac OS X 10.8.2 (12C60)
                                                              Report Version:  10
                                                              Interval Since Last Report:          285162 sec
                                                              Crashes Since Last Report:           6
                                                              Per-App Interval Since Last Report:  21 sec
                                                              Per-App Crashes Since Last Report:   6
                                                              Anonymous UUID:                      6E65B022-DF6C-F2D1-DCA5-D2FF2A685D1C
                                                              Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                                                              Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
                                                              Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000028
                                                              VM Regions Near 0x28:
        __TEXT                 0000000100000000-0000000100fe0000 [ 15.9M] r-x/rwx SM=COW  /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/Adobe Bridge CS6
                                                              Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                                                              0   com.adobe.bridge5                       0x00000001004d2a66 start + 4907842
                                                              1   com.adobe.bridge5                       0x0000000100719870 boost::exception_detail::error_info_injector<boost::thread_resource_error>::~error_info_i njector() + 791392
                                                              2   com.adobe.bridge5                       0x0000000100332bd9 start + 3204277
                                                              3   com.adobe.bridge5                       0x000000010032ddc0 start + 3184284
                                                              4   com.adobe.bridge5                       0x000000010049bb8a start + 4682854
                                                              5   com.adobe.bridge5                       0x0000000100495f43 start + 4659231
                                                              6   com.adobe.bridge5                       0x00000001004970e0 start + 4663740
                                                              7   com.adobe.bridge5                       0x0000000100498200 start + 4668124
                                                              8   com.adobe.bridge5                       0x000000010049d7ed start + 4690121
                                                              9   com.adobe.bridge5                       0x000000010049da2f start + 4690699
                                                              10  com.adobe.bridge5                       0x000000010049dbe3 start + 4691135
                                                              11  com.adobe.bridge5                       0x000000010049dc9c start + 4691320
                                                              12  com.adobe.bridge5                       0x00000001004a23eb start + 4709575
                                                              13  com.adobe.bridge5                       0x0000000100336244 start + 3218208
                                                              14  com.adobe.bridge5                       0x0000000100465d3f start + 4462107
                                                              15  com.adobe.bridge5                       0x00000001004618df start + 4444603
                                                              16  com.adobe.bridge5                       0x00000001001bd84f start + 1675563
                                                              17  com.adobe.bridge5                       0x00000001001be2db start + 1678263
                                                              18  com.adobe.bridge5                       0x00000001001b2bcc start + 1631400
                                                              19  com.adobe.bridge5                       0x000000010012cf89 start + 1083493
                                                              20  com.adobe.bridge5                       0x00000001003f7290 start + 4008812
                                                              21  com.adobe.bridge5                       0x000000010003b910 start + 94700
                                                              22  com.adobe.bridge5                       0x00000001000451f2 start + 133838
                                                              23  com.adobe.bridge5                       0x0000000100046405 start + 138465
                                                              24  com.adobe.bridge5                       0x0000000100035615 start + 69361
                                                              25  com.adobe.bridge5                       0x00000001003f71cc start + 4008616
                                                              26  com.adobe.bridge5                       0x00000001004c5443 start + 4853023
                                                              27  com.adobe.bridge5                       0x00000001004c5168 start + 4852292
                                                              28  com.adobe.bridge5                       0x0000000100024758 start + 52
                                                              Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                                                              0   libsystem_kernel.dylib                  0x00007fff88cc7d16 kevent + 10
                                                              1   libdispatch.dylib                       0x00007fff8c4d1dea _dispatch_mgr_invoke + 883
                                                              2   libdispatch.dylib                       0x00007fff8c4d19ee _dispatch_mgr_thread + 54
                                                              Thread 2:
                                                              0   libsystem_kernel.dylib                  0x00007fff88cc76d6 __workq_kernreturn + 10
                                                              1   libsystem_c.dylib                       0x00007fff88b17eec _pthread_workq_return + 25
                                                              2   libsystem_c.dylib                       0x00007fff88b17cb3 _pthread_wqthread + 412
                                                              3   libsystem_c.dylib                       0x00007fff88b02171 start_wqthread + 13
                                                              Thread 3:
                                                              Thread 4:
                                                              Thread 5:
                                                              0   libsystem_kernel.dylib                  0x00007fff88cc7386 __semwait_signal + 10
                                                              1   libsystem_c.dylib                       0x00007fff88b9f800 nanosleep + 163
                                                              2   com.adobe.bridge5                       0x0000000100643edb std::_Rb_tree<SPSUAS, std::pair<SPSUAS const, int>, std::_Select1st<std::pair<SPSUAS const, int> >, std::less<SPSUAS>, std::allocator<std::pair<SPSUAS const, int> > >::_M_insert_unique(std::pair<SPSUAS const, int> const&) + 197051
                                                              3   com.adobe.bridge5                       0x0000000100628809 std::_Rb_tree<SPSUAS, std::pair<SPSUAS const, int>, std::_Select1st<std::pair<SPSUAS const, int> >, std::less<SPSUAS>, std::allocator<std::pair<SPSUAS const, int> > >::_M_insert_unique(std::pair<SPSUAS const, int> const&) + 84713
