Good morning,
I have just upgraded from RoboHelp 9 to RoboHelp 10 and I've noticed something odd about the multilevel lists and bullets when I am working in the Design view. There is now much larger line spacing between each bullet or number than there was in RoboHelp 9 (approx. 1,5 line or double spacing). When I actually preview the topic or generate the project the line spacing is fine (single) but it's just a bit odd that I'm seeing this extra spacing in the source files.
Has anybody else had similar issues?
Hello,
Welcome to Adobe Forums.
1) Open your Robohelp 10 project.
2) Click on Tools -> Options (Menu Bar)
3) Select "General" from Left section
4) Check "Convert Robohelp-edited topics to HTML" (Under Generation)
5) Click on "OK"
Generate the output again and check do you have that spacing issue ?
Vikram
If that does fix the problem, then the real solution lays in formatting your lists properly. See Lists on my site.
Hi there,
Thanks for getting back to me. The generated output is perfect - the multilevel lists and bullets are dislayed exactly as they should be (that is, exactly how we have formatted them in RoboHelp). The issue is how they are actually displaying in the 'Design' view in RoboHelp. Extra line spacing is automatically being placed before and after bullet and number lists (both multilevel and regular lists). You can see the difference in the screenshots below. The first image shows the spacing in the 'Design' view and the second shows the generated output for the same content. Perhaps I have configured something incorrectly to make the extra spacing appear - but in that case should it not also be displayed as extra space in the output? In RH 9, the spacing in the 'Design' view and in the output matched - this has only happened since we upgraded to RH 10.
It's not a big issue, as the output looks fine (which is the main thing) - it just means that the extra spacing takes up a lot of room in the 'Design' view and makes it harder to judge how the list will actually look when generated.
That points to the code being wrong. Following what I have covered in Lists should correct it.
Thanks Peter,
I have gone through your topics on multilevel lists and regular lists in RH and everything appears to be in order within our projects (in fact, I used these topics as a guide when creating the lists in RH9 - thank you for that!).
I have used our regular 'body' style (with paragraph spacing of 8pt before and 8pt after the paragraph) as the 'Paragraph Style' that is applied to the multilevel lists and bullets. So the paragraph spacing for these lists should match that of the 'body' style as they did in RH9 (8pt before and 8pt after each bullet/list item). Instead, it is now about 12pt before and after each bullet/list item - but only in the Design view (the paragraph spacing in the generated output displays the correct 'Paragraph Style'). It's as if RH is automatically adding 50% to the spacing for all bullet and list items in the Design view (not just for multilevel lists but also for regular RH bullets and numbers).
The simplest thing here is to import a topic into a new project and use the same CSS, that should show the problem.
Assuming it does, then zip up the project and see the Contact page on my site. Send the project as instructed there. Do make sure you include a link to this thread and please do not email the project direct.
In your list style there are two lines
x-lvl-1-p-class: Body; | |
x-lvl-1-p-tag: p; |
That's the way RoboHelp writes the list style and as a result it is inheriting values from the P tag.
You P tag definition includes
margin-top: 8pt; | |
margin-bottom: 8pt; |
and that is what is creating the gap. Change that and the gap changes. That may change other things in your content.
Thanks so much for your help Peter - I really appreciate it!
