Hi guys, been a while, hope everyone is well. I am having a problem implementing a next/previous button on an image once it has been enlarged in my gallery. I have done it in pure as3 but all tutorials seem to use the timeline. I will post my code underneath so you can see what I am up too. The next/previous button should I think be added to the modelClicked function.
From what I understand, I will get a next/previous button and turn them into a button object. I will then delete them from my stage and instantiate them within the class below. I would then add them to the modelClicked function with events tied to them. What should I then do in these events to make it fit in with the code below?
Any advise appreciated,
Cheers
Nick
package classes.models
import flash.display.Bitmap;
import flash.display.Loader;
import flash.display.MovieClip;
import flash.display.Sprite;
import flash.geom.Rectangle;
import flash.events.MouseEvent;
import flash.events.Event;
import flash.net.URLRequest;
import eu.flashlabs.ui.BasicButton;
import classes.ui.StateClip;
import classes.ui.Placeholder;
import classes.utils.URLUtil;
import classes.vo.ModelsStates;
import fl.containers.ScrollPane;
import fl.controls.ProgressBar;
import com.greensock.TweenLite;
public class IndividualModel extends StateClip
// CONSTANTS
private static const PADDING_TOP:Number= 28;
private static const PADDING_LEFT:Number= 50;
private static const COLS:int= 4;
private static const ROWS:int= 8;
private static const GAP_HORIZONTAL:Number= 5;
private static const GAP_VERTICAL:Number= 5;
// MEMBER VARIABLES
private var _data:XML;
public function get data():XML
return _data;
public function set data(value:XML):void
setData(value);
private var items:Array;
private var backBtn:BasicButton;
private var itemsHolder:MovieClip;
private var loadIndex:int;
private var sp:ScrollPane;
private var clonedBitmap:Bitmap;
private var originalBitmap:Bitmap;
private var rect:Rectangle;
private var screen:Sprite = new Sprite();
public function IndividualModel()
super();
items = [];
addEventListener(Event.ADDED_TO_STAGE, addedToStageHandler);
private function addedToStageHandler(event:Event):void
initChildren();
private function initChildren():void
itemsHolder = new MovieClip();
addChild(itemsHolder);
sp = getChildByName("mc_pane") as ScrollPane;
backBtn = getChildByName("btn_back") as BasicButton;
backBtn.addEventListener(MouseEvent.CLICK, backBtn_clickHandler);
screen.graphics.beginFill(0x111111, .75);
screen.graphics.drawRect(0, 0, stage.stageWidth, stage.stageHeight);
screen.graphics.endFill();
public function destroy():void
clearItems();
// PUBLIC INTERFACE
// LAYOUT
private function clearItems():void
while (items.length > 0)
var item:ModelsItem = items.pop() as ModelsItem;
itemsHolder.removeChild(item);
item.destroy();
private function populateItems():void
for (var i:int = 0; i < Math.min(COLS * ROWS, data.picture.length()); i++)
var item:ModelsItem = new ModelsItem();
item.data = data.picture;
item.x = PADDING_LEFT + (i % COLS) * (ModelsItem.ITEM_WIDTH + GAP_HORIZONTAL);
item.y = PADDING_TOP + Math.floor(i / COLS) * (ModelsItem.ITEM_HEIGHT + GAP_VERTICAL);
/*item.addEventListener(MouseEvent.CLICK, modelClicked);*/
itemsHolder.addChild(item);
/*item.mouseEnabled = false;*/
sp.source = itemsHolder;
items.push(item);
sp.verticalScrollPolicy = "on";
sp.horizontalScrollPolicy = "off";
sp.update();
// PICTURE LOADING
private function loadNextPicture():void
if (loadIndex < items.length)
var loader:Loader = new Loader();
loader.contentLoaderInfo.addEventListener(Event.COMPLETE, loadNextPicture_completeHandler);
var item:ModelsItem = items[loadIndex] as ModelsItem;
loader.load(new URLRequest(URLUtil.getURL(item.data.@url.toString())));
/*item.mouseEnabled = true;*/
private function loadNextPicture_completeHandler(event:Event):void
event.target.removeEventListener(Event.COMPLETE, loadNextPicture_completeHandler);
ModelsItem(items[loadIndex]).bitmap = event.target.content as Bitmap;
ModelsItem(items[loadIndex]).addEventListener(MouseEvent.CLICK, modelClicked);
loadIndex++;
loadNextPicture();
// EVENT HANDLERS
private function backBtn_clickHandler(event:MouseEvent):void
state = ModelsStates.HIDDEN;
private function modelClicked(e:MouseEvent):void
stage.addChild(screen);
var item:ModelsItem = e.currentTarget as ModelsItem;
originalBitmap = item.bitmap;
clonedBitmap = new Bitmap(originalBitmap.bitmapData.clone());
stage.addChild(clonedBitmap);
rect = originalBitmap.getBounds(stage);
clonedBitmap.x = rect.x;
clonedBitmap.y = rect.y;
clonedBitmap.width = rect.width;
clonedBitmap.height = rect.height;
clonedBitmap.smoothing = true;
TweenLite.to(clonedBitmap, 1, { x: (stage.stageWidth - originalBitmap.width) / 4, y: (stage.stageHeight - originalBitmap.height) / 6, onComplete:zoomInFinished, scaleX: 1, scaleY: 1 });
private function zoomInFinished():void
trace("Zoom In Finished");
stage.addEventListener(MouseEvent.CLICK, mouseClicked);
private function mouseClicked(e:MouseEvent):void
TweenLite.to(clonedBitmap, 1, { x: rect.x, y: rect.y, onComplete:zoomOutFinished, width: rect.width, height: rect.height});
stage.removeEventListener(MouseEvent.CLICK, mouseClicked);
private function zoomOutFinished():void
trace("Mouse Clicked");
stage.removeChild(screen);
stage.removeChild(clonedBitmap);
// GETTERS & SETTERS
private function setData(value:XML):void
_data = value;
clearItems();
populateItems();
loadIndex = 0;
loadNextPicture();
state = ModelsStates.SHOWN;
// UTILS
override protected function animateInComplete():void
super.animateInComplete();
switch (state)
case ModelsStates.SHOWN :
break;
case ModelsStates.HIDDEN :
break;
No offense, but I lost interest about halfway through your code. It's just too much code to ask someone to go through and try to guess where your problem is.
