I have downloaded adobe flash player multiple times. Each time I install it the computer says install was successful. But it's never there. I'll be on a site and it will ask me to install adobe flash player to view content. Would like to be able to. It's getting to be a bummer.
Hello Deborah,
Please check, Is ActiveX Filtering enabled on Internet Explorer 9 ?
1) Launch IE 9
2) From Menu Bar, Click on Tools -> ActiveX Filtering
OR
2) Click on Gear Icon (Right Hand Corner) -> Safety -> ActiveX Filtering
Note : Clicking on ActiveX Filtering will disable it
Vikram
What is your operating system & version?
What is your web browser?
[topic moved to Flash Player forum]
Hi Pat,
I’m working with vista, internet explorer 9 version 9.0.8112.16421. I see when I went in to look there was an update available. I will probably download that. If I didn’t get you the right info let me know I’ll send it to you. Thanks.
Deborah
Hello Deborah,
1) Launch IE 9
OR
Vikram
Thanks so much. That did the trick. But I have to wonder seeing as I downloaded it several times does that mean it’s been installed multiple times, and is taking up more space on computer, or does it remove previous version and replace it? Thanks.
Deborah
Re-installing Flash Player will just replace the installed player files.
Is there an equivalent solution for Macs? I have the same problem (Mac OS 10.7.4).
Lee