                                                              4   com.adobe.bridge5                       0x0000000100644226 std::_Rb_tree<SPSUAS, std::pair<SPSUAS const, int>, std::_Select1st<std::pair<SPSUAS const, int> >, std::less<SPSUAS>, std::allocator<std::pair<SPSUAS const, int> > >::_M_insert_unique(std::pair<SPSUAS const, int> const&) + 197894
                                                              5   libsystem_c.dylib                       0x00007fff88b15742 _pthread_start + 327
                                                              6   libsystem_c.dylib                       0x00007fff88b02181 thread_start + 13
                                                              Thread 6:
                                                              0   libsystem_kernel.dylib                  0x00007fff88cc70fa __psynch_cvwait + 10
                                                              1   libsystem_c.dylib                       0x00007fff88b19f89 _pthread_cond_wait + 869
                                                              2   com.apple.CoreServices.CarbonCore          0x00007fff88d7e214 TSWaitOnCondition + 108
                                                              3   com.apple.CoreServices.CarbonCore          0x00007fff88d7e3eb TSWaitOnConditionTimedRelative + 132
                                                              4   com.apple.CoreServices.CarbonCore          0x00007fff88ce0b24 MPWaitOnQueue + 252
                                                              5   com.adobe.ACE                           0x00000001046df2c9 0x1046a6000 + 234185
                                                              6   com.adobe.ACE                           0x00000001046de5da 0x1046a6000 + 230874
                                                              7   com.apple.CoreServices.CarbonCore          0x00007fff88d557e4 PrivateMPEntryPoint + 58
                                                              8   libsystem_c.dylib                       0x00007fff88b15742 _pthread_start + 327
                                                              9   libsystem_c.dylib                       0x00007fff88b02181 thread_start + 13
                                                              Thread 7:
                                                              Thread 8:
                                                              Thread 9:
                                                              Thread 10:
                                                              Thread 11:
                                                              Thread 12:
                                                              Thread 13:
                                                              5   com.adobe.CameraRaw                     0x000000010bb863d9 0x10b93b000 + 2405337
                                                              6   com.adobe.CameraRaw                     0x000000010bb85630 0x10b93b000 + 2401840
                                                              Thread 14:
                                                              Thread 15:
                                                              Thread 16:
                                                              Thread 17:
                                                              Thread 18:
                                                              Thread 19:
                                                              Thread 20:: cr_scratch
                                                              2   com.adobe.CameraRaw                     0x000000010b99db43 0x10b93b000 + 404291
                                                              3   com.adobe.CameraRaw                     0x000000010bd0cd94 EntryFM + 962180
                                                              4   com.adobe.CameraRaw                     0x000000010ba61338 0x10b93b000 + 1205048
                                                              Thread 21:
                                                              2   com.adobe.bridge5                       0x000000010066c4fe boost::exception_detail::error_info_injector<boost::thread_resource_error>::~error_info_i njector() + 81902
                                                              3   com.adobe.bridge5                       0x000000010066e4df boost::exception_detail::error_info_injector<boost::thread_resource_error>::~error_info_i njector() + 90063
                                                              4   com.adobe.bridge5                       0x000000010066ceeb boost::exception_detail::error_info_injector<boost::thread_resource_error>::~error_info_i njector() + 84443
                                                              5   com.adobe.bridge5                       0x00000001004d29b9 start + 4907669
                                                              6   com.apple.CoreServices.CarbonCore          0x00007fff88d557e4 PrivateMPEntryPoint + 58
                                                              7   libsystem_c.dylib                       0x00007fff88b15742 _pthread_start + 327
                                                              8   libsystem_c.dylib                       0x00007fff88b02181 thread_start + 13
                                                              Thread 22:
                                                              0   libsystem_kernel.dylib                  0x00007fff88cc7ffa read + 10
                                                              1   com.adobe.bridge5                       0x0000000100547544 sqlite3_strnicmp + 3060
                                                              2   com.adobe.bridge5                       0x000000010056d13e sqlite3_os_init + 10830
                                                              3   com.adobe.bridge5                       0x000000010056fcf3 sqlite3_os_init + 22019
                                                              4   com.adobe.bridge5                       0x00000001005bc221 sqlite3_backup_finish + 242049
                                                              5   com.adobe.bridge5                       0x0000000100566182 sqlite3_step + 2882
                                                              6   com.adobe.bridge5                       0x0000000100746575 boost::exception_detail::error_info_injector<boost::thread_resource_error>::~error_info_i njector() + 974949
                                                              7   com.adobe.bridge5                       0x00000001006b7a4b boost::exception_detail::error_info_injector<boost::thread_resource_error>::~error_info_i njector() + 390459
                                                              8   com.adobe.bridge5                       0x000000010076f175 boost::exception_detail::error_info_injector<boost::thread_resource_error>::~error_info_i njector() + 1141861
                                                              9   com.adobe.bridge5                       0x000000010066cf14 boost::exception_detail::error_info_injector<boost::thread_resource_error>::~error_info_i njector() + 84484
                                                              10  com.adobe.bridge5                       0x00000001004d29b9 start + 4907669
                                                              11  com.apple.CoreServices.CarbonCore          0x00007fff88d557e4 PrivateMPEntryPoint + 58
                                                              12  libsystem_c.dylib                       0x00007fff88b15742 _pthread_start + 327
