14 Replies Latest reply on Sep 6, 2012 1:06 AM by hans-g.
    Question: My spry menu bar is not displaying correctly in Dreamweaver
    alrosales
      Hello,
      I am  new to Dreamweaver CS5, so coding isn't my area of expertise. My problem with my spry menu bar is that it does not display the tabs on the menu bar correctly. When I try to apply new changes to the CSS of the horizontal menu bar, half of the tabs will change and the other half will not. Also, I am unable to drag and move the menu bar itself around, a function that I was once able to do before. At times, only one tab of the menu bar will display itself, without any of the other tabs as well.
      I have a hunch that my problems stem from some coding errors in the SpryMenuBarHorizontal.css, and possibly in the SpryMenuBar.js. On the CSS Styles panel, my SpryMenuBarHorizontal.CSS list reads as follows:
      I also have a hunch that something about this line-up is also incorrect, but I don't exactly know what the problem is.
      Here is what my coding for my SpryMenuBarHorizontal.css looks like right now:
      ____________________________
      @charset "UTF-8";
      /* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
      /* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
      LAYOUT INFORMATION: describes box model, positioning, z-order
      /* The outermost container of the Menu Bar, an auto width box with no margin or padding */
      ul.MenuBarHorizontal
          margin: 0;
          padding: 0;
          list-style-type: none;
          font-size: 100%;
          cursor: default;
          width: auto;
          text-align: center;
      /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
      ul.MenuBarActive
          z-index: 1000;
      /* Menu item containers, position children relative to this container and are a fixed width */
      ul.MenuBarHorizontal li
          margin: 0;
          padding: 0;
          font-size: 100%;
          position: relative;
          text-align: left;
          cursor: pointer;
          width: 8em;
          float: left;
          left: 10;
          top: 10;
          height: 10;
      /* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
      ul.MenuBarHorizontal ul
          margin: 0;
          padding: 0;
          font-size: 100%;
          z-index: 1020;
          cursor: default;
          width: 8.2em;
          position: absolute;
          left: -1000em;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
          left: auto;
      /* Menu item containers are same fixed width as parent */
      ul.MenuBarHorizontal ul li
          width: 8.2em;
      /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
      ul.MenuBarHorizontal ul ul
          position: absolute;
          margin: -5% 0 0 95%;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
      ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
          left: auto;
          top: 0;
      DESIGN INFORMATION: describes color scheme, borders, fonts
      /* Submenu containers have borders on all sides */
          border: 1px solid #CCC;
          text-align: left;
      /* Menu items are a light gray block with padding and no text decoration */
      ul.MenuBarHorizontal a
          display: block;
          cursor: pointer;
          background-color: #000;
          padding: 0.5em 0.75em;
          color: #FFF;
          text-decoration: none;
          font-family: Futura;
          float: none;
      /* Menu items that have mouse over or focus have a blue background and white text */
      ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
          background-color: #C00;
          color: #FFF;
      /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
      ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
          color: #FFF;
      SUBMENU INDICATION: styles if there is a submenu under a given menu item
      /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
          background-image: url(SpryMenuBarDown.gif);
          background-repeat: no-repeat;
          background-position: 95% 50%;
          text-align: center;
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
          background-image: url(SpryMenuBarRight.gif);
      /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
          background-image: url(SpryMenuBarDownHover.gif);
      ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
          background-image: url(SpryMenuBarRightHover.gif);
      BROWSER HACKS: the hacks below should not be changed unless you are an expert
      /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
      ul.MenuBarHorizontal iframe
          position: absolute;
          z-index: 1010;
          filter:alpha(opacity:0.1);
      /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
      @media screen, projection
          ul.MenuBarHorizontal li.MenuBarItemIE
          display: block;
          f\loat: left;
          background: #FFF;
      _________________________________
      And here is what my SpryMenuBar.js coding looks like right now too:
      SpryMenuBar.js
      This file handles the JavaScript for Spry Menu Bar.  You should have no need
      to edit this file.  Some highlights of the MenuBar object is that timers are
      used to keep submenus from showing up until the user has hovered over the parent
      menu item for some time, as well as a timer for when they leave a submenu to keep
      showing that submenu until the timer fires.
