Cannot update Illustrator CS6 Mac to version 16.0.1
Aug 28, 2012 Aug 28, 2012
I have Illustrator 16.0.0 retail on my Mac running Mountain Lion, and has downloaded he Updater to version 16.0,1
I have Illustrator 16.0.0, version 682 on my system.
When running the Updater, it end up with Installation fail, this update is not applicable for you.
I have tried to uninstall and reinstall Illustrator but the update problem persist.
All other updates went fine. and Adobe Application Manager stated that all my software is up to date, no update
I have just updated Prelude To version 1.0.2 without any problem thru AAM
Help please.
12.6K
Explorer , Aug 28, 2012 Aug 28, 2012
I have solved the problem by downloading the latest version of Adobe Application Manager and install it (version 6.2.122.0).
Then run the Updater for Illustrator 16.0.1. It run fine. Tryy this and let me know whether it work for everybody as it was for me.
Cheer
I'm running into the same problem. I get an Upload Failed message when I attempt to update Illustrator CS6. When I click on the error log link I get the following message:
Adobe Illustrator CS6 Update (version 16.0.1)
Installation failed. Error Code: U44M1P7
Does anyone know what the issue may be and how to solve it?
Thanks.
Same exact error here this morning.
How can you find the error code in Mac? On the error dialog, there is no error code, only the message that the update is not applicable, and ask me contact support
So where can you find the error code in Mac. Can you advise please and how can we solve this problem?
Cheer
Where I can download the Application Manager 6.2?
I had to reinstall Illustrator... then the updater worked!
I have uninstall and reinstall Illustrator but he update still fail. In m ace, update to the latest Adobe Application Manager allow me to update to Illustrator 16,0.1 without any problem.
This method work for y friends too. And there is no need to waste your time uninstall and reinstall Illustrator to run the update.
Hope this help everybody and goodluck
It most definitely does NOT work for me.  I tried the new Application Manager, and the update still fails with the following error:
Is your version a Mac or PC. mine is Mac version. and by the way, on Mac version,Bhee is o error code shown. Where can you get he error code you stated?
It's a Mac.  The error code is linked from the resulting error message - just clicking the word "error" provides the code.
Adobe Employee ,
Aug 29, 2012 Aug 29, 2012
Yapple_Dapple which version of the Adobe Application Manager do you have installed?  You can locate the Adobe Application Manager in Applications/Utilities/Adobe Application Manager/core.
6.2.112.0, installed fresh yesterday.
BTW, this also fails with the same error on my Macbook Pro.  Both machines are running 10.8.1, which has been a little flakey on the Mac Pro 3,1, but pretty solid on the laptop.
Adobe Employee ,
Can you please review your installation log located in Library/Logs/Adobe/Installers to see what maybe the cause.  You can utilize the directions listed in Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html for information regarding how to review the installation log.
The quick summary though is doing a search on the words ERROR and FATAL.  You can then do a search on the code at Adobe.com.  You can also find many of the error codes listed at Installation, launch log errors | CS5, CS5.5, CS6, CCM - http://helpx.adobe.com/x-productkb/global/installation-launch-log-errors-creative.html.
Here's the final entry in the Illustrator installer log:
START - Installer Session
RIBS version: 6.2.10.0
OSX version: 10.8.1
::START TIMER:: [Total Timer]
CHECK: Single instance running
CHECK : Credentials
Load Deployment File
deploymentFile option not given
CHECK : Another Native OS installer already running
Create Required Folders
Assuming install mode
Looking up install source path
Sync Media DB ...
::START TIMER:: [Sync Media DB]
Pre check media db sync
End of Pre check media db sync. Exit code: 0
:: END TIMER :: [Sync Media DB] took 20 milliseconds (0.02 seconds)
Ready to initialize session to start with ...
::START TIMER:: [CreatePayloadSession]
-------------------- BEGIN - Updating Media Sources - BEGIN --------------------
Updated source path: /Users/ericdarling/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.1
Updating media info for: {449931D3-C2C4-4817-919E-9774ECE85BFF}
Ignoring original data since install source is local
  Type: 0, Volume Order: 1, Media Name:
  Path: /Users/ericdarling/Library/Caches/Adobe/AAMUpdater/AdobeIllustrator16-mul/16.1/payloads/AdobeIllustrator16-mul-180812133154/AdobeIllustrator16-mul-180812133154.dmg
--------------------  END  - Updating Media Sources -  END  --------------------
Supported RIBS version range: [0.0.66.0,6.2.10.0]
----------------- CreatePayloadSession: machine is x86 ---------------
[       0] Tue Aug 28 18:34:47 2012  INFO
______ Verify Dependency Subscribers ______
BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
  {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0: 0 (0,0)
END Operation order for all session payloads: mediaGroup (requires,satisfies)
Patch {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0 can be applied to product {AAF0D225-F129-40F2-916E-12E28DBD19ED} Adobe Illustrator CS6 Core 16.0.0.0
Overwrite property "extensionsOnly" to: 1
Overwrite property "mode" to: silent
Overwrite property "patchesOnly" to: 1
Overwrite property "workflow" to: updater
Found payload actions:
Deciding what installer mode to use...
