I'm creating navigational elements in photoshop and I want to be able to adjust the outline by itself, as well as there are some elements that are only an outline with no fill. How do I create shape outlines without the fill?
Adobe Photoshop CS4, PC.
they changed this a few times, on one version there was a stroke style option to do it.
the earlier versions there was a long winded way of
1. Draw your rounded rect etc with the tool
2. Ctrl-select that layer to select the shape
3. Create a new layer
4. Edit -> Stroke... to create the outline
5. Delete the original shape
another was was Select->Modify->Border
don't forget there is a stroke from the drop down menus not just in effects, this is what you need when you want a stroke on a stroke on a stro
...Copy link to clipboard
don't forget there is a stroke from the drop down menus not just in effects, this is what you need when you want a stroke on a stroke on a stroke etc
Both useful answers, thanks so much for taking the time to reply!
I see the option available there, however it is shaded out when I select the shape I wish to apply changes to. how can I solve this problem?
