I need to create mailing/address labels. There will be multiple addressees and most likely mutiple pages using Avery 5160. We are using coldfusion as the front end and oracle as the backend. My thought is to use an avery 5160 template which I found on the web, insert text fields for the database fields and somehow merge. But I'm not sure if this is the right way to approach it OR if this is the way to approach it...how? Do I set up each label with the text fields for the name, address etc. this would be 3 labels across and 10 down for a total of 30? We have Livecycle Designer ES 8.2 and Acrobat Prof 9 to use.
Sherry
Total Likes
