hi
i get this error after doing some change in the hero class , i mean after this command
MovieClip(parent) only!.
the old code (works very well)
package {
import flash.display.MovieClip;
import flash.events.KeyboardEvent;
import flash.ui.Keyboard;
import flash.events.Event;
import flash.sensors.Accelerometer;
import flash.media.Sound;
import flash.media.SoundChannel;
public class HERO extends MovieClip {
var NIGHTJUNGLE:nightjungle = new nightjungle
var ELECTRICALSHIELD:electricalshield=new electricalshield ;
var fBall:fireball = new fireball();
var FIREBALLSOUND:fireballsound = new fireballsound
var speed:int=3;
var fireballindex:Array = new Array
var dir:int;
var ELECTRICITY:electricity = new electricity;
var SOUNDCHANNEL:SoundChannel = new SoundChannel
var firespeed:int = 10
var totalfirespeed = 0
var i:int
public function HERO() {
addEventListener(Event.ADDED_TO_STAGE,onAddedToStage);
public function onAddedToStage(event:Event):void {
addEventListener(Event.ENTER_FRAME,onEnterFrame );
stage.addEventListener(KeyboardEvent.KEY_DOWN,onKeyDown);
stage.addEventListener(KeyboardEvent.KEY_UP,onKeyUp);
SOUNDCHANNEL = NIGHTJUNGLE.play(1,1000)
gotoAndStop(4);
public function onEnterFrame(event:Event):void {
x += dir * speed
if (fBall.stage){
fBall.x += firespeed * dir;
fBall.width +=2
fBall.height += 2
totalfirespeed +=1
if (totalfirespeed == 10){
removeChild(fBall)
totalfirespeed = 0
public function onKeyDown(event:KeyboardEvent):void {
if (event.keyCode==Keyboard.RIGHT) {
gotoAndStop(2);
dir=1;
speed = 10
if (ELECTRICALSHIELD.stage)
addChild(ELECTRICALSHIELD)
if (event.keyCode==Keyboard.LEFT) {
gotoAndStop(1);
dir=-1;
speed = 10
if (event.keyCode==Keyboard.UP) {
gotoAndStop(1);
y=10;
if (event.keyCode==Keyboard.Q) {
speed=30;
addChild(ELECTRICALSHIELD);
SOUNDCHANNEL = ELECTRICITY.play()
if (event.keyCode == Keyboard.W) {
SOUNDCHANNEL = FIREBALLSOUND.play()
fBall.name = "fb"+String(i);
fBall.width = 50;
fBall.x
fireballindex.push(fBall);
addChild(fBall);
i++;
trace(i)
trace( fBall.name)
if (event.keyCode == Keyboard.E) {
MovieClip(parent).aa.x = x +100
public function onKeyUp(event:KeyboardEvent):void {
if (ELECTRICALSHIELD.stage) {
removeChild(ELECTRICALSHIELD);
if (SOUNDCHANNEL != null)
speed=0;
SOUNDCHANNEL = ELECTRICITY.play(1,1)
if (event.keyCode==Keyboard.W) {
speed = 0
gotoAndStop(3);
} else if (event.keyCode == Keyboard.RIGHT) {
speed =0
gotoAndStop(4);
new code (which is the one who has the error message)
package {
var speed:int=3;
var dir:int;
var i:int
gotoAndStop(4);
x += dir * speed
if (MovieClip(parent).fBall.stage){
MovieClip(parent).fBall.x += firespeed * dir;
MovieClip(parent).fBall.width +=2
MovieClip(parent).fBall.height += 2
totalfirespeed +=1
MovieClip(parent).removeChild(fBall)
totalfirespeed = 0
gotoAndStop(2);
dir=1;
speed = 10
gotoAndStop(1);
dir=-1;
speed = 10
gotoAndStop(1);
y=10;
speed=30;
MovieClip(parent).fBall.name = "fb"+String(i);
MovieClip(parent).fBall.width = 20;
MovieClip(parent).fBall.x =400
MovieClip(parent).fBall.y = 400
fireballindex.push(MovieClip(parent).fBall);
MovieClip(parent).addChild(fBall);
i++;
trace(i)
trace( MovieClip(parent).fBall.name)
speed=0;
speed = 0
gotoAndStop(3);
speed =0
gotoAndStop(4);
thank you
You have to remove any MovieClip(parent).fBall references overall. Use fBall directly as I've shown you above. I'll show you how your W key code would look rewritten with it:
fBall.name = "fb" + String(i);
fBall.width = 20;
fBall.x = 400
fBall.y = 400
i++;
trace(i)
trace(fBall.name)
Remove the Movie
...Copy link to clipboard
You should always include the entire error message(s) in your postings. With a few exceptions, there are only a couple of errors that I remember what they involve without having to see the message.
Be sure you have enabled the Permit Debugging option in your Flash Publish Settings before testing again to get the message. It can help by isolating the line where the problem is.