                                                              13  libsystem_c.dylib                       0x00007fff88b02181 thread_start + 13
                                                              Thread 23:
                                                              2   com.adobe.bridge5                       0x000000010066c4b8 boost::exception_detail::error_info_injector<boost::thread_resource_error>::~error_info_i njector() + 81832
                                                              3   com.adobe.bridge5                       0x00000001006a6bfe boost::exception_detail::error_info_injector<boost::thread_resource_error>::~error_info_i njector() + 321262
                                                              4   com.adobe.bridge5                       0x00000001004d29b9 start + 4907669
                                                              5   com.apple.CoreServices.CarbonCore          0x00007fff88d557e4 PrivateMPEntryPoint + 58
                                                              6   libsystem_c.dylib                       0x00007fff88b15742 _pthread_start + 327
                                                              7   libsystem_c.dylib                       0x00007fff88b02181 thread_start + 13
                                                              Thread 0 crashed with X86 Thread State (64-bit):
        rax: 0x000000010e031710  rbx: 0x00007fff5fbfdff0  rcx: 0x000000010e031710  rdx: 0x0000000000080000
        rdi: 0x0000000000000020  rsi: 0x00007fff5fbfdff0  rbp: 0x00007fff5fbfdf20  rsp: 0x00007fff5fbfdf20
        r8: 0x0000000000000001   r9: 0x0000000000000013  r10: 0x000000010e031710  r11: 0x0000000000000001
        r12: 0x0000000106694748  r13: 0x000000010668f9d0  r14: 0x0000000000000000  r15: 0x0000000000000020
        rip: 0x00000001004d2a66  rfl: 0x0000000000010202  cr2: 0x0000000000000028
                                                              Logical CPU: 6
                                                              Binary Images:
        0x100000000 -        0x100fdfff7 +com.adobe.bridge5 (5.0.0.399 - 5.0.0.399) <636A7F8C-23DD-C87E-DA14-1BECA16EF6FD> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/MacOS/Adobe Bridge CS6
        0x10152a000 -        0x1018a7fff +com.adobe.AGM (AdobeAGM 4.26.17.19243 - 4.26.17.19243) <19B59987-1020-E125-DC86-EA48FC81A890> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
        0x101913000 -        0x101d59ff7 +com.adobe.MPS (AdobeMPS 5.8.0.19243 - 5.8.0.19243) <54D82D33-3BD6-30EB-2308-B5C113CD3280> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
        0x101dd5000 -        0x101e17ff7 +com.adobe.ARE (AdobeARE 1.5.02.19243 - 1.5.02.19243) <8ADD7F0A-6F31-7E61-F5C1-9A32CF8072E7> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
        0x101e1f000 -        0x102b64ff7 +libicudata.40.0.dylib (40) <6211D655-ECF8-7378-CF68-3B07300D5A29> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
        0x102b77000 -        0x102c34fff +com.adobe.AdobeExtendScript (ExtendScript 4.2.12 - 4.2.12.18602) <0957DFA6-0593-CE4B-8638-00F32113B07B> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
        0x102c7e000 -        0x102d2cfef +com.adobe.AdobeScCore (ScCore 4.2.12 - 4.2.12.18602) <9CEE95E5-2FC6-5E58-02A4-138EA6F8D894> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
        0x102d69000 -        0x1030cafef +com.adobe.CoolType (AdobeCoolType 5.10.31.19243 - 5.10.31.19243) <8BFF14FB-AA14-1CBF-C2A3-715363B5A841> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
        0x103117000 -        0x1031dcfff +com.adobe.JP2K (2.0.0 - 2.0.0.18562) <B14B096C-AA23-BA8F-E3AE-8DB102F9D161> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
        0x103229000 -        0x104327fff +com.adobe.psl (AdobePSL 13.0.0.19494 - 13.0.0.19494) <2EC30542-8CE4-DAE8-D4E5-73ED0E25209D> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
        0x1044e7000 -        0x104627fe7 +libicui18n.40.0.dylib (40) <B0341318-FB92-A0CF-2CA5-7FA100624DBD> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/libicui18n.40. 0.dylib
        0x1046a6000 -        0x10481ffff +com.adobe.ACE (AdobeACE 2.19.18.19243 - 2.19.18.19243) <7F28B188-1D1B-20C9-BBB9-B74FCC12ECAD> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
        0x104832000 -        0x104934fef +libicuuc.40.0.dylib (40) <76F12DCE-F356-D48D-4239-FC103706EF76> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/libicuuc.40.0.dylib
        0x10497c000 -        0x104ac9fe7 +com.winsoft.wrservices (WRServices 5.0.0 - 5.0.0) <2072D001-8A6C-1906-05DA-A79519C1B3E8> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
        0x104b3d000 -        0x104be7fe7 +libicucnv.40.0.dylib (40) <768D99C5-46B9-B849-2834-B5BF541856D1> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
        0x104c0e000 -        0x104c12ff7 +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120201) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
        0x104c18000 -        0x104c96fff +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 66.145433) <5C63613F-6BDE-1C29-D3FD-9D292F9ADB12> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
        0x104ca7000 -        0x104d07ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.145661) <B475CD07-1024-560D-5BFE-2A6FCE63925C> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
        0x104d11000 -        0x104df5fe7 +com.adobe.amtlib (amtlib 6.0.0.93 - 6.0.0.93) <3FB67F73-A24E-789B-0BAE-8FB3BE025C11> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
        0x104e06000 -        0x104ebefe7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.4 -f 49 - 66.145661) <9F30F410-B84E-EB85-7F2C-C72BCD50CB77> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
        0x104ef1000 -        0x104ef6fff  com.apple.agl (3.2.1 - AGL-3.2.1) <1A57AE22-37F6-3A2E-8098-183B280EEEA9> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
        0x104efd000 -        0x104f29fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.7.101.18636 - 3.7.101.18636) <488DF1F7-A643-5168-706A-498A0322A87E> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
        0x104f4c000 -        0x104f50ff7 +com.adobe.ape.shim (3.3.8.19346 - 3.3.8.19346) <13D5CEF7-6090-CD66-8DA0-190771950F76> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
        0x104f56000 -        0x104f70ff7 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
        0x104f79000 -        0x104f98fff +com.adobe.BIB (AdobeBIB 1.2.02.19243 - 1.2.02.19243) <B7D7EE28-D604-2989-B099-62AEF4885C21> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
        0x104f9f000 -        0x104fc7ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <9BDD08A8-2DD8-A570-7A7B-EDAA7097D61B> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
        0x104fce000 -        0x105014fff +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
        0x10502e000 -        0x105128fe7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.7.101.18636 - 3.7.101.18636) <C7652AF2-56D7-8AF8-A207-0BDEDDFF0BEC> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
        0x1051cc000 -        0x1051d4fff +com.adobe.boost_date_time.framework (6.0.0 - 6.0.0.0) <C1595DE4-3635-DCE0-CD0F-2003C9BFF053> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
        0x1051f3000 -        0x1052dcff7 +com.adobe.dvaplayer.framework (6.0.0 - 6.0.0.0) <8D554E7A-D281-E779-6E28-AFC80E8CA9AB> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
        0x105440000 -        0x10544cfff +com.adobe.boost_threads.framework (6.0.0 - 6.0.0.0) <269A9942-7F59-01D1-C00D-1E4AB7C7C9F6> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
        0x105473000 -        0x105474fff +com.adobe.boost_system.framework (6.0.0 - 6.0.0.0) <5DDA11F3-C29A-CA82-FE1C-46D488DD6AB7> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
