1. Re: I-200 error when trying to login
Refsgaard Aug 23, 2012 1:55 PM (in response to Refsgaard)I found a solution in another discussion:
1) opm.db file becomes corrupted and must be deleted. We're working to isolate the cause of this.
The opm.db file can be found in the OOBE folder in:
on Mac: <yourusername>/Library/Application Support/Adobe
on Windows XP: <youruser>\Local Settings\Application Data\Adobe
on Windows 7: <youruser>\AppData\Local\Adobe
This worked for me
2. Re: I-200 error when trying to login
wadirum123 Aug 30, 2012 6:41 AM (in response to Refsgaard)I have the same problem
I removed the opm.db file but as soon as I start the MUSE Application the file appears in the OOBE again. What can I do?
3. Re: I-200 error when trying to login
Ashley*Howard Aug 30, 2012 9:07 AM (in response to Refsgaard)I also have the same problem. I have tried the solution noted above - deleting the file and reopening. I have uninstalled and deleted the file, then reinstalled both the 1.1 and 2.0 versions. All to no avail. Help. Note: I am trying to sign into the trial version.
Wadirum - when muse is launched it should create a new (hopefully, uncorrupted) copy of the file in the folder. You want the file to come back.
4. Re: I-200 error when trying to login
ianhew Sep 21, 2012 6:35 AM (in response to Refsgaard)Thanks Refsgaard, this solution worked for me (win 7)
5. Re: I-200 error when trying to login
x504xPulpo Oct 29, 2012 12:37 PM (in response to ianhew)It worked for me too (Win 7)
6. Re: I-200 error when trying to login
rayacosta Jan 9, 2013 6:07 PM (in response to Refsgaard)Thanks, that really worked for me, but it was kind of hard. There is two upates with muse that didn´t woork with mac, could Adobe create a message or dialog box to point a help file explaining that I need to unistall or delete some files.
7. Re: I-200 error when trying to login
bepartners Apr 10, 2013 4:09 AM (in response to rayacosta)Thanks, but unforturnately this does not work for me, too with Mac. Is there another suggestion to solve the Problem?
8. Re: I-200 error when trying to login
Zak Williamson (Adobe) Apr 10, 2013 12:22 PM (in response to bepartners)Are you behind a corporate firewall? Do you have anti-malware software installed that may be preventing Muse from being able to reach the internet or use port 443 (to verify your trial/subscription)?
9. Re: I-200 error when trying to login
bepartners Apr 18, 2013 6:59 AM (in response to Zak Williamson (Adobe))Thank you for your help, Zak. We have located the issue within our infrastructure and working to solve it.
10. Re: I-200 error when trying to login
egbert kochen Apr 26, 2013 7:53 AM (in response to Refsgaard)I have the same problem with starting adobe muse on a macosx system.
Wich solution help?
11. Re: I-200 error when trying to login
bepartners Apr 26, 2013 3:38 AM (in response to Zak Williamson (Adobe))Zak, unfortunately we have not been able to solve the problem in the meantime. We use a https-proxy. Does Muse require an individualized ssl-certificate or a special hard-coded finger print? Does Adobe require to contact particular IP-addresses? If we know them, we are able to implement exeptional rules in our proxy for them.
12. Re: I-200 error when trying to login
harrison_tait Apr 29, 2013 6:32 AM (in response to Refsgaard)Hi Refsgaard,
I am having the same problem as everyone here, except when I went to delete the file opm.db I cant find it in the OOBE folder.. Do you have any advice on what to try next?
13. Re: I-200 error when trying to login
Vinayak_Gupta Apr 30, 2013 1:25 AM (in response to harrison_tait)Please refer to the following available documentation on resolving I-200 error with detailed explanation of each step.
http://helpx.adobe.com/muse/kb/unexpected-error-occurred-i-200.html
Vinayak
14. Re: I-200 error when trying to login
harrison_tait Apr 30, 2013 4:40 AM (in response to Vinayak_Gupta)Hi Vinayak,
I have tried all the options on tat link you sent but none have worked so far.. In the last option it say to launch a support ticket with the Adobemuse.log
Where do I launch a Support ticket from?
Harry
15. Re: I-200 error when trying to login
Vinayak_Gupta May 1, 2013 9:51 PM (in response to harrison_tait)You can reach Adobe Muse chat support through the following link, they shall create a case for you if needed - http://helpx.adobe.com/contact.html?product=muse
Just look for the "I still need help" button after you select anything from the 2nd step dropdown.
Vinayak
