Locked
FMS stop recording video in middle of recording
Aug 31, 2012 Aug 31, 2012
I am trying to record the h.264 long video through fms server side code(more than 2 hour), but video recording is stopped before I stop publishing the video, and it’s not throwing any error in server side as well as client side, I have given the video recording code
stream=Stream.get("mp4:testStream.f4v");
  if(stream)
  stream.record("append");
  stream.play(streamName, -1, -1);
and recorded video also not playing fine, its stuck in middle. should I need to modify anything? Any help are appreciated......
2.1K
Sep 05, 2012 Sep 05, 2012
Please use the recommended Application - DVRCast - for Server Side recording and report back if you are still not able to record content.
Shiven
Sep 06, 2012 Sep 06, 2012
Cant I record the stream with out using the DVR cast application? If I must to use DVRCast application please could you tell me whats the reason for that. what should I do for recording the stream using DVRCast
Adobe Employee ,
Can you paste the whole server-side code and what are you using for publishing? And is there set pattern where your recording stops? Can you check your server-side core.00.logs and see if you see any recording failures?
For publishing I am using the action script code, It stops after 40 min some time its recording fine upto two hours I count find where its stoping and why its happening, I am giving the server side code and client publishing code and the log with this
Server side code
application.onAppStart = function() {      trace("app fme started!");      application.message_so = SharedObject.get( "message");      // Initialize the unique user ID      application.noOfUser = 0; } application.onConnect = function(client) {      this.acceptConnection(client);      client.id = "u" + application.noOfUser++;               client.recordStream=function(streamName)      {                trace('record called');                stream=Stream.get("mp4:"+streamName+".f4v");                if(stream)                {                     stream.record("append");                                        stream.play(streamName, -1, -1);                     live=true;                                         }      }           client.stopRecordingStream=function(streamName)      {           stream=Stream.get("mp4:"+streamName+".f4v");           if(stream)           {                stream.flush();                msg=stream.record(false);                live=false;                stream.play(false);                         }      }      } application.onPublish = function (client, stream) { } application.onUnpublish = function(client, stream) {
client side code
private function publishCamera():void {
     ns = new NetStream(nc);
     if(cmbEncoder.selectedItem.data=="Sorenson")
          ns.videoStreamSettings=new VideoStreamSettings();
     else//H.264
          var h264Codec:H264VideoStreamSettings=new H264VideoStreamSettings();
          h264Codec.setKeyFrameInterval(12);
          h264Codec.setProfileLevel(H264Profile.BASELINE, H264Level.LEVEL_5_1);
          ns.videoStreamSettings=h264Codec;
     cam = Camera.getCamera(cmbCamera.selectedIndex.toString());
     mic = Microphone.getMicrophone(cmbMicroPhone.selectedIndex);
     var resolutionWidth:Number;
     var resolutionHeight:Number;
     var videoQuality:Number;
     resolutionWidth=768;
     resolutionHeight=576;
     ns.client = this;
     ns.addEventListener(NetStatusEvent.NET_STATUS, onNetStatus);
     ns.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler);
     videoQuality=(Number(cmbBandWidth.selectedItem.data)/8)*1024;
     cam.setQuality(videoQuality, 0);
     /* Set the mode of the camera component
     width, height, fps
     this will be the recorded size of the video
     cam.setMode(resolutionWidth,resolutionHeight,12);
     mic.rate = 11;
     ns.attachCamera(cam);
     ns.attachAudio(mic);
     ns.publish("mp4:testStream.f4v");
     nc.call('recordStream',null,'testStream');
core.00.log
#Version: 1.0
#Start-Date: 2012-09-07 10:06:18
#Software: Adobe Flash Media Server 4.0.0 r1121 x86
#Date: 2012-09-07
#Fields: date          time          x-pid          x-status          x-ctx          x-comment
2012-09-07          10:06:18          1180          (i)2631174          Listener started ( _defaultRoot_ ) : 192.168.173.184:19350 (rtmfp-core)/v4          -
2012-09-07          10:06:18          1180          (i)2631174          Listener started ( _defaultRoot_ ) : 127.0.0.1:19350 (rtmfp-core)/v4          -
2012-09-07          10:06:18          1180          (i)2631509          Public rtmfp-core addresses for listener _defaultRoot_ are: 192.168.173.184:19350;127.0.0.1:19350          -
2012-09-07          10:06:18          1180          (i)2581246          Core (1180) sending register cmd to edge.          -
#Date: 2012-09-07
2012-09-07          11:39:02          5696          (i)2581237          Starting admin app on core (5696).          -
2012-09-07          11:39:02          5696          (i)2581238          Core (5696) connecting to admin.          -
2012-09-07          11:39:02          5696          (i)2581231          Core (5696) connected to admin.          -
2012-09-07          11:39:02          5696          (i)2631174          Listener started ( _defaultRoot_ ) : 192.168.173.184:19352 (rtmfp-core)/v4          -
2012-09-07          11:39:02          5696          (i)2631174          Listener started ( _defaultRoot_ ) : 127.0.0.1:19352 (rtmfp-core)/v4          -
2012-09-07          11:39:02          5696          (i)2631509          Public rtmfp-core addresses for listener _defaultRoot_ are: 192.168.173.184:19352;127.0.0.1:19352          -
2012-09-07          11:39:02          5696          (i)2581246          Core (5696) sending register cmd to edge.          -
2012-09-07          11:39:02          5696          (i)2581234          Core (5696) connection to admin accepted.          -
Adobe Employee ,
Sep 07, 2012 Sep 07, 2012
Your code looks ok and difficult to conclude what's goign wrong. Can you paste your application logs too? If there is a way to attach can you attach all your logs and server and client side source files. If there is no way to attach here - please drop me any email with attachments to rchari@adobe.com
Jan 30, 2013 Jan 30, 2013
Where will be the application log? can you please give me the code which working fine? am I missing anything?
Adobe Employee ,
You can find applications logs in <FMSinstalldir>/logs/_defaultVHost_/<yourApplication>
