I have to migrate the website to a server that is running CF
MX and the site being created in CF 5.0 is not compatable. When i
go to the site location on the new server, i get the following
error message. Does anyone know how i can update the site?
Error Occurred While Processing Request
Attribute validation error for tag query.
The tag does not have an attribute called CONNECTSTRING. The
valid attribute(s) are name, datasource, dbtype, sql, username,
password, maxrows, blockfactor, timeout, cachedafter, cachedwithin,
debug.
Please try the following:
Enable Robust Exception Information to provide greater detail
about the source of errors. In the Administrator, click Debugging
& Logging > Debugging Settings, and select the Robust
Exception Information option.
Check the ColdFusion documentation to verify that you are
using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1;
SV1; .NET CLR 1.1.4322; Alexa Toolbar)
Remote Address 70.176.124.115
Referrer
Date/Time 27-Nov-06 10:19 AM