        0x10547d000 -        0x105489ff7 +com.adobe.boost_signals.framework (6.0.0 - 6.0.0.0) <11FED135-516F-7A53-F976-D86F91918D8F> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
        0x1054a2000 -        0x105675fff +com.adobe.dvacore.framework (6.0.0 - 6.0.0.0) <1058D6FF-14BF-AA82-1B06-5A940736CD78> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
        0x1058fd000 -        0x105941fff +com.adobe.dvamarshal.framework (6.0.0 - 6.0.0.0) <8B9C7238-3529-3105-B632-135E69E619BC> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
        0x1059d1000 -        0x1059feff7 +com.adobe.dvamediatypes.framework (6.0.0 - 6.0.0.0) <ED6D5CBD-86F9-7E68-9E2C-FFD527865A83> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
        0x105a39000 -        0x105a99fff +com.adobe.dvatransport.framework (6.0.0 - 6.0.0.0) <C59040CF-8E73-F921-6F28-E982E85454FA> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
        0x105b1b000 -        0x105b43ff7 +com.adobe.dvaunittesting.framework (6.0.0 - 6.0.0.0) <50E7B3AC-B623-AE2B-BCD4-5C03EE081036> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
        0x105b8d000 -        0x105dcbfef +com.adobe.dynamiclink.framework (6.0.0 - 6.0.0.0) <5B92B2A8-D8D1-580F-67BA-4D7BD850A1B4> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
        0x105fc1000 -        0x106066ff7 +com.adobe.dvaaudiodevice.framework (6.0.0 - 6.0.0.0) <09575BCE-F941-90C4-8903-42431130A38A> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
        0x106142000 -        0x1062cdff7 +com.adobe.mediacoreif.framework (6.0.0 - 6.0.0.0) <73E27DD4-9345-A414-61A1-B184C4919A8C> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/mediacoreif.framework/Versions/A/mediacoreif
        0x1064f5000 -        0x106521ff7 +libtbb.dylib (0) <57655978-A378-BE1E-7905-7D7F951AD6F7> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/libtbb.dylib
        0x106538000 -        0x106546ff3 +libtbbmalloc.dylib (0) <CB038B96-2999-5EB1-E26A-7720A7A8F8CD> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/libtbbmalloc.dylib
        0x1065eb000 -        0x1065edff7  com.apple.textencoding.unicode (2.5 - 2.5) <0518078E-C652-3CFC-A3FB-903C600CE831> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
        0x108ec7000 -        0x108f41fef +com.adobe.adobe_caps (adobe_caps 6.0.29.0 - 6.0.29.0) <C0AD101D-E452-4B4B-5B31-F467133EC20C> /Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
        0x10b024000 -        0x10b0ddff7  ColorSyncDeprecated.dylib (400) <7CE58F6E-D2C8-39FB-8EE0-28CC6EC6D04F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
        0x10b125000 -        0x10b1aafff +MultiProcessor Support (???) <3282C25C-382A-0D1C-57FA-5D8F17433F81> /Applications/Adobe Bridge CS6/*/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
        0x10b300000 -        0x10b36dff7 +MMXCore (???) <1774E65C-6EF3-2CA7-0293-2588C53031A9> /Applications/Adobe Bridge CS6/*/MMXCore.plugin/Contents/MacOS/MMXCore
        0x10b6ea000 -        0x10b7a0fef +Photoshop Adapter (???) <5312C312-1DB3-584F-37BA-D0A765BA77C6> /Applications/Adobe Bridge CS6/*/Photoshop Adapter.plugin/Contents/MacOS/Photoshop Adapter
        0x10b93b000 -        0x10ca2ffe7 +com.adobe.CameraRaw (7.0 [308] - 7.0.0f308) <E39B3C04-98BA-7EE2-8926-35EDF86CF2C5> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
        0x7fff67a2a000 -     0x7fff67a5e93f  dyld (210.2.3) <A40597AA-5529-3337-8C09-D8A014EB1578> /usr/lib/dyld
        0x7fff86357000 -     0x7fff86381ff7  com.apple.CoreVideo (1.8 - 99.3) <C424838A-889C-39E5-8108-FD05C93D26A0> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff86382000 -     0x7fff86391ff7  com.apple.opengl (1.8.6 - 1.8.6) <720CC06C-0D01-37AE-BB3D-D7F0242B262A> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff8654d000 -     0x7fff8657bff7  libsystem_m.dylib (3022.6) <B434BE5C-25AB-3EBD-BAA7-5304B34E3441> /usr/lib/system/libsystem_m.dylib
        0x7fff8657c000 -     0x7fff865adff7  com.apple.DictionaryServices (1.2 - 184.4) <054F2D6F-9CFF-3EF1-9778-25C551B616C1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
        0x7fff86609000 -     0x7fff86db1fff  com.apple.CoreAUC (6.16.00 - 6.16.00) <B0B4B5B8-6F8F-3221-9128-313E3B8C695D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
        0x7fff86db2000 -     0x7fff86ea7fff  libiconv.2.dylib (34) <FEE8B996-EB44-37FA-B96E-D379664DEFE1> /usr/lib/libiconv.2.dylib
        0x7fff86ecb000 -     0x7fff86f38fff  com.apple.datadetectorscore (4.0 - 269.1) <C94C372B-3821-3A46-A8C2-091AB1CFF7F4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
        0x7fff87f76000 -     0x7fff880bafef  com.apple.MediaControlSender (1.4.5 - 145.3) <3A308EA3-21F7-3213-9157-D3421EB43715> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSen der
        0x7fff880bb000 -     0x7fff880c2fff  libcopyfile.dylib (89) <876573D0-E907-3566-A108-577EAD1B6182> /usr/lib/system/libcopyfile.dylib
        0x7fff880c3000 -     0x7fff88169ff7  com.apple.CoreServices.OSServices (557.4 - 557.4) <841878A8-6F3E-300D-8F01-444B3CC1F41D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
        0x7fff883ea000 -     0x7fff883eaffd  com.apple.audio.units.AudioUnit (1.8 - 1.8) <29E2C990-3617-3FA2-BDD7-DB7DF493E443> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff884c7000 -     0x7fff884c8fff  liblangid.dylib (116) <864C409D-D56B-383E-9B44-A435A47F2346> /usr/lib/liblangid.dylib
        0x7fff8867b000 -     0x7fff8874dff7  com.apple.CoreText (260.0 - 275.16) <5BFC1D67-6A6F-38BC-9D90-9C712684EDAC> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff8874f000 -     0x7fff887e9fff  com.apple.CoreSymbolication (3.0 - 87) <75F2C0DD-549A-36F6-BD9E-FB40A924344F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
        0x7fff887ea000 -     0x7fff887edfff  com.apple.help (1.3.2 - 42) <343904FE-3022-3573-97D6-5FE17F8643BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
        0x7fff887ee000 -     0x7fff887efff7  libremovefile.dylib (23.1) <DBBFAF35-AC78-3856-92F6-6E4FD9DF14A2> /usr/lib/system/libremovefile.dylib
        0x7fff887f0000 -     0x7fff887f8fff  liblaunch.dylib (442.26.2) <2F71CAF8-6524-329E-AC56-C506658B4C0C> /usr/lib/system/liblaunch.dylib
        0x7fff887f9000 -     0x7fff887f9fff  com.apple.Carbon (154 - 155) <372716D2-6FA1-3611-8501-3DD1D4A6E8C8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff88827000 -     0x7fff8883cfff  com.apple.ImageCapture (8.0 - 8.0) <17A45CE6-7DA3-36A5-B7EF-72BC136981AE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
        0x7fff88a99000 -     0x7fff88aa7fff  libcommonCrypto.dylib (60026) <2D6537F5-1B5E-305C-A1CF-D1FA80CA3939> /usr/lib/system/libcommonCrypto.dylib
        0x7fff88aa8000 -     0x7fff88aacff7  com.apple.CommonPanels (1.2.5 - 94) <AAC003DE-2D6E-38B7-B66B-1F3DA91E7245> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
        0x7fff88b01000 -     0x7fff88bcdfe7  libsystem_c.dylib (825.25) <8CBCF9B9-EBB7-365E-A3FF-2F3850763C6B> /usr/lib/system/libsystem_c.dylib
        0x7fff88c2d000 -     0x7fff88c33fff  libGFXShared.dylib (8.6.1) <CF55E720-1B9E-3E24-A1DA-7FA8B261CD8E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
        0x7fff88c92000 -     0x7fff88cb4ff7  libxpc.dylib (140.41) <FAC04D8B-680E-325F-8F0C-DD69859D0E01> /usr/lib/system/libxpc.dylib
        0x7fff88cb5000 -     0x7fff88cd0ff7  libsystem_kernel.dylib (2050.18.24) <C0535565-35D1-31A7-A744-63D9F10F12A4> /usr/lib/system/libsystem_kernel.dylib
        0x7fff88cd1000 -     0x7fff88fe8ff7  com.apple.CoreServices.CarbonCore (1037.3 - 1037.3) <DF7CABCA-F2CB-345B-8EFF-F0F4E937B7FF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
        0x7fff88fe9000 -     0x7fff88fecfff  libRadiance.dylib (845) <E8956A35-494E-3014-8B86-362D32576116> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff88fed000 -     0x7fff88feffff  libCVMSPluginSupport.dylib (8.6.1) <7EFDA31E-E463-3897-A8DC-7FD266EB713E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
