Set Contents pane width in WebHelp?
Guest
Aug 21, 2012 Aug 21, 2012
Hello all,
I'm using RoboHelp 8 / RH8 to create WebHelp.
How / where do I set the width of the Table of Contents pane for the webhelp output? I can't find this in the forum or the Help Guide...
These days, with high resolution monitors, I need to increase the font size in the ToC. But then it runs out of space in the ToC width. Hence the need for a wider ToC.
Help anyone?
2.9K
LEGEND , Aug 21, 2012 Aug 21, 2012
Hi Philip
Sorry, but RoboHelp has never provided a GUI way to do this. Not for WebHelp. If you were using CHM, it would be a piece of cake.
What you will have too do is hack the output files. I believe I've documented how in my Skinny on Skins file.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Hi Philip
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Adobe Employee ,
Hi Philip,
There is no way we can change that within Robohelp however after generating the output we can make very small change in "whskin_frmset01.htm" change the value "frameset cols". It will change the Navigation Pane width. But everytime you will generate teh webhelp it will reset the settings, so you need to make these changes again and agian.
Hope this helps
Priyank
Priyank Shrivastava
Guest
Thanks Rick and Priyank.
Great... It is s-o-o EASY to do this for CHM Help, but not-invented-yet for WebHelp.
I guess the client will have to live with it, 'cause I can't rely on remembering to do this every time I build the output.
Priyank, put this on the wish list, would you?
Thanks again Guys.
Philip
You should be able to locate the corresponding "seed" file among the files in the RoboHelp install folder. If you amended that file with the desired width, all subsequent generations would follow suit as they draw from this file.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Guest
Hmm...
I have 4,061 files in my RoboHelp install folder.
Can you give me a clue what to look for?!
Adobe Employee ,
Hi Philip,
The file which i mentioned above are available in the SSL! folder which is in your Project folder in your harddrive. You can search for the file and open it in Wordpad or Notepad and then just change the value, but default it is 220, you can change it to anything.
Priyank
Priyank Shrivastava
Guest
Thanks Priyank,
I forgot to say that my last reply was to Rick, who said look for a "seed" file in my "RoboHelp install folder". I don't have a clue where to begin!
Philip
HI again Philip
I would use the Windows Find utilty and search for whskin_frmset01.htm. I think the file name is the same in the seed folders.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Guest
I do not find a file by that name inside the RoboHelp 9 install folder or subfolders
Maybe it is only in the output. Check there.
@petergrainge
Guest
Yes, it is there. Thank you. This option will not work for my project, which requires frequent publishing, although I wonder if there is a way to block that file from being overwritten on the server.
Michael West | ASK Support | Business Improvement | Aurecon
Message was edited by: Captiv8r - Removed SPAM bait.
Aug 22, 2012 Aug 22, 2012
The next few times you generate, see if the content changes. If it does not you could keep a replacement copy. However, I suspect this is a file that will change so be very wary.
@petergrainge
Guest
Feb 26, 2013 Feb 26, 2013
In RoboHelp 10, I found that I had to change the width setting twice in that file:
<frameset cols=\"220,
oFrameset.cols= "220,
When I changed only the first value, the web page would open with the correct column width, but as soon as I clicked another button (Search, Glossary), it would flip back to the old setting.
Guest
Jun 26, 2014 Jun 26, 2014
In Robohelp 10, I was able to open the *.skn file for the project and adjust the <frameset cols 220 value (in two places). This changed the width of the navigation pane and was a sticky setting.
Dec 16, 2015 Dec 16, 2015
Does anyone know if this is customizable (fixed) in a later version of RoboHelp?
Don’t believe so – you still need to go “under the hood”
RoboHelp Documentation
Download Adobe RoboHelp