      (function() { // BeginSpryComponent
      if (typeof Spry == "undefined") window.Spry = {}; if (!Spry.Widget) Spry.Widget = {};
      Spry.BrowserSniff = function()
          var b = navigator.appName.toString();
          var up = navigator.platform.toString();
          var ua = navigator.userAgent.toString();
          this.mozilla = this.ie = this.opera = this.safari = false;
          var re_opera = /Opera.([0-9\.]*)/i;
          var re_msie = /MSIE.([0-9\.]*)/i;
          var re_gecko = /gecko/i;
          var re_safari = /(applewebkit|safari)\/([\d\.]*)/i;
          var r = false;
          if ( (r = ua.match(re_opera))) {
              this.opera = true;
              this.version = parseFloat(r[1]);
          } else if ( (r = ua.match(re_msie))) {
              this.ie = true;
          } else if ( (r = ua.match(re_safari))) {
              this.safari = true;
              this.version = parseFloat(r[2]);
          } else if (ua.match(re_gecko)) {
              var re_gecko_version = /rv:\s*([0-9\.]+)/i;
              r = ua.match(re_gecko_version);
              this.mozilla = true;
          this.windows = this.mac = this.linux = false;
          this.Platform = ua.match(/windows/i) ? "windows" :
                          (ua.match(/linux/i) ? "linux" :
                          (ua.match(/mac/i) ? "mac" :
                          ua.match(/unix/i)? "unix" : "unknown"));
          this[this.Platform] = true;
          this.v = this.version;
          if (this.safari && this.mac && this.mozilla) {
              this.mozilla = false;
      Spry.is = new Spry.BrowserSniff();
      // Constructor for Menu Bar
      // element should be an ID of an unordered list (<ul> tag)
      // preloadImage1 and preloadImage2 are images for the rollover state of a menu
      Spry.Widget.MenuBar = function(element, opts)
          this.init(element, opts);
      Spry.Widget.MenuBar.prototype.init = function(element, opts)
          this.element = this.getElement(element);
          // represents the current (sub)menu we are operating on
          this.currMenu = null;
          this.showDelay = 250;
          this.hideDelay = 600;
          if(typeof document.getElementById == 'undefined' || (navigator.vendor == 'Apple Computer, Inc.' && typeof window.XMLHttpRequest == 'undefined') || (Spry.is.ie && typeof document.uniqueID == 'undefined'))
              // bail on older unsupported browsers
              return;
          // Fix IE6 CSS images flicker
          if (Spry.is.ie && Spry.is.version < 7){
              try {
                  document.execCommand("BackgroundImageCache", false, true);
              } catch(err) {}
          this.upKeyCode = Spry.Widget.MenuBar.KEY_UP;
          this.downKeyCode = Spry.Widget.MenuBar.KEY_DOWN;
          this.leftKeyCode = Spry.Widget.MenuBar.KEY_LEFT;
          this.rightKeyCode = Spry.Widget.MenuBar.KEY_RIGHT;
          this.escKeyCode = Spry.Widget.MenuBar.KEY_ESC;
          this.hoverClass = 'MenuBarItemHover';
          this.subHoverClass = 'MenuBarItemSubmenuHover';
          this.subVisibleClass ='MenuBarSubmenuVisible';
          this.hasSubClass = 'MenuBarItemSubmenu';
          this.activeClass = 'MenuBarActive';
          this.isieClass = 'MenuBarItemIE';
          this.verticalClass = 'MenuBarVertical';
          this.horizontalClass = 'MenuBarHorizontal';
          this.enableKeyboardNavigation = true;
          this.hasFocus = false;
          // load hover images now
          if(opts)
              for(var k in opts)
                  if (typeof this[k] == 'undefined')
                      var rollover = new Image;
                      rollover.src = opts[k];
              Spry.Widget.MenuBar.setOptions(this, opts);
          // safari doesn't support tabindex
          if (Spry.is.safari)
              this.enableKeyboardNavigation = false;
          if(this.element)
              this.currMenu = this.element;
              var items = this.element.getElementsByTagName('li');
              for(var i=0; i<items.length; i++)
                  if (i > 0 && this.enableKeyboardNavigation)
                      items[i].getElementsByTagName('a')[0].tabIndex='-1';
                  this.initialize(items[i], element);
                  if(Spry.is.ie)
                      this.addClassName(items[i], this.isieClass);
