1. Re: How to permanently rotate pdf 90 deg?
MichaelKazlow Jul 10, 2008 11:30 AM (in response to (mattad))This cannot be done in Reader, only Acrobat Standard, Pro, or Extended.
Mike -
2. Re: How to permanently rotate pdf 90 deg?
lrosenth Aug 27, 2012 7:44 AM (in response to (mattad))This is an Adobe forum, so mentions of other software products is not appropriate.
3. Re: How to permanently rotate pdf 90 deg?
Brett Veen Oct 19, 2012 8:44 AM (in response to lrosenth)Except when other products are able to solve a problem that Adobe's software can't. This is basic functionality and should be part of Adobe Reader.
4. Re: How to permanently rotate pdf 90 deg?
MC1001 Mar 15, 2013 8:23 AM (in response to (mattad))Install a pdf file printer driver and print the rotated file to the "pdf" printer. It will ask you for a file name to "print" to. The "printed" file will open in the correct orientation.
5. Re: How to permanently rotate pdf 90 deg?
Jelmor12 Jul 9, 2013 3:40 PM (in response to (mattad))Using AP, there are two methods of rotating pages. Think of one method as a view rotation and the other as a total file rotation. You want to go after the file rotation.
Problem. Most commonly used is the view rotation method (not permanent). Generally, these are menu buttons or perhaps you are using Ctrl+Shift+Plus/Minus to rotate left or right. Don't use this. Following a view rotation, notice your save icon is grayed out and if you save as..., there is no change.
Solution. Open your file that you want rotated (even if it is 1000 pages all in the wrong direction). Go to Document/Rotate Pages... or use Ctrl+Shift+R and this opens your rotation menu. You have several rotation options to rotate single pages, all pages, or a selection of pages. Choose what you need and select OK to proceed. Now you have two options; 1. You will notice your save icon is no longer grayed out so you can permanenly save the file, 2. You will be able to save as... a new file, should you want to keep the original in tact. Both options permanenly save your chosen rotation(s). This has been built into to software for quite some time but is often overlooked - and rightly so as its not immediately evident.
No cumbersome third-party software needed to resolve (or learn).
No printer driver to fumble with.
6. Re: How to permanently rotate pdf 90 deg?
Ragnarbh Apr 14, 2014 1:32 PM (in response to lrosenth)I believe Michael was refering to Adobe Acrobat Pro or Standard. So how would mentioning other Adobe products be inappropriate on an Adobe Forum?
7. Re: How to permanently rotate pdf 90 deg?
Test Screen Name Apr 14, 2014 1:36 PM (in response to Ragnarbh)I think the message was referring to a now-deleted post.
8. Re: How to permanently rotate pdf 90 deg?
scottdatek May 21, 2014 3:15 PM (in response to (mattad))i have Adobe Acrobat XI, and i still cannot rotate and save the pdf file without the orientation reverting to the original after i close and reopen. i try printing the pdf to the adobe pdf printer and then saving it, but i get the same results. This is maddening.
9. Re: How to permanently rotate pdf 90 deg?
Test Screen Name May 21, 2014 3:23 PM (in response to scottdatek)Rotate from the Pages palette or the Tools area. Do not rotate the view.
10. Re: How to permanently rotate pdf 90 deg?
lrosenth May 21, 2014 3:26 PM (in response to scottdatek)Choose the Rotate Pages command. http://drops.pdfsages.com/DGKN
11. Re: How to permanently rotate pdf 90 deg?
utahsmith Jun 13, 2014 8:36 AM (in response to Jelmor12)You are the MAN!
Thank you!
12. Re: How to permanently rotate pdf 90 deg?
coqui Jul 25, 2014 6:01 AM (in response to Test Screen Name)Worked perfectly using the Tool menu, not the view menu. Thanks very much.
13. Re: How to permanently rotate pdf 90 deg?
snarchitetto Sep 8, 2014 6:49 PM (in response to Jelmor12)do you have also some instructon for adobe touch user?
14. Re: How to permanently rotate pdf 90 deg?
Test Screen Name Sep 9, 2014 1:00 AM (in response to snarchitetto)Adobe Touch? You mean Adobe Reader Touch for Windows 8?
No version of Adobe Reader can edit files in this way. Only the paid-for Acrobat can. This runs on Windows 8, but not Windows 8 RT.
15. Re: How to permanently rotate pdf 90 deg?
snarchitetto Sep 9, 2014 2:09 AM (in response to Test Screen Name)hi I meant Adobe Reader Touch for Windows 8
it looks very limited to me :-( I can't do so much with this program
16. Re: How to permanently rotate pdf 90 deg?
snarchitetto Sep 9, 2014 2:10 AM (in response to snarchitetto)anyways, I just wanted to rotate file NOT permanently with Adobe Reader Touch for Windows 8
17. Re: How to permanently rotate pdf 90 deg?
Test Screen Name Sep 9, 2014 2:45 AM (in response to snarchitetto)Yes, it is very new and limited. Probably only for people with very limited Windows who cannot run the "real" Adobe Reader. Do you have WIndows RT?
18. Re: How to permanently rotate pdf 90 deg?
snarchitetto Sep 9, 2014 2:58 AM (in response to Test Screen Name)nope. I will check it later. thanks, s.
