Like I wrote in my subject line, RoboHelp pop-ups the error message “The Parameter is incorrect” when I try to modify any SSL.
What happens next, is that the “Print Document General” window opens, but does not allow me to select anything (the fields are blank).
If I close the window and open it again, it seems to work until I have to select the styles from our Microsoft Word Template.
Then the error message “The parameter is incorrect” appears again, and RoboHelp does not allow me to select anything but a stylesheet
(which is not what I need).
This is very strange, because not only until recently I was able to build Word documents and PDFs, but also my colleagues are able to
produce them out of my source.
Even the old projects, that I was able to build, now I cannot.
I do not have any problem in generating CHMs.
Until now I have tried everything I found in the forum:
http://forums.adobe.com/thread/120022
http://forums.adobe.com/thread/598335
http://forums.adobe.com/thread/870339
I am also looking at all programs that I installed since the last time I was able to build .docs in case there is a conflict, but I do not find anything!
My computer has Windows 7 installed and I use the Adobe Technical Communication Suite 3.5, with RoboHelp 9.
My Microsoft Office is 2010.
Can somebody please help me? Did someone have the same problem?
Thanks in advance.
Hi there
I know you said you reinstalled, but did you reinstall before or after you gave administrator rights to all users on your computer? And how many users *ARE* on your computer?
Often you need administrator rights to properly install things.
Cheers... Rick
Hi Rick,
thanks for answering so quickly!
I reinstalled before giving rights to all users. I am the administrator of my computer, that is why it is strange that for some reason I did not have all the rights from the beginning.
I attached a screenshot, so that you know what I mean about the rights.
Now that everyone on the computer is an admin, I'd suggest uninstalling and reinstalling once again.
Cheers... Rick
Hi Rick,
I found a solution in the middle .
I found an article about how, although you may think that you are the administrator of your computer, Windows 7 does not want you to be (if anyone is interested this is the English version of the one I read in German: http://www.sevenforums.com/tutorials/507-built-administrator-account-enable-disable.html).
Now as the real administrator, I can change the SSLs without problem.
What I still do not understand is how I could build the pdfs and docs before, and all of the sudden I could not, or why I still could build the CHMs... but I guess that is one of the many misteries about RoboHelp (and Windows ) that I will probably never understand.
Anyway, thank you for your help, hopefully I will not need it for this problem again.
Cheers,
Ana
Win7 changed the old rules we were used to under WinXP - if you were an admin, you automatically got access to all the files & folders on your c:\ drive; now you have to "promote" yourself to give you the same rights.