                      items[i].style.position = "static";
              if (this.enableKeyboardNavigation)
                  var self = this;
                  this.addEventListener(document, 'keydown', function(e){self.keyDown(e); }, false);
              if(Spry.is.ie)
                  if(this.hasClassName(this.element, this.verticalClass))
                      this.element.style.position = "relative";
                  var linkitems = this.element.getElementsByTagName('a');
                  for(var i=0; i<linkitems.length; i++)
                      linkitems[i].style.position = "relative";
      Spry.Widget.MenuBar.KEY_ESC = 27;
      Spry.Widget.MenuBar.KEY_UP = 38;
      Spry.Widget.MenuBar.KEY_DOWN = 40;
      Spry.Widget.MenuBar.KEY_LEFT = 37;
      Spry.Widget.MenuBar.KEY_RIGHT = 39;
      Spry.Widget.MenuBar.prototype.getElement = function(ele)
          if (ele && typeof ele == "string")
              return document.getElementById(ele);
          return ele;
      Spry.Widget.MenuBar.prototype.hasClassName = function(ele, className)
          if (!ele || !className || !ele.className || ele.className.search(new RegExp("\\b" + className + "\\b")) == -1)
              return false;
          return true;
      Spry.Widget.MenuBar.prototype.addClassName = function(ele, className)
          if (!ele || !className || this.hasClassName(ele, className))
              return;
          ele.className += (ele.className ? " " : "") + className;
      Spry.Widget.MenuBar.prototype.removeClassName = function(ele, className)
          if (!ele || !className || !this.hasClassName(ele, className))
              return;
          ele.className = ele.className.replace(new RegExp("\\s*\\b" + className + "\\b", "g"), "");
      // addEventListener for Menu Bar
      // attach an event to a tag without creating obtrusive HTML code
      Spry.Widget.MenuBar.prototype.addEventListener = function(element, eventType, handler, capture)
          try
              if (element.addEventListener)
                  element.addEventListener(eventType, handler, capture);
              else if (element.attachEvent)
                  element.attachEvent('on' + eventType, handler);
          catch (e) {}
      // createIframeLayer for Menu Bar
      // creates an IFRAME underneath a menu so that it will show above form controls and ActiveX
      Spry.Widget.MenuBar.prototype.createIframeLayer = function(menu)
          var layer = document.createElement('iframe');
          layer.tabIndex = '-1';
          layer.src = 'javascript:""';
          layer.frameBorder = '0';
          layer.scrolling = 'no';
          menu.parentNode.appendChild(layer);
          layer.style.left = menu.offsetLeft + 'px';
          layer.style.top = menu.offsetTop + 'px';
          layer.style.width = menu.offsetWidth + 'px';
          layer.style.height = menu.offsetHeight + 'px';
      // removeIframeLayer for Menu Bar
      // removes an IFRAME underneath a menu to reveal any form controls and ActiveX
      Spry.Widget.MenuBar.prototype.removeIframeLayer =  function(menu)
          var layers = ((menu == this.element) ? menu : menu.parentNode).getElementsByTagName('iframe');
          while(layers.length > 0)
              layers[0].parentNode.removeChild(layers[0]);
      // clearMenus for Menu Bar
      // root is the top level unordered list (<ul> tag)
      Spry.Widget.MenuBar.prototype.clearMenus = function(root)
          var menus = root.getElementsByTagName('ul');
          for(var i=0; i<menus.length; i++)
              this.hideSubmenu(menus[i]);
          this.removeClassName(this.element, this.activeClass);
      // bubbledTextEvent for Menu Bar
      // identify bubbled up text events in Safari so we can ignore them
      Spry.Widget.MenuBar.prototype.bubbledTextEvent = function()
          return Spry.is.safari && (event.target == event.relatedTarget.parentNode || (event.eventPhase == 3 && event.target.parentNode == event.relatedTarget));
      // showSubmenu for Menu Bar
      // set the proper CSS class on this menu to show it
      Spry.Widget.MenuBar.prototype.showSubmenu = function(menu)
          if(this.currMenu)
              this.clearMenus(this.currMenu);
          if(menu)
              this.addClassName(menu, this.subVisibleClass);
              if(typeof document.all != 'undefined' && !Spry.is.opera && navigator.vendor != 'KDE')