BEGIN Setting requested payload actions
Value returned on lookup of payload: {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0 is: false
Action string for {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0  is install
END Setting requested payload actions
Collected advanced path check information for INSTALLDIR
INSTALLDIR is a well-formed path
INSTALLDIR is not the root path
INSTALLDIR is on a local volume
INSTALLDIR is on a writable volume
INSTALLDIR is not on a case sensitive volume
INSTALLDIR passed path basic path validation: /Applications
BEGIN InstallOperationsQueue Unordered operations
  {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0:  with operation install
END InstallOperationsQueue Unordered operations
BEGIN InstallOperationsQueue Ordered operations
END InstallOperationsQueue Ordered operations
Payloads passed preflight validation.
Call PreSession Custom Hook
Calling the custom action code for pre-install for payload {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0
::START TIMER:: [Payload Operation :{449931D3-C2C4-4817-919E-9774ECE85BFF}]
[       1] Tue Aug 28 18:34:47 2012  INFO
Installer Operation: PayloadInstaller
Request to install payload
Payload {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0: Calling ARKEngine from path /Applications/Utilities/Adobe Application Manager/DECore/DE6/resources
[       1] Tue Aug 28 18:34:49 2012  INFO
CustomizedPatch property not found in database
Beginning installation for payload at /private/tmp/.tempdirfrEfqL18/Install.db
Attempting to patch file: "/Applications/Adobe Illustrator CS6/Plug-ins.localized/Illustrator Formats.localized/SVG File Format.aip/Contents/Resources/it.lproj/InfoPlist.strings"(Seq 3)
[       1] Tue Aug 28 18:34:49 2012 ERROR
DF019: Unable to locate file to patch at "/Applications/Adobe Illustrator CS6/Plug-ins.localized/Illustrator Formats.localized/SVG File Format.aip/Contents/Resources/it.lproj/InfoPlist.strings"(Seq 3)
DW063: Command ARKPatchCommand failed.(Seq 3)
Completing installation for payload at /private/tmp/.tempdirfrEfqL18/Install.db
[       0] Tue Aug 28 18:34:49 2012  INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{449931D3-C2C4-4817-919E-9774ECE85BFF}] took 1516 milliseconds (1.516 seconds)
User specified overrideFile:
The csu inventory was not updated for payload {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0, value of local var is -1
Calling the ROLLBACK custom action code for pre-install for payload {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0
No operation.  We're done:
[       0] Tue Aug 28 18:34:51 2012  INFO
Total components installed: 0
Total components repaired: 0
Total components removed: 0
[       0] Tue Aug 28 18:34:51 2012 ERROR
DW050: The following payload errors were found during install:
DW050:  - Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul: Install failed
Call PostSession Custom Hook
:: END TIMER :: [Total Timer] took 11646 milliseconds (11.646 seconds) DTR = 4.12159 KBPS (0.00402499 MBPS)
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 3 error(s), 0 warning(s)
----------- Payload: {449931D3-C2C4-4817-919E-9774ECE85BFF} Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul 16.0.1.0 -----------
ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Illustrator CS6/Plug-ins.localized/Illustrator Formats.localized/SVG File Format.aip/Contents/Resources/it.lproj/InfoPlist.strings"(Seq 3)
ERROR: DW063: Command ARKPatchCommand failed.(Seq 3)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Adobe Illustrator CS6 Core_16.0.1_AdobeIllustrator16-mul: Install failed
Please search the above error/warning string(s) to find when the error occurred.
These errors resulted in installer Exit Code mentioned below.
[       0] Tue Aug 28 18:34:52 2012  INFO
Exit Code: 7 - Unable to complete Silent workflow.
Please see specific errors and warnings for troubleshooting. For example, ERROR: DF019, DW063 ...
END - Installer Session
Adobe Employee ,
The failure appears to be at DF019: Unable to locate file to patch at "/Applications/Adobe Illustrator CS6/Plug-ins.localized/Illustrator Formats.localized/SVG File Format.aip/Contents/Resources/it.lproj/InfoPlist.strings"
If you view the package and navigate to that directory does the InfoPlist.strings file exist?  If so can you also verify the permissions on the file so that system and admin groups have read & write access.
I've only got an en.lproj folder in the Contents/Resrouces folder.  That folder does have the InfoPlist.strings file.  Should I expect to also have an it.lproj folder there?  Are those language files?
Adobe Employee ,
Yes I have verified on both my Creative Cloud and perpetual version installations.  This is what is causing your failure.
I thought you already posted that you had removed and reinstalled Illustrator?  Regardless you will need to do so again because it appears your current installation is incomplete.
Sep 04, 2012 Sep 04, 2012
I got the same problem as user yapple_dapple and read all of the above comments but this is unacceptable. I mean I paid a lot of money for this product and suddenly it doesn't work anymore!
Will this problem be fixed within a new soon to be coming update? I don't have time to reinstall Illustrator and hoping for the best.
Hi Jeff, no it was someone else who had reported they tried re-installing from scratch.  I did that, and the update worked.  I am glad Adobe allows me to download the installer perpetually - that's good customer service!  Thanks, Jeff.
Adobe Employee ,
Excellent thank you for the update Yapple_dapple!
Sep 07, 2012 Sep 07, 2012
Gentlemen, I've just downloaded a stand-alone 16.0.1 update (AAM v. 6.2.112.0 didn't see it for some reason) and that's what I get tying to install it:
Any thoughts? Please?
Adobe Employee ,
Andrew.Kramar please try the steps listed in message #15 to review your installation log for the update.  Also unless you installation log matches exactly what Yapple_Dapple posted in message #16 I might recommend creating a new thread regarding your difficulties.  This thread is already quite difficult to read due to the previously posted install log.