Also, you can then help others to help you by highlighting where in all the code you show the problemed code is.
lol , sorry i forget that
here
ReferenceError: Error #1069: Property fBall not found on MAIN and there is no default value.
at HERO/onEnterFrame()
You're adding an ADDED_TO_STAGE and an ENTER_FRAME event one after another. The ENTER_FRAME event is checking fBall.stage. At that point you probably have not even added fBall to the stage yet. You should check to see if it exists in your onEnterFrame() method.
e.g.
if (!fBall) { return; } // no fBall exists, ignore
x += dir * speed
if (fBall.stage)
fBall.width += 2
fBall.height += 2
totalfirespeed += 1
removeChild(fBall)
totalfirespeed = 0
no , the problem from the other code with MovieClip(parent) function
thank you for your replay
Please highlight line 56 in your code, either bold it or even better make it appear a different color.
sorry , i will edit it now
i dont know why i cant edit it now
but here
54 public function onEnterFrame(event:Event):void {
55
56 if (MovieClip(parent).fBall.stage){
57 MovieClip(parent).fBall.x += firespeed * dir;
58 MovieClip(parent).fBall.width +=2
59 MovieClip(parent).fBall.height += 2
60 totalfirespeed +=1
Ah didn't see it was 2 different pastes of code but the issue is the same. Here:
if (!MovieClip(this.parent).fBall) { return; } // doesn't exist yet
x += dir * speed
MovieClip(parent).fBall.width += 2
totalfirespeed += 1
totalfirespeed = 0
i copied your code in on enter frame function , but the problem still the same ?
So it exists but it's not on the display list. You'll need to amend that line of code to check if it's on a display list:
if ((!MovieClip(this.parent).fBall) || (!MovieClip(this.parent).contains(MovieClip(this.parent).fBall))) { return; }
Again it needs to not only exist but actually be on the display list. I should have remembered that
Optionally you can just check to see if the stage property is null, same difference. e.g.: MovieClip(this.parent).fBall.stage == null.
sorry but iam not realy sure if i realy understand what you mean,
i did this
remove this line
then i add this line
but the problem still there ?
sorry because dont get what you mean
thank you again for your replay
Can you paste the whole code block including what you inserted? It must be at the beginning of the function.
All the code is doing is quickly checking 2 things. 1, if fBall exists. 2, if it's currently on the display list.
If it doesn't exist you'll get one error. If it exists but it's not on the display list then the "stage" property won't be valid and you'll get a different error.
Include the error you're getting as well please.
here
package {
var speed:int=3;
var dir:int;
var i:int
gotoAndStop(4);
x += dir * speed
totalfirespeed += 1
totalfirespeed = 0
gotoAndStop(2);
dir=1;
speed = 10
gotoAndStop(1);
dir=-1;
speed = 10
gotoAndStop(1);
y=10;
speed=30;
i++;
trace(i)
speed=0;
speed = 0
gotoAndStop(3);
speed =0
gotoAndStop(4);
message error
I'm assuming you have a class that is loading this "HERO" class inside itself because you're trying to access MovieClip(parent). I see you're adding fBall to the parent when the user presses the "W" key. I presumed the parent would have a defined object you're accessing via MovieClip(fBall) when I should have just read all of the code.
You have a direct reference to fBall inside this class that fires off onEnterFrame. You can't reference it via MovieClip(parent).fBall as if it's a direct object reference because it's not. And if you were to try to access it as a MovieClip then you'd need to use a getChild* function of MovieClip(parent) to gain access to it via index or name. But you don't need to do that.
Your first class had it correct. Just access fBall directly like this:
if ((!fBall) || (!MovieClip(this.parent).contains(fBall))) { return; }
x += dir * speed
fBall.width += 2
fBall.height += 2
totalfirespeed += 1
totalfirespeed = 0
edit:
In the future you only need to paste the relevant lines of code giving you an error, plus a few lines above and below it. If you need to paste a large amount of code it's advisable to use something that makes code easy to see like:
i did that , but now i cant move the player or use w spell
i get this error
at HERO/onKeyDown()
after pressing W but there are no errors when i enter the frame except that i cant move the player
maybe because this command doesn,t work
x += dir * speed // in on enter frame function
yeah right (maybe you know that already) this class not document class it is the hero class
i can fix the error in the main class but i want to learn how to do that with normal class
fBall.width = 20;
fBall.x = 400
fBall.y = 400
i++;
trace(i)
trace(fBall.name)
Remove the MovieClip(parent) off of any references to fBall in all your code. That class can directly access fBall. Even though you're adding it to the parent display list you still access it in the class directly using fBall. The class still owns the object.
The HERO class extends MovieClip so you don't need to add it to the parent at all. I'm assuming you have a reason for doing so. Adding it to the HERO display list would make it show up as long as HERO was on the parents display list. Although the position of the object would be relative to the position of the HERO.
ohhh , lol yeah i get it now , it was stupid thing but i didn,t notice i
thank you again for your help
just there is one problem left the object doesn,t display after clicking W there is no errors and the object effects work very well
i just cant see it
i will try to fix this problem
thank you dr.murphy
that Permit Debugging is realy helpful
When you add the fBall you still want to add it to the parent. While removing MovieClip(parent) from fBall, you didn't remove the MovieClip(parent) when you were adding it to the parents display list did you? Like in the code I posted above I'm still adding the fBall to the parent via:
So if you did a global find/replace and removed MovieClip(parent) then it might look like:
addChild(fBall);
If your HERO class isn't on the display list then you won't see the fireball anymore so make sure you still have MovieClip(parent) on that line.
i fixed it
it was here
MovieClip(parent).fBall.x =4000!!
thank you for your help
You're welcome and good luck!
You're welcome
Line 56 when I copy your code is exactly what I posted, "if (fBall.stage){". You're checking a property (stage) of something that has not been added to the display list and therefore has no stage property. Please try adding the code I bolded (the easy way) or only add an ENTER_FRAME handler once it has been added to the display list (the better way to reduce wasted cycles).
no that is the old code
the problem came after this
because i dont want fball to be a child for the hero class anymore then i get this error after change all the fBall to MovieClip(parent).fBall