A few questions, maybe they'll help me zero in on your issue:
Hi, thanks for the reply. I actually dont have any problems with the code, it works perfectly and is a fully functioning image gallery. I only added it at the bottom as a source to scan through incase it helped. Now that everything is working, I want to add a next/previous button to the gallery. My idea about adding them as images to the stage and then deleting them was so I had access to it in the code. Really I am just looking for ideas about how to add a next/previous button to my working gallery. At the moment I have not added anything, so the code I show is fine.
Cheers
Nick
You'd have access to it in the code whether you delete it or not, or whether you put it on the stage or instantiate it directly from the library. What are you specifically having an issue with?
Hi, I have managed to get the next and back buttons in, but the problem I am having is using them to scroll through the images in my gallery. As you can see in the code, I have a modelClicked function. This function is called when a thumbnail is clicked, and it enlarges it to a larger image. For the next/previous buttons, I think I basically have to reproduce this function. However, instead of calling the current target, I think I need to call the next target (If that is possible). Basically, I am trying to figure out a way of scrolling through the large versions of my images in the gallery.
Many thanks
Nick
Divide the current function into two functions. In the first function, just find the index of the item in your items list, then call the second function. In the second function, find the item in the items list from its index and then run the code on it just like you are now.
Now, you can use your second function from your next and previous buttons. They will simply increment or decrement from a stored current index variable and call the new function that can enlarge the item based on index.
Hi Amy, thank you very much for your help up until this point, its much appreciated. The gallery I am working with is basically 2 galleries in one, and its for a modelling agency. Basically, the first gallery displays a picture of every model. When you click on a model, a new gallery is displayed with every picture for that model, and this is handled by the class I have show in my original post.
When each image is loaded for the individual model (handled by the function loadNextPicture) a load index is incremented. However, if I check what the loadIndex is for the model whos gallery is being displayed, the number is always the number of pictures in the models gallery (not the number of the current picture). In order to get the image number, I would need something like the following which doesnt work.
trace(e.currentTarget.loadIndex);
So although the loadIndex is used to increment through the number of images in a models gallery, the images themself are not given any identification (or I dont think they are anyways). So how would I go about making sure that the numbers used in the loadIndex are assigned to each image? In my loadNextPicture_completeHandler function, I am trying something along the lines of, without success,
event.target.name = loadIndex;
I may even need to use a variable tottally seperate from loadIndex? I am hoping you kind of see what I am doing and thank you for all the advise so far.
Cheers
Nick
I don't actually know how you're loading your data. It's also very difficult to figure out what's happening in your code, since you're extending Classes you don't show. What I can tell you is that you need to store the data about iterating each collection at the level where it's needed. You may want to look at the composite pattern http://www.as3dp.com/2007/05/composite-pattern-book-part-1/ .
In my opinion, the biggest problem you have is poor separation of concerns--you call things Models that are clearly Views, and because you are storing relevant data in Views rather than simply using your Views to represent data, you're making the task of representing and iterating through your data much harder than it needs to be.
The ideal structure would be a data structure that has data for each thumbnail in some sort of collection, like an Array or Vector. This data structure would only be responsible for storing the data and maintaining a pointer to the currently selected thumbnail. When the pointer changes, the data object dispatches a change event, so Views that care about this pointer can update. Each piece of data could then have a member variable that is one of these collections that manages the correct pointer. That's where the composite pattern comes in.
Now, the task of building your Views becomes much easier. You have one View that gets a collection and shows all the thumbnails and one View that gets a specific thumbnail, mix and match as needed. The Views, again watch the change event and do whatever they need to do when the pointer changes.
At this point, who sets the pointer ceases to matter. It can be inside one of your Views or outside any of your Views--when the pointer changes, the View that is watching that particular collection will update, and if the result of that update is that a nested View then watches a different collection, that's ok--it still follows the same principles.
