Hello all,
I'm using RoboHelp 8 / RH8 to create WebHelp.
How / where do I set the width of the Table of Contents pane for the webhelp output? I can't find this in the forum or the Help Guide...
These days, with high resolution monitors, I need to increase the font size in the ToC. But then it runs out of space in the ToC width. Hence the need for a wider ToC.
Help anyone?
Hi Philip
Sorry, but RoboHelp has never provided a GUI way to do this. Not for WebHelp. If you were using CHM, it would be a piece of cake.
What you will have too do is hack the output files. I believe I've documented how in my Skinny on Skins file.
Cheers... Rick
Hi Philip
Cheers... Rick
Hi Philip,
There is no way we can change that within Robohelp however after generating the output we can make very small change in "whskin_frmset01.htm" change the value "frameset cols". It will change the Navigation Pane width. But everytime you will generate teh webhelp it will reset the settings, so you need to make these changes again and agian.
Hope this helps
Priyank
Thanks Rick and Priyank.
Great... It is s-o-o EASY to do this for CHM Help, but not-invented-yet for WebHelp.
I guess the client will have to live with it, 'cause I can't rely on remembering to do this every time I build the output.
Priyank, put this on the wish list, would you?
Thanks again Guys.
Philip
You should be able to locate the corresponding "seed" file among the files in the RoboHelp install folder. If you amended that file with the desired width, all subsequent generations would follow suit as they draw from this file.
Cheers... Rick
Hmm...
I have 4,061 files in my RoboHelp install folder.
Can you give me a clue what to look for?!
Hi Philip,
The file which i mentioned above are available in the SSL! folder which is in your Project folder in your harddrive. You can search for the file and open it in Wordpad or Notepad and then just change the value, but default it is 220, you can change it to anything.
Priyank
Thanks Priyank,
I forgot to say that my last reply was to Rick, who said look for a "seed" file in my "RoboHelp install folder". I don't have a clue where to begin!
Philip
HI again Philip
I would use the Windows Find utilty and search for whskin_frmset01.htm. I think the file name is the same in the seed folders.
Cheers... Rick
I do not find a file by that name inside the RoboHelp 9 install folder or subfolders
Maybe it is only in the output. Check there.
Yes, it is there. Thank you. This option will not work for my project, which requires frequent publishing, although I wonder if there is a way to block that file from being overwritten on the server.
Michael West | ASK Support | Business Improvement | Aurecon
Message was edited by: Captiv8r - Removed SPAM bait.
The next few times you generate, see if the content changes. If it does not you could keep a replacement copy. However, I suspect this is a file that will change so be very wary.
In RoboHelp 10, I found that I had to change the width setting twice in that file:
<frameset cols=\"220,
oFrameset.cols= "220,
When I changed only the first value, the web page would open with the correct column width, but as soon as I clicked another button (Search, Glossary), it would flip back to the old setting.
In Robohelp 10, I was able to open the *.skn file for the project and adjust the <frameset cols 220 value (in two places). This changed the width of the navigation pane and was a sticky setting.
Does anyone know if this is customizable (fixed) in a later version of RoboHelp?
Don’t believe so – you still need to go “under the hood”