        0x7fff88ff2000 -     0x7fff89049ff7  com.apple.ScalableUserInterface (1.0 - 1) <F1D43DFB-1796-361B-AD4B-39F1EED3BE19> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
        0x7fff8904a000 -     0x7fff8904cfff  com.apple.TrustEvaluationAgent (2.0 - 23) <A97D348B-32BF-3E52-8DF2-59BFAD21E1A3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
        0x7fff8904d000 -     0x7fff89054fff  com.apple.NetFS (5.0 - 4.0) <82E24B9A-7742-3DA3-9E99-ED267D98C05E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff89055000 -     0x7fff89057ff7  com.apple.print.framework.Print (8.0 - 258) <34666CC2-B86D-3313-B3B6-A9977AD593DA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
        0x7fff89058000 -     0x7fff8905efff  libmacho.dylib (829) <BF332AD9-E89F-387E-92A4-6E1AB74BD4D9> /usr/lib/system/libmacho.dylib
        0x7fff8911f000 -     0x7fff89146ff7  com.apple.PerformanceAnalysis (1.16 - 16) <E4888388-F41B-313E-9CBB-5807D077BDA9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
        0x7fff894de000 -     0x7fff894f4fff  com.apple.MultitouchSupport.framework (235.28 - 235.28) <BD78B16E-9B5A-3E07-93B4-13AD1A538CAC> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
        0x7fff897c8000 -     0x7fff8981efff  com.apple.HIServices (1.20 - 417) <A1129272-FEC8-350B-BA26-5A97F23C413D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
        0x7fff8981f000 -     0x7fff8989fff7  com.apple.ApplicationServices.ATS (332 - 341.1) <BD83B039-AB25-3E3E-9975-A67DAE66988B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
        0x7fff898a0000 -     0x7fff898e4fff  libcups.2.dylib (327) <9B3F3321-D2BC-3195-BF20-4008FC52A390> /usr/lib/libcups.2.dylib
        0x7fff898e5000 -     0x7fff89c15ff7  com.apple.HIToolbox (2.0 - 625) <317F75F7-4B0F-35F5-89A7-F20BA60AC944> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
        0x7fff8a359000 -     0x7fff8a3dbfff  com.apple.Heimdal (3.0 - 2.0) <660A6C64-4912-32C8-A332-B64164032A2D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
        0x7fff8a3ef000 -     0x7fff8a44bff7  com.apple.Symbolication (1.3 - 93) <F2C7E0B6-B241-3020-B30A-0636D0FA3378> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
        0x7fff8a44c000 -     0x7fff8a4a9ff7  com.apple.AE (645.3 - 645.3) <FF867ACA-8628-3E5A-8FA0-AF429B42C5D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
        0x7fff8a4aa000 -     0x7fff8a61bff7  com.apple.QTKit (7.7.1 - 2599.13) <5B24A892-ED69-3C01-8B00-DF3AD81A20D4> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff8a632000 -     0x7fff8a638fff  com.apple.DiskArbitration (2.5.1 - 2.5.1) <F7DAF7CC-5893-3F06-9168-3B0192B66D15> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
        0x7fff8a639000 -     0x7fff8aa75fff  com.apple.VideoToolbox (1.0 - 926.62) <7D749558-08B6-3F86-A20E-05ECDACE6F17> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
        0x7fff8aa76000 -     0x7fff8ab81fff  libFontParser.dylib (84.5) <617A7D30-C7BC-39FC-A1FE-59367B4A5719> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
        0x7fff8ac28000 -     0x7fff8ac48fff  libPng.dylib (845) <C3CDD2B4-3CB0-3F6D-8411-DAAF267E952B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff8ad18000 -     0x7fff8ae15fff  libsqlite3.dylib (138.1) <ADE9CB98-D77D-300C-A32A-556B7440769F> /usr/lib/libsqlite3.dylib
        0x7fff8ae16000 -     0x7fff8ae21fff  libsystem_notify.dylib (98.5) <C49275CC-835A-3207-AFBA-8C01374927B6> /usr/lib/system/libsystem_notify.dylib
        0x7fff8ae24000 -     0x7fff8aed5fff  com.apple.LaunchServices (539.7 - 539.7) <DA7C602E-5E01-31B8-925D-B45360CA089F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
        0x7fff8b03a000 -     0x7fff8b223fff  com.apple.CoreFoundation (6.8 - 744.12) <EF002794-DAEF-31C6-866C-E3E3AC387A9F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff8b224000 -     0x7fff8b2b1ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <C7F43889-F8BF-3CB9-AD66-11AEFCBCEDE7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
        0x7fff8b6f7000 -     0x7fff8baeefff  libLAPACK.dylib (1073.4) <D632EC8B-2BA0-3853-800A-20DA00A1091C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
        0x7fff8baef000 -     0x7fff8bb17fff  libJPEG.dylib (845) <A32618D7-FB91-3EE2-A105-5407B2F3F8D8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff8bc09000 -     0x7fff8bc1cff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2F2694E9-A7BC-33C7-B4CF-8EC907DF0FEB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
        0x7fff8bc1d000 -     0x7fff8bc68fff  com.apple.framework.CoreWLAN (3.0.1 - 301.11) <8370178E-438C-375C-AA41-A8DEE60B8636> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff8bcf4000 -     0x7fff8be45fff  com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <833DA682-A3C1-39E7-AEC3-9EDC734DE2A9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
        0x7fff8be55000 -     0x7fff8be6ffff  com.apple.CoreMediaAuthoring (2.1 - 914) <CFA664F9-D5A7-3281-A12F-3ED8A98FD8C1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
        0x7fff8be70000 -     0x7fff8beb8fff  com.apple.framework.CoreWiFi (1.0 - 100.10) <0E863B4A-1094-3F8D-BEDE-D99537E9C588> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
        0x7fff8beb9000 -     0x7fff8befcfff  com.apple.RemoteViewServices (2.0 - 80.5) <F3A897C9-A277-3B56-8FB3-2BC2C10C33BF> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
        0x7fff8befd000 -     0x7fff8bf52ff7  libTIFF.dylib (845) <ADCB4683-69EB-318B-8BE7-5FDF38BCADAF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff8c216000 -     0x7fff8c2d3ff7  com.apple.ColorSync (4.8.0 - 4.8.0) <6CE333AE-EDDB-3768-9598-9DB38041DC55> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
        0x7fff8c2d4000 -     0x7fff8c3d6fff  libcrypto.0.9.8.dylib (47) <74F165AD-4572-3B26-B0E2-A97477FE59D0> /usr/lib/libcrypto.0.9.8.dylib
        0x7fff8c3d7000 -     0x7fff8c3d7fff  com.apple.CoreServices (57 - 57) <9DD44CB0-C644-35C3-8F57-0B41B3EC147D> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
        0x7fff8c3d8000 -     0x7fff8c422ff7  libGLU.dylib (8.6.1) <DF45C1E3-3884-3991-B84F-F39B482E8BF8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
        0x7fff8c429000 -     0x7fff8c466fe7  libGLImage.dylib (8.6.1) <7F31DD61-3110-3541-A9BB-035CD1262E50> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
        0x7fff8c467000 -     0x7fff8c467fff  com.apple.Cocoa (6.7 - 19) <1F77945C-F37A-3171-B22E-F7AB0FCBB4D4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff8c468000 -     0x7fff8c4beff7  com.apple.opencl (2.1.20 - 2.1.20) <AF142CA4-EA1D-31B0-A48F-AA2B75D4309E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff8c4bf000 -     0x7fff8c4ccfff  libbz2.1.0.dylib (29) <CE9785E8-B535-3504-B392-82F0064D9AF2> /usr/lib/libbz2.1.0.dylib
        0x7fff8c4cd000 -     0x7fff8c4e2ff7  libdispatch.dylib (228.23) <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
        0x7fff8c4e3000 -     0x7fff8c5bdff7  com.apple.backup.framework (1.4.1 - 1.4.1) <A3CFCA9E-717C-302D-821B-16FD35E6673F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
        0x7fff8c5be000 -     0x7fff8c615ff7  com.apple.AppleVAFramework (5.0.18 - 5.0.18) <B75949DD-AC27-3848-8221-00D70D14C7E0> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
        0x7fff8c88b000 -     0x7fff8c88dfff  libquarantine.dylib (52) <4BE2E642-A14F-340A-B482-5BD2AEFD9C24> /usr/lib/system/libquarantine.dylib
        0x7fff8c88e000 -     0x7fff8c9aefff  com.apple.desktopservices (1.7.2 - 1.7.2) <CDE8C2C2-C505-31B0-8C61-E40E4EA364A5> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
        0x7fff8c9af000 -     0x7fff8caacff7  libxml2.2.dylib (22.3) <47B09CB2-C636-3024-8B55-6040F7829B4C> /usr/lib/libxml2.2.dylib
