Baggage files not showing up in search
Guest
Aug 20, 2012 Aug 20, 2012
I have a small RH 9.0 project with about 15 pdf baggage files. The issue is the baggage files are not consistently showing up when using the "Search" feature. I deleted the files, readded to be sure I imported them correctly as baggage files, moved them to a new folder, re-added the hyperlinks, inserted them in the TOC as a page w/hyperlink, inseted the link directly in a topic as a lin, checked to ensure my RH recognized .pdfs ... everything I can find online suggestion how to fix it. Nothing is working! The frustrating thing is ... I can see one of them when I search (it is always the same one), but none of the others. All of the pdfs follow the same naming convention and are all the same type of pdf so I don't understand! I did the exact same thing for all of them! Help!
724
Aug 21, 2012 Aug 21, 2012
Have you have checked the baggage files are making it to wherever you have generated and published the help?
When you say the files are all the same type of PDF, do you mean they all compatible with the same version of Acrobat? How were the files created?
@petergrainge
Guest
Sep 07, 2012 Sep 07, 2012
Yes, we confirmed the baggae files were carried over to the published location. The pdf files were created with Acrobat X Pro. We did find a solution by downloading something called iFilter. I'm not sure why it worked, but it enhances .pdf search function or something like that.
Is it possible the one file that was found was created with another PDF tool or an earlier version of Acrobat? There was a bug in an earlier version of RoboHelp that was linked to the version of Acrobat used.
@petergrainge
Guest
Sep 09, 2012 Sep 09, 2012
Hmm ... maybe. We did upgrade our version of Acrobat. I think all referenced PDFs were created post upgrade, but that would be an easy thing to check. Thanks!
Keep in mind my suggestion is just a longshot.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
