3 Replies Latest reply: Aug 21, 2012 11:08 AM by Sport2105 RSS
    Encore CS 6: Multipage Menues
    Sport2105 Community Member
      Hello,
      I'm new here and I'm creating currently a project with a lot of chapters. I used a predefined menue with a connected submenu.
      Then I connected one button to the submenu and another button to the first chapter. These two buttons are working just fine.
      Then I assigned in the submenue the first button to the first chapter and let Encore create the remaining links to the other chapters. In total I have now 4 pages (1 main menue and 3 sub menues).
      Even if it looks that the pages from the submenues are connected the menue doesn't change to the next screen if I choose "Next". In comparison the link to the Main Menue works fine.
      Any ideas what I can try?
      This happens while Trying "Preview from here" in the menue context menue.
      I have Windows 7 64 Bit and I'm creating a PAL DVD with 720*576 resolution.
      Thanks in Advance
      Uwe
      Some more information added
        • 1. Re: Encore CS 6: Multipage Menues
          Ramesh_Encore Adobe Employee
          Multipage menu is a Blu-ray feature.
          Encore has just the DVD preview available. So any Blu-ray feature would not be previewd in Encore itself. For this you have to burn a disc and test if the navigation works fine for you. Please use BD-RE discs for testing purposes.
          -Ramesh.
          • 2. Re: Encore CS 6: Multipage Menues
            Stan Jones CommunityMVP
            As Ramesh says, multipage is not available in DVD. Are you creating a multipage? Are you doing a BD?
            If you are creating a DVD, use "Create Chapter Index," not "Create Multipage Chapter Index."
            If that is not it, let us know and we'll help you sort it out.
            • 3. Re: Encore CS 6: Multipage Menues
              I assume that you mean BlueRay when you say "BD". I'm still burning regular one-sided DVDs. So I will try "Create Chapter Index" and then I will report here if this is working. However based on the information you provided my assumption is that this will solve the problem.
              Thanks to both of you
              Uwe
              I tried it out and it works now.
              Thanks again