        0x7fff8caad000 -     0x7fff8cab9fff  libCSync.A.dylib (324.6) <2033247A-CABC-3E20-8498-7367A8F44A08> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
        0x7fff8caff000 -     0x7fff8cb26fff  com.apple.framework.familycontrols (4.1 - 410) <AE49B2AB-7D2B-3D52-8E21-60EBEA1A38E6> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
        0x7fff8cb27000 -     0x7fff8cf44fff  FaceCoreLight (2.4.1) <A34C9575-C4C1-31B1-809B-7751070B4E8B> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
        0x7fff8cf83000 -     0x7fff8cfa4fff  com.apple.Ubiquity (1.2 - 243.10) <F97D3A33-2C8B-3CFF-AF75-A74866D42853> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
        0x7fff8cfa5000 -     0x7fff8cfcaff7  libc++abi.dylib (24.4) <E7BD9363-1D25-3551-A68A-2E2FF6ABECD7> /usr/lib/libc++abi.dylib
        0x7fff8cfcb000 -     0x7fff8cfdffff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <94EDF2AB-809C-3D15-BED5-7AD45B2A7C16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
        0x7fff8cfe0000 -     0x7fff8d016fff  com.apple.DebugSymbols (98 - 98) <14E788B1-4EB2-3FD7-934B-849534DFC198> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
        0x7fff8d017000 -     0x7fff8d074fff  com.apple.audio.CoreAudio (4.1.0 - 4.1.0) <B3198BD6-EA1D-3E5E-ADD4-37D8E6B72678> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff8d0b6000 -     0x7fff8d0b7ff7  libSystem.B.dylib (169.3) <365477AB-D641-389D-B8F4-A1FAE9657EEE> /usr/lib/libSystem.B.dylib
        0x7fff8d0ba000 -     0x7fff8d0e5fff  com.apple.framework.Apple80211 (8.0.1 - 801.17) <05786C8E-8C6F-31AF-80B5-9C98175757B4> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
        0x7fff8d271000 -     0x7fff8d27fff7  libkxld.dylib (2050.18.24) <7027CE49-007D-3553-8FFA-3E3B428B2316> /usr/lib/system/libkxld.dylib
        0x7fff8d280000 -     0x7fff8d294fff  libGL.dylib (8.6.1) <2E00615F-97F5-34EB-BE07-75A24F3C18D7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
        0x7fff8d295000 -     0x7fff8d2d4ff7  com.apple.QD (3.42 - 285) <8DF36FCA-C06B-30F4-A631-7BE2FF7E56D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
        0x7fff8d373000 -     0x7fff8d3c4ff7  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <E095637C-457F-3D8F-AE32-A032F9D5A46C> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
        0x7fff8d3ca000 -     0x7fff8d3cafff  com.apple.vecLib (3.8 - vecLib 3.8) <794317C7-4E38-338A-A874-5E18001C8503> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff8d3cb000 -     0x7fff8d405fff  com.apple.GSS (3.0 - 2.0) <0BDF8090-5EF4-3759-94DE-8521D74188AA> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff8d448000 -     0x7fff8d44bff7  libdyld.dylib (210.2.3) <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
        0x7fff8d49c000 -     0x7fff8d740fff  com.apple.CoreImage (8.2.2 - 1.0.1) <930B0B23-DD84-3B0C-B5A9-C09B7068A6F0> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
        0x7fff8e4f8000 -     0x7fff8e4fafff  com.apple.securityhi (4.0 - 55002) <34E45C60-DC7E-3FCC-A1ED-EBF48B77C559> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
        0x7fff8e4fb000 -     0x7fff8e57cfff  com.apple.Metadata (10.7.0 - 707.3) <A45D75C1-B311-39F0-AF4A-63FCCC098C1D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
        0x7fff8e57d000 -     0x7fff8e588fff  com.apple.CommonAuth (3.0 - 2.0) <74A86DDD-57D0-3178-AB74-E1F31DBFFC39> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
        0x7fff8e5fc000 -     0x7fff8e601fff  com.apple.OpenDirectory (10.8 - 151.10) <CF44120B-9B01-32DD-852E-C9C0E1243FC0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
        0x7fff8e63a000 -     0x7fff8e63cff7  libunc.dylib (25) <92805328-CD36-34FF-9436-571AB0485072> /usr/lib/system/libunc.dylib
        0x7fff8e828000 -     0x7fff8e83ffff  com.apple.GenerationalStorage (1.1 - 132.2) <3F5C87BD-D866-3732-8CB9-D23ED9784D6E> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
        0x7fff8e891000 -     0x7fff8e8bdff7  libRIP.A.dylib (324.6) <5A7EB5C2-BA60-36D7-BF41-9853F37837AA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
        0x7fff8e8be000 -     0x7fff8ea6cfff  com.apple.QuartzCore (1.8 - 304.0) <BDC66714-F60C-386D-A773-F897D1E87AB6> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff8eaf0000 -     0x7fff8eaf5fff  libcompiler_rt.dylib (30) <08F8731D-5961-39F1-AD00-4590321D24A9> /usr/lib/system/libcompiler_rt.dylib
        0x7fff8ebde000 -     0x7fff8ebe2fff  libCGXType.A.dylib (324.6) <2FC25246-A69F-3F81-9AC6-0A1753E1C6A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
        0x7fff8ebe3000 -     0x7fff8ec00fff  com.apple.openscripting (1.3.6 - 148.2) <33B87CFB-CACC-3EBC-893D-38AECB94FB8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
        0x7fff8ec01000 -     0x7fff8ec05fff  libCoreVMClient.dylib (24.4) <55F71158-ADEE-3863-92E9-4772DCEA8E31> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
        0x7fff8ec06000 -     0x7fff8ec73ff7  com.apple.framework.IOKit (2.0 - 755.18.10) <142E19DD-1C8D-3D61-ABC8-83994A73279F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff8ec74000 -     0x7fff8ede8fff  com.apple.CFNetwork (596.2.3 - 596.2.3) <6A16C2BD-1035-30F9-AE96-D9E3BB54A976> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff8edfc000 -     0x7fff8ee0eff7  libz.1.dylib (43) <2A1551E8-A272-3DE5-B692-955974FE1416> /usr/lib/libz.1.dylib
        0x7fff8ee0f000 -     0x7fff8ee2eff7  libresolv.9.dylib (51) <0882DC2D-A892-31FF-AD8C-0BB518C48B23> /usr/lib/libresolv.9.dylib
        0x7fff8ee2f000 -     0x7fff8f7bfc67  com.apple.CoreGraphics (1.600.0 - 324.6) <DCC70C6E-AB6D-3457-A823-7569CB29B107> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
        0x7fff8f7fa000 -     0x7fff8f7fefff  com.apple.IOSurface (86.0.3 - 86.0.3) <C121DE83-ED12-3DC1-BDB3-4FCB29AB0571> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff8f814000 -     0x7fff8fa14fff  libicucore.A.dylib (491.11.1) <CC318A27-878A-38CE-9292-1B98353FA9C7> /usr/lib/libicucore.A.dylib
        0x7fff8fa15000 -     0x7fff8fa23ff7  libsystem_network.dylib (77.10) <0D99F24E-56FE-380F-B81B-4A4C630EE587> /usr/lib/system/libsystem_network.dylib
        0x7fff8fbaf000 -     0x7fff8fde4ff7  com.apple.CoreData (106.1 - 407.7) <24E0A6B4-9ECA-3D12-B26A-72B9DCF09768> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff8fde5000 -     0x7fff8fe3ffff  com.apple.print.framework.PrintCore (8.1 - 387.1) <1FA17B75-33E6-35BD-9198-35F92E37B248> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
        0x7fff8fe40000 -     0x7fff8ff5892f  libobjc.A.dylib (532.2) <90D31928-F48D-3E37-874F-220A51FD9E37> /usr/lib/libobjc.A.dylib
        0x7fff8ffec000 -     0x7fff90003fff  com.apple.CFOpenDirectory (10.8 - 151.10) <FFBBA538-00B5-334E-BA5B-C8AD6CDCDA14> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
        0x7fff9002d000 -     0x7fff9002dfff  com.apple.Accelerate (1.8 - Accelerate 1.8) <6AD48543-0864-3D40-80CE-01F184F24B45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff90063000 -     0x7fff90101ff7  com.apple.ink.framework (10.8.2 - 150) <84B9825C-3822-375F-BE58-A753444FBDE2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
        0x7fff90102000 -     0x7fff90106fff  libGIF.dylib (845) <2690CE83-E934-3EF8-A30A-996EDADCE3E4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff90123000 -     0x7fff90124ff7  libsystem_sandbox.dylib (220) <3C3B03CF-C525-3CB3-8557-62E91B93AC95> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff90125000 -     0x7fff901eaff7  com.apple.coreui (2.0 - 181.1) <83D2C92D-6842-3C9D-9289-39D5B4554C3A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff901f0000 -     0x7fff9028afff  libvMisc.dylib (380.6) <714336EA-1C0E-3735-B31C-19DFDAAF6221> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
