I would like to know how to select multiple separate lines of text? For example, selecting the a few words of the first and last line of a paragraph and applying a style? I am trying to apply the same function as cmd+mouse would do in Microsoft Office WORD. Thank you for your help!!
No InDesign does not allow non-contigious text selections.
You can apply the paragraph style to first pararaph.
Then use the Eye Dropper tool http://help.adobe.com/en_US/indesign/cs/using/WSa285fff53dea4f8617383751001ea8cb3f-6e68a.html
to apply the same formatting to different text.
If you double click the Eye Dropper tool you will get options on exactly what can and can't be sampled.
Thank you very much for your help!
I have been using the eye drop tool but was trying to find if there was actually a another way of doing the multiple selection of text.
Cheers,
InDesign's nested line style feature can apply character styles to designated lines within a paragraph. So you could specify a character style to automatically apply to the first line of any paragraph. However, because there's no option to specify the last line, you'd need to create paragraph styles with line styles that apply the character style None to a number of lines after the first, then repeat the line style. In other words, you'd need one paragraph with a line style for two-line, three-line, four-line, etc. paragraphs.
If your text doesn't reflow often, you could define a nested style that applies a character style up to an End Nested Style character that you insert manually at the end of the first line, and at the end of the line before the last line, and define the character style to run up to the first End Nested Style character, then None up to the next (last) End Nested Style character, then apply the desired last-line character style through the end of the paragraph.
Search Google for terms like "InDesign end nested style line style" and similar terms without quotes for more info.
HTH
Peter
_______________________
Peter Gold
KnowHow ProServices