                  if(!this.hasClassName(this.element, this.horizontalClass) || menu.parentNode.parentNode != this.element)
                      menu.style.top = menu.parentNode.offsetTop + 'px';
              if(Spry.is.ie && Spry.is.version < 7)
                  this.createIframeLayer(menu);
          this.addClassName(this.element, this.activeClass);
      // hideSubmenu for Menu Bar
      // remove the proper CSS class on this menu to hide it
      Spry.Widget.MenuBar.prototype.hideSubmenu = function(menu)
          if(menu)
              this.removeClassName(menu, this.subVisibleClass);
                  menu.style.top = '';
                  menu.style.left = '';
                  this.removeIframeLayer(menu);
      // initialize for Menu Bar
      // create event listeners for the Menu Bar widget so we can properly
      // show and hide submenus
      Spry.Widget.MenuBar.prototype.initialize = function(listitem, element)
          var opentime, closetime;
          var link = listitem.getElementsByTagName('a')[0];
          var submenus = listitem.getElementsByTagName('ul');
          var menu = (submenus.length > 0 ? submenus[0] : null);
          if(menu)
              this.addClassName(link, this.hasSubClass);
          if(!Spry.is.ie)
              // define a simple function that comes standard in IE to determine
              // if a node is within another node
              listitem.contains = function(testNode)
                  // this refers to the list item
                  if(testNode == null)
                      return false;
                  if(testNode == this)
                      return true;
                  else
                      return this.contains(testNode.parentNode);
          // need to save this for scope further down
          var self = this;
          this.addEventListener(listitem, 'mouseover', function(e){self.mouseOver(listitem, e);}, false);
          this.addEventListener(listitem, 'mouseout', function(e){if (self.enableKeyboardNavigation) self.clearSelection(); self.mouseOut(listitem, e);}, false);
              this.addEventListener(link, 'blur', function(e){self.onBlur(listitem);}, false);
              this.addEventListener(link, 'focus', function(e){self.keyFocus(listitem, e);}, false);
      Spry.Widget.MenuBar.prototype.keyFocus = function (listitem, e)
          this.lastOpen = listitem.getElementsByTagName('a')[0];
          this.addClassName(this.lastOpen, listitem.getElementsByTagName('ul').length > 0 ? this.subHoverClass : this.hoverClass);
          this.hasFocus = true;
      Spry.Widget.MenuBar.prototype.onBlur = function (listitem)
          this.clearSelection(listitem);
      Spry.Widget.MenuBar.prototype.clearSelection = function(el){
          //search any intersection with the current open element
          if (!this.lastOpen)
              return;
          if (el)
              el = el.getElementsByTagName('a')[0];
              // check children
              var item = this.lastOpen;
              while (item != this.element)
                  var tmp = el;
                  while (tmp != this.element)
                      if (tmp == item)
                          return;
                      try{
                          tmp = tmp.parentNode;
                      }catch(err){break;}
                  item = item.parentNode;
              this.hideSubmenu(item.parentNode);
              var link = item.getElementsByTagName('a')[0];
              this.removeClassName(link, this.hoverClass);
              this.removeClassName(link, this.subHoverClass);
          this.lastOpen = false;
      Spry.Widget.MenuBar.prototype.keyDown = function (e)
          if (!this.hasFocus)
              return;
          if (!this.lastOpen)
              return;
          var e = e|| event;
          var listitem = this.lastOpen.parentNode;
          var link = this.lastOpen;
          var hasSubMenu = (menu) ? true : false;
          var opts = [listitem, menu, null, this.getSibling(listitem, 'previousSibling'), this.getSibling(listitem, 'nextSibling')];
          if (!opts[3])
              opts[2] = (listitem.parentNode.parentNode.nodeName.toLowerCase() == 'li')?listitem.parentNode.parentNode:null;
          var found = 0;
          switch (e.keyCode){
              case this.upKeyCode:
                  found = this.getElementForKey(opts, 'y', 1);