        0x7fff90294000 -     0x7fff902e3ff7  libFontRegistry.dylib (100) <2E03D7DA-9B8F-31BB-8FB5-3D3B6272127F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
        0x7fff902e4000 -     0x7fff902f1ff7  com.apple.NetAuth (4.0 - 4.0) <F5BC7D7D-AF28-3C83-A674-DADA48FF7810> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
        0x7fff902f3000 -     0x7fff902f7ff7  com.apple.TCC (1.0 - 1) <F2F3B753-FC73-3543-8BBE-859FDBB4D6A6> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
        0x7fff90388000 -     0x7fff90397ff7  libxar.1.dylib (105) <370ED355-E516-311E-BAFD-D80633A84BE1> /usr/lib/libxar.1.dylib
        0x7fff90398000 -     0x7fff903a2fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <D803919C-3102-3515-A178-61E9C86C46A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
        0x7fff903e4000 -     0x7fff903f1fff  com.apple.AppleFSCompression (49 - 1.0) <5508344A-2A7E-3122-9562-6F363910A80E> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
        0x7fff903f2000 -     0x7fff9101fff7  com.apple.AppKit (6.8 - 1187.34) <1FF64844-EB62-3F96-AED7-6525B7CCEC23> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff9105b000 -     0x7fff9105bfff  com.apple.ApplicationServices (45 - 45) <A3ABF20B-ED3A-32B5-830E-B37831A45A80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
        0x7fff9105e000 -     0x7fff91067fff  com.apple.CommerceCore (1.0 - 26) <997CD214-BC78-3C61-A1B8-813EA1CB9997> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
        0x7fff91068000 -     0x7fff9106dfff  libcache.dylib (57) <65187C6E-3FBF-3EB8-A1AA-389445E2984D> /usr/lib/system/libcache.dylib
        0x7fff9106e000 -     0x7fff9109cfff  com.apple.CoreServicesInternal (154.2 - 154.2) <3E6196E6-F3B4-316F-9E1F-13B6B9694C7E> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
        0x7fff910cc000 -     0x7fff910ebff7  com.apple.ChunkingLibrary (2.0 - 133.2) <D2A746DE-002A-3C6C-961E-BE94E71DB835> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
        0x7fff91140000 -     0x7fff912dbfef  com.apple.vImage (6.0 - 6.0) <FAE13169-295A-33A5-8E6B-7C2CC1407FA7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
        0x7fff91319000 -     0x7fff9134ffff  libsystem_info.dylib (406.17) <4FFCA242-7F04-365F-87A6-D4EFB89503C1> /usr/lib/system/libsystem_info.dylib
        0x7fff91350000 -     0x7fff9139cff7  libauto.dylib (185.1) <73CDC482-16E3-3FC7-9BB4-FBA2DA44DBC2> /usr/lib/libauto.dylib
        0x7fff91460000 -     0x7fff915e6fff  libBLAS.dylib (1073.4) <C102C0F6-8CB6-3B49-BA6B-2EB61F0B2784> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
        0x7fff91673000 -     0x7fff916b6ff7  com.apple.bom (12.0 - 192) <0BF1F2D2-3648-36B7-BE4B-551A0173209B> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
        0x7fff916b7000 -     0x7fff916b7fff  libOpenScriptingUtil.dylib (148.2) <B8061D13-C1B2-38D5-A723-9A98D64E67AC> /usr/lib/libOpenScriptingUtil.dylib
        0x7fff916b8000 -     0x7fff91703ff7  com.apple.CoreMedia (1.0 - 926.62) <CFBD094F-DA9C-3498-9D50-BC754B56F00A> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff91753000 -     0x7fff91754fff  libsystem_blocks.dylib (59) <D92DCBC3-541C-37BD-AADE-ACC75A0C59C8> /usr/lib/system/libsystem_blocks.dylib
        0x7fff917ad000 -     0x7fff917b3ff7  libunwind.dylib (35.1) <21703D36-2DAB-3D8B-8442-EAAB23C060D3> /usr/lib/system/libunwind.dylib
        0x7fff917b4000 -     0x7fff917d6ff7  com.apple.Kerberos (2.0 - 1) <C49B8820-34ED-39D7-A407-A3E854153556> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff917d7000 -     0x7fff917f8ff7  libCRFSuite.dylib (33) <736ABE58-8DED-3289-A042-C25AF7AE5B23> /usr/lib/libCRFSuite.dylib
        0x7fff917f9000 -     0x7fff91805fff  com.apple.CrashReporterSupport (10.8.2 - 415) <55783BF9-125E-3F9C-A412-6A095ECD9353> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
        0x7fff91806000 -     0x7fff91853fff  com.apple.CoreMediaIO (301.0 - 4147) <61E348A5-1F9E-3390-9613-3EACE40DBD8C> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
        0x7fff918f5000 -     0x7fff91973ff7  com.apple.securityfoundation (6.0 - 55115.4) <C5461971-E455-31A6-99B8-AF80C4BC26DD> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
        0x7fff91974000 -     0x7fff91978fff  libpam.2.dylib (20) <C8F45864-5B58-3237-87E1-2C258A1D73B8> /usr/lib/libpam.2.dylib
        0x7fff91a1a000 -     0x7fff91a25ff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <C12962D5-85FB-349E-AA56-64F4F487F219> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
        0x7fff91a6e000 -     0x7fff91a81ff7  libbsm.0.dylib (32) <F497D3CE-40D9-3551-84B4-3D5E39600737> /usr/lib/libbsm.0.dylib
        0x7fff91eeb000 -     0x7fff921bbfff  com.apple.security (7.0 - 55179.1) <639641EF-8156-3190-890C-1053658E044A> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff921bc000 -     0x7fff9220bff7  libcorecrypto.dylib (106.2) <CE0C29A3-C420-339B-ADAA-52F4683233CC> /usr/lib/system/libcorecrypto.dylib
        0x7fff9220c000 -     0x7fff92568fff  com.apple.Foundation (6.8 - 945.11) <A5D41956-A354-3ACC-9355-BE200072223B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff92627000 -     0x7fff9268ffff  libvDSP.dylib (380.6) <CD4C5EEB-9E63-30C4-8103-7A5EAEA0BE60> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
        0x7fff92690000 -     0x7fff926bbfff  libxslt.1.dylib (11.3) <441776B8-9130-3893-956F-39C85FFA644F> /usr/lib/libxslt.1.dylib
        0x7fff926bc000 -     0x7fff926bdfff  libDiagnosticMessagesClient.dylib (8) <8548E0DC-0D2F-30B6-B045-FE8A038E76D8> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff9271b000 -     0x7fff92835fff  com.apple.coreavchd (5.6.0 - 5600.4.16) <0CF2ABE5-B088-3B5D-9C04-47AE708ADAE3> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
        0x7fff9286c000 -     0x7fff92874ff7  libsystem_dnssd.dylib (379.32.1) <62AA0B84-188A-348B-8F9E-3E2DB08DB93C> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff92875000 -     0x7fff9298eff7  com.apple.ImageIO.framework (3.2.0 - 845) <553B9828-A7D9-3AE4-A214-1C33417545FD> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff9298f000 -     0x7fff92d88ff7  com.apple.MediaToolbox (1.0 - 926.62) <83BBE53E-29FE-3874-9991-B6D009EADCC5> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
        0x7fff92d89000 -     0x7fff92e8bfff  libJP2.dylib (845) <405CAF25-0AA5-3C6B-A4A6-94471A1EDD2F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
        0x7fff92ed3000 -     0x7fff92ee1fff  com.apple.Librarian (1.1 - 1) <1635162F-239A-341E-83C7-710C55E254AF> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
        0x7fff92f3d000 -     0x7fff92fa5ff7  libc++.1.dylib (65.1) <20E31B90-19B9-3C2A-A9EB-474E08F9FE05> /usr/lib/libc++.1.dylib
        0x7fff92fa6000 -     0x7fff9300ffff  libstdc++.6.dylib (56) <EAA2B53E-EADE-39CF-A0EF-FB9D4940672A> /usr/lib/libstdc++.6.dylib
        0x7fff93014000 -     0x7fff93014fff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <B5A18EE8-DF81-38DD-ACAF-7076B2A26225> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
        0x7fff93015000 -     0x7fff93016ff7  libdnsinfo.dylib (453.18) <E7595861-ECF9-336E-9901-BED2620FAA80> /usr/lib/system/libdnsinfo.dylib
        0x7fff93028000 -     0x7fff93028fff  libkeymgr.dylib (25) <CC9E3394-BE16-397F-926B-E579B60EE429> /usr/lib/system/libkeymgr.dylib
                                                              External Modification Summary:
        Calls made by other processes targeting this process:
        task_for_pid: 4
        thread_create: 0
        thread_set_state: 0
        Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
        Calls made by all processes on this machine:
        task_for_pid: 864
        thread_create: 1
        thread_set_state: 0
                                                              VM Region Summary:
