Hi alta-girl,
First, work with BMP instead of PNG, if you can. You'll have
less problems because Captivate was bottle-fed BMP from birth and
likes it a lot as default image fodder. That's just a throw-away
suggestion ... and is worth exactly what you paid for it.
You can use highlight box(es) to create the outer frame(s).
Just insert it/them on slide #1 and set object properties to
display for "Rest of Project" (or "Rest of Movie" as is appropriate
to your version).
The bottom "gray area" (playback control?) can be created
many ways, the easiest of which is to capture it with the original
recording as a part of the recording background. To see how to do
that, scope out my example/tutorial
at
the link right here.
Another - quicker - way is to just set up your recording area
(square red rectangle) to include an additional 30 -45 pixels
below the application window you are capturing - AFTER
FIRST:
1) Clearing the Desktop ...
(right-click Desktop) > Arrange Icons by > (de-select)
Show Desktop Icons
2) Removing Desktop images ...
(right-click Desktop) > Properties > Desktop (tab) >
Background > "None"
3) Change Desktop background color (to gray in your case)
Color picker box > Select color
Finally, you can duplicate the logo (watermark) by inserting
(on first slide, probably) an image, or a text-box, or an animated
text object (any of those) and - again - setting its "Display for
..." setting to "Rest of Project".
Hope there is some useful information here for you. If not, I
tried. If so, send money, small denominations.