                  break;
              case this.downKeyCode:
                  found = this.getElementForKey(opts, 'y', -1);
                  break;
              case this.leftKeyCode:
                  found = this.getElementForKey(opts, 'x', 1);
                  break;
              case this.rightKeyCode:
                  found = this.getElementForKey(opts, 'x', -1);
                  break;
              case this.escKeyCode:
              case 9:
                  this.clearSelection();
              default: return;
          switch (found)
              case 0: return;
              case 1:
                  //subopts
                  this.mouseOver(listitem, e);
                  break;
              case 2:
                  //parent
                  this.mouseOut(opts[2], e);
                  break;
              case 3:
              case 4:
                  // left - right
                  this.removeClassName(link, hasSubMenu ? this.subHoverClass : this.hoverClass);
                  break;
          var link = opts[found].getElementsByTagName('a')[0];
          if (opts[found].nodeName.toLowerCase() == 'ul')
              opts[found] = opts[found].getElementsByTagName('li')[0];
          this.addClassName(link, opts[found].getElementsByTagName('ul').length > 0 ? this.subHoverClass : this.hoverClass);
          this.lastOpen = link;
          opts[found].getElementsByTagName('a')[0].focus();
              //stop further event handling by the browser
          return Spry.Widget.MenuBar.stopPropagation(e);
      Spry.Widget.MenuBar.prototype.mouseOver = function (listitem, e)
          if(this.bubbledTextEvent())
              // ignore bubbled text events
              return;
          if (listitem.closetime)
              clearTimeout(listitem.closetime);
          if(this.currMenu == listitem)
          // move the focus too
          if (this.hasFocus)
              link.focus();
          // show menu highlighting
          this.addClassName(link, hasSubMenu ? this.subHoverClass : this.hoverClass);
          if(menu && !this.hasClassName(menu, this.subHoverClass))
              var self = this;
              listitem.opentime = window.setTimeout(function(){self.showSubmenu(menu);}, this.showDelay);
      Spry.Widget.MenuBar.prototype.mouseOut = function (listitem, e)
              return;
          var related = (typeof e.relatedTarget != 'undefined' ? e.relatedTarget : e.toElement);
          if(!listitem.contains(related))
              if (listitem.opentime)
                  clearTimeout(listitem.opentime);
              this.currMenu = listitem;
              // remove menu highlighting
              if(menu)
                  var self = this;
                  listitem.closetime = window.setTimeout(function(){self.hideSubmenu(menu);}, this.hideDelay);
              if (this.hasFocus)
                  link.blur();
      Spry.Widget.MenuBar.prototype.getSibling = function(element, sibling)
          var child = element[sibling];
          while (child && child.nodeName.toLowerCase() !='li')
              child = child[sibling];
          return child;
      Spry.Widget.MenuBar.prototype.getElementForKey = function(els, prop, dir)
          var found = 0;
          var rect = Spry.Widget.MenuBar.getPosition;
          var ref = rect(els[found]);
          var hideSubmenu = false;
          //make the subelement visible to compute the position
          if (els[1] && !this.hasClassName(els[1], this.MenuBarSubmenuVisible))
              els[1].style.visibility = 'hidden';
              this.showSubmenu(els[1]);
              hideSubmenu = true;
          var isVert = this.hasClassName(this.element, this.verticalClass);
          var hasParent = els[0].parentNode.parentNode.nodeName.toLowerCase() == 'li' ? true : false;
          for (var i = 1; i < els.length; i++){
              //when navigating on the y axis in vertical menus, ignore children and parents
              if(prop=='y' && isVert && (i==1 || i==2))
                  continue;
              //when navigationg on the x axis in the FIRST LEVEL of horizontal menus, ignore children and parents
              if(prop=='x' && !isVert && !hasParent && (i==1 || i==2))
                  continue;
              if (els[i])
                  var tmp = rect(els[i]);
                  if ( (dir * tmp[prop]) < (dir * ref[prop]))