                                                              ReadOnly portion of Libraries: Total=281.5M resident=168.0M(60%) swapped_out_or_unallocated=113.5M(40%)
                                                              Writable regions: Total=82.6M written=7492K(9%) resident=18.7M(23%) swapped_out=0K(0%) unallocated=63.9M(77%)
                                                              REGION TYPE                      VIRTUAL
                                                              CG backing stores                  6204K
                                                              CG image                              4K
                                                              CG shared images                   1184K
                                                              CoreServices                       2004K
                                                              MALLOC                             53.2M
                                                              MALLOC guard page                    48K
                                                              Memory tag=242                       12K
                                                              STACK GUARD                        56.1M
                                                              Stack                              19.7M
                                                              VM_ALLOCATE                        1020K
                                                              __DATA                             25.1M
                                                              __IMAGE                             528K
                                                              __LINKEDIT                         70.2M
                                                              __TEXT                            211.3M
                                                              __UNICODE                           544K
                                                              mapped file                        41.5M
                                                              shared memory                      9532K
                                                              TOTAL                             497.6M
                                                              • 68. Re: Adobe Bridge CS6 will not open
        ChunXiaYang Level 2
        I will check your crash report and update you once I get result.
        Chunxia
        • 69. Re: Adobe Bridge CS6 will not open
        ChunXiaYang Level 2
        After quick check your crash log, I think this issue may related to the collections you may created. So please try:
        1. remove all the files and sub-folders in folder ~/Library/Application Support/Adobe/Bridge CS6.
        2. If method 1 cannot resolve the issue, try to launch Bridge by pressing option key, and check the checkboxes in the dialog popping up.
        Please tell me the result. Thanks!
        Chunxia
        • 70. Re: Adobe Bridge CS6 will not open
        alty33000 Level 1
        Thanks for your reply.
        Tried both and none corrected the crush of Bridge….
        Any other solution?
        Tal
        • 71. Re: Adobe Bridge CS6 will not open
        alty33000 Level 1
        Also when trying the second option….getting error:
        The Operation could not be completed.
        A write permissions error has occurred.
        I went to Bridge which i tried to reinstall….and gave ALL permissions of Read and Write to the file…..but stll getting this error msg….
        Frustratiing indeed.
        • 72. Re: Adobe Bridge CS6 will not open
        Curt Y Level 6
        If if is a permission error that is based in the operating system.  Sometimes one can do a workaround with a permission problem if you right click on the Bridge icon and choose "run as administrator".  THis is a different permission level that having full permission.  If this changes anything the next step is to see what needs to be changed.  Frequently occurs with external drives or drives that have been moved from one computer to another (ownership issue).
        • 73. Re: Adobe Bridge CS6 will not open
        Omke Oudeman Level 5
        On a Mac that is not an option. Go to your application folder / utility folder and inhere find and open Apple Disk utility.
        Choose the start Up disk and run the Check and repair permissions, after finished try again.
        • 74. Re: Adobe Bridge CS6 will not open
        gsmoliar
        Mac Mountain Lion Adobe CS6 fully updated as of December 11 2012. Bridge will not launch and has never launched with this setup (MacBook Pro Retina Display)
        I have only been able to launch Bridge if I startup with a fairly blank user account, not my regular setup. Any thoughts about what might be mucking it up in my usual account?
        • 75. Re: Adobe Bridge CS6 will not open
        I have no clue how Bridge did muck your system up but in the before Lion and ML period this usually was solved by performing an Archive and Install from your original OS install disk. This provided a back up of your old user library and created a fresh one while all applications and files stayed on your system (although you should first make a back up of all important files for security) and took not more then half an hour. While I believe this is still possible but then you have to download the OS again from the App Store and create an install DVD your self (try and Google this for detailed info).
        But I would first start with a Check and Repair permissions using Apple Disk Utility (in the application / utilities folder) and try if that solves this problem.
        Could you report back if the permissions repair did work?
        • 76. Re: Adobe Bridge CS6 will not open
        gsmoliar Level 1
        Repairing permissions did not help.
        • 77. Re: Adobe Bridge CS6 will not open
        Quit Bridge, go to your user library ( by default hidden, menu go and press option to reveal it) and in preferences folder find and manual delete the 'com.adobe.bridge5.plist' file to the trash.
        In same library: user (you username) / Library / caches / Adobe / Bridge CS6 and inhere find and delete both files ( Adobe Bridge Plug-in Cache and the folder called Cache.)
        Same path for caches but now Adobe Camera Raw and inhere select all and delete to the trash.
        Then restart Bridge holding down (again) option and choose reset preferences.
        Hope this works for you otherwise an Archive and Install for OSX might do the trick.
        • 78. Re: Adobe Bridge CS6 will not open
        gsmoliar Level 1
        Still no luck. And I don't think Archive and Install in Mt. Lion is the way to go because, as I mentioned in my first post, Bridge will start in the Guest User account.
        • 79. Re: Adobe Bridge CS6 will not open
        That is what an archive an install does, creating a fresh user account library and copy the old one. I'm still not on Mountain Lion (waiting for the new macPro to appear) but I have created a install Disk myself from the Lion edition I did buy in the App Store. Also believe the archive and install is still an option, only can't check it now.
        Try a Google search for this. In the past (CS3 and CS4 mainly) the new user account test was a common check if all other options did not work, and in those cases an Archive and Install did the trick.
        You can try also first to uninstall CS6 and use the Adobe cleaner tool (read the manual carefully, no dangerous stuff but be sure to have a back up) and then reinstall CS6 again as fresh.
        But no guarantee this will solve it either, Bridge can be quit critical on installing, don't know what procedure or action caused this but it has been a problem (not common btw) before.
