Hi All -
I am using cf 9 version and cfcalendar. This does not seem to be working only on chrome. The date value is not getting passed to the next page. I get the following error in chrome console
Uncaught ReferenceError: updateHiddenValue is not defined
And in network tab of chrome, the following returns 304 not modified cfform.swc.cfswf
Does anybody have an idea why this could be happening?
Thanks.
Can you please try the sample code shared at:
http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-7afb.html
and observe the behavioron Google Chrome?
**** firstDayOfWeek="first day of the week in integer", You need to enter an integer here. {for eg. 1}
Also, once you run this code on Google Chrome, can you share the snap-shot of the same too?
Thanks.
rg,
Spsb84
Thanks for the reply. The sample code works fine when format="flash". When format="html", that is when the I get
'updateHiddenValue' is not defined. I have more fields on my page other than calendar. I dont want to change the format to flash. Any workaround for this kind of issue?
Thanks for yuor updates.
I ran the code {sample as per livedocs}, changing the format="html", on both IE and Chrome.
The code runs fine on both the browsers. But, the only difference that i observed was:
Running on IE: when changing the dates and clicking Save, on the top, i see: "You Selected {the_selected_date}".
Running on Chrome: when changing the dates and clicking Save, on the top, i only see: "You Selected ". --> with no date being shown.
Do you see the same?
HTH.
Rg,
Spsb84
Yes, I do see the same behavior. For chrome if you checked the console, its the same error I get with my application
