I have tried a number of times to download Adobe Flash Player. It looks like it is installing, then I get a message that it has installed successfully. However, when I try to use it, I get a new message that I need to download Flash Player. If I go to "all programs", I see that it never really installed. I have an HP running Vista (32 bit). My browser is Internet Explorer. Can you help?
Hello there ^^
Are you sure you installed the ActiveX version, not the other one (which is for kinda like every browser except IE) ?
Do you get the message on every website ?
What does this page : http://www.adobe.com/software/flash/about/ say about the version you currently have installed ?
I used your link to get to Adobe and I downloaded the version for IE and still, no luck. Thanks so much for your thoughts.
Pat,
You rock! I "deselected" ActiveX filtering as you suggested and Flash Player worked fine! Eureka!! Thank you soooo much for your help!! --KM
Moved to Installing Flash Player
