I have my Flash Player set to update fully automatically, but this seems pretty haphazard at the moment. I checked the install log, and this is a section from it.
2012-5-11+9-0-31.513 [error] 1226 1062
=O====== M/11.2.202.235 2012-05-11+09-00-24.659 ========
0000 00000010 "C:\Users\Nige\AppData\Local\Temp\{98D35243-42EB-4FD2-80EE-7BCE8E2481E4}\InstallFlashPlayer.exe" -iv 4
0001 00000020 C:\windows\system32\FlashPlayerCPLApp.cpl
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\windows\system32\Macromed\Flash\NPSWF32_11_2_202_235.dll
0012 00000015 C:\windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_Plugin.exe
0013
0014 00000017 C:\windows\system32\Macromed\Flash
0015 00000019 C:\windows\system32\FlashPlayerCPLApp.cpl
0016
0017
0018 00000021 C:\windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0019
0020
0021
0022 00000012
=X====== M/11.2.202.235 2012-05-11+09-00-46.845 ========
2012-5-20+18-37-0.256 [error] 1223 1056
2012-5-25+23-37-0.257 [error] 1223 1056
2012-6-3+7-37-0.258 [error] 1223 1056
2012-6-4+8-37-0.255 [error] 1223 1056
2012-6-7+11-37-0.257 [error] 1223 1056
Can someone advise what these error codes mean and how I can rectify them ? I appears that the update has worked in the past for both the my Firefox plugin and the ActiveX component, but it would be good to get confirmation on that, too.
Thanks.
the same here
2012-6-1+17-7-33.985 [error] 1226 1062
=O====== M/11.2.202.235 2012-06-01+17-07-32.534 ========
0000 00000010 "C:\Windows\TEMP\{FE5CA04F-F3F5-4AF4-9F09-A90568B13457}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001
0002
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_2_202_235.dll
0013 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_235_Plugin.exe
0014 00000017 C:\Windows\SysWOW64\Macromed\Flash
0015 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0016
0017
0018 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0019
0020
0021
0022 00000012
=X====== M/11.2.202.235 2012-06-01+17-07-36.481 ========
2012-6-14+11-7-0.219 [error] 1223 1056
the same error
2012-8-21+16-18-0.221 [error] 1223 1056
2012-8-21+17-18-0.220 [error] 1223 1056
2012-8-22+18-18-0.229 [error] 1223 1056
2012-8-22+20-18-0.224 [error] 1223 1056
2012-8-22+22-18-0.220 [error] 1223 1056
2012-8-23+12-18-0.228 [error] 1223 1056
2012-8-23+14-18-0.222 [error] 1223 1056
2012-8-23+15-18-0.221 [error] 1223 1056
if I start "FlashPlayerPlugin_xx_x_xxx_xxx.exe -update plugin" or "FlashPlayerActiveX_xx_x_xxx_xxx.exe -update activex" all updates are applied fine
Please download the latest version of Flash Player and let us know if you continue to see these issues: http://get.adobe.com/flashplayer/
Version 11_2_202_235 is fairly old and there have been several improvements in the update mechanism since then.
-Stephen
I'm getting this error on both 11.3 and 11.4.402.265. I grabbed the update for 11.4.402.278 and it's still happening. As far as I can tell, there are no problems with Flash but I do see this reported error.
Hi GDRamp,
Could you attach the contents of your log file? I'm particularly interested to see if this is happening every day, or just every once in a while. Also, does this still happen after a system restart?
