1. Re: Color Picker in Flash CS6 Changing My Picked Color
Line Sep 4, 2012 2:38 PM (in response to rryanhayes79)Did you resolve this issue? I'm having a similar one.
2. Re: Color Picker in Flash CS6 Changing My Picked Color
rryanhayes79 Sep 4, 2012 2:56 PM (in response to Line)Nope, I have had no resolution to this problem as of yet. I have submitted a bug to Adobe but have not heard anything from them yet either.
3. Re: Color Picker in Flash CS6 Changing My Picked Color
Line Sep 5, 2012 9:05 AM (in response to rryanhayes79)Hey Ryan, my problem was solved for my monitor. Perhaps it may work for your laptop screen:
http://forums.adobe.com/thread/1060487?tstart=0
-Line
4. Re: Color Picker in Flash CS6 Changing My Picked Color
rryanhayes79 Sep 5, 2012 10:35 AM (in response to Line)Unfortunately this did not fix the bug I am experiencing. Its also not just limited to my laptop monitor, but also occurs on the external display my monitor is connected to, which leads me to believe it is a software issue. Thanks for looking out though!
5. Re: Color Picker in Flash CS6 Changing My Picked Color
rryanhayes79 Sep 25, 2012 12:33 PM (in response to rryanhayes79)I just wanted to update this thread. Today I installed the update for Flash CS6 and I am still experiencing the exact same bug. It has not been fixed.
6. Re: Color Picker in Flash CS6 Changing My Picked Color
balgram Feb 26, 2013 11:11 AM (in response to rryanhayes79)I'm updating this thread mainly because it's the only thread I could find that describes my exact issue. I am having this problem. When I select a color using the color picker, it settles on a different, lighter color. THIS HAPPENS EVEN WHEN I ENTER THE HEX CODE VALUE. It's like Flash is auto-correcting a problem that doesn't exist. Help? This is becoming a serious problem for me!
Also Flash CS6, Mac OS X (10.8.2). The monitor I'm using shouldn't be relevant; Flash is literally changing the hex code value after I type it in or select it.
EDIT: Just did some research, found out that Flash isn't 10.8 compatible. When is that going to be fixed?
7. Re: Color Picker in Flash CS6 Changing My Picked Color
stduerr-swa Aug 28, 2013 2:12 AM (in response to rryanhayes79)Same with me, in both Flash and FW CS6.
8. Re: Color Picker in Flash CS6 Changing My Picked Color
SujaiS Aug 30, 2013 4:36 AM (in response to stduerr-swa)This could be because the System Color settings on MAC OSX 10.8 is set to a value other than sRGB. To reset System Color Settings, do the following:
- On MAC OSX 10.8, go to System Preferences > Displays > Color.
- Select the sRGB IEC61966-2.1 display profile.
Please check if changing this setting works?
-Sujai