                      ref = tmp;
                      found = i;
          // hide back the submenu
          if (els[1] && hideSubmenu){
              this.hideSubmenu(els[1]);
              els[1].style.visibility =  '';
          return found;
      Spry.Widget.MenuBar.camelize = function(str)
          if (str.indexOf('-') == -1){
              return str;
          var oStringList = str.split('-');
          var isFirstEntry = true;
          var camelizedString = '';
          for(var i=0; i < oStringList.length; i++)
              if(oStringList[i].length>0)
                  if(isFirstEntry)
                      camelizedString = oStringList[i];
                      isFirstEntry = false;
                  else
                      var s = oStringList[i];
                      camelizedString += s.charAt(0).toUpperCase() + s.substring(1);
          return camelizedString;
      Spry.Widget.MenuBar.getStyleProp = function(element, prop)
          var value;
          try
              if (element.style)
                  value = element.style[Spry.Widget.MenuBar.camelize(prop)];
              if (!value)
                  if (document.defaultView && document.defaultView.getComputedStyle)
                      var css = document.defaultView.getComputedStyle(element, null);
                      value = css ? css.getPropertyValue(prop) : null;
                  else if (element.currentStyle)
                          value = element.currentStyle[Spry.Widget.MenuBar.camelize(prop)];
          catch (e) {}
          return value == 'auto' ? null : value;
      Spry.Widget.MenuBar.getIntProp = function(element, prop)
          var a = parseInt(Spry.Widget.MenuBar.getStyleProp(element, prop),10);
          if (isNaN(a))
              return 0;
          return a;
      Spry.Widget.MenuBar.getPosition = function(el, doc)
          doc = doc || document;
          if (typeof(el) == 'string') {
              el = doc.getElementById(el);
          if (!el) {
              return false;
          if (el.parentNode === null || Spry.Widget.MenuBar.getStyleProp(el, 'display') == 'none') {
              //element must be visible to have a box
              return false;
          var ret = {x:0, y:0};
          var parent = null;
          var box;
          if (el.getBoundingClientRect) { // IE
              box = el.getBoundingClientRect();
              var scrollTop = doc.documentElement.scrollTop || doc.body.scrollTop;
              var scrollLeft = doc.documentElement.scrollLeft || doc.body.scrollLeft;
              ret.x = box.left + scrollLeft;
              ret.y = box.top + scrollTop;
          } else if (doc.getBoxObjectFor) { // gecko
              box = doc.getBoxObjectFor(el);
              ret.x = box.x;
              ret.y = box.y;
          } else { // safari/opera
              ret.x = el.offsetLeft;
              ret.y = el.offsetTop;
              parent = el.offsetParent;
              if (parent != el) {
                  while (parent) {
                      ret.x += parent.offsetLeft;
                      ret.y += parent.offsetTop;
                      parent = parent.offsetParent;
              // opera & (safari absolute) incorrectly account for body offsetTop
              if (Spry.is.opera || Spry.is.safari && Spry.Widget.MenuBar.getStyleProp(el, 'position') == 'absolute')
                  ret.y -= doc.body.offsetTop;
          if (el.parentNode)
                  parent = el.parentNode;
          else
              parent = null;
          if (parent.nodeName){
              var cas = parent.nodeName.toUpperCase();
              while (parent && cas != 'BODY' && cas != 'HTML') {
                  ret.x -= parent.scrollLeft;
                  ret.y -= parent.scrollTop;
                  if (parent.parentNode)
                      parent = parent.parentNode;
                  else
                      parent = null;
          return ret;
      Spry.Widget.MenuBar.stopPropagation = function(ev)
          if (ev.stopPropagation)
              ev.stopPropagation();
          else
              ev.cancelBubble = true;
          if (ev.preventDefault)
              ev.preventDefault();
          else
              ev.returnValue = false;
      Spry.Widget.MenuBar.setOptions = function(obj, optionsObj, ignoreUndefinedProps)
          if (!optionsObj)
              return;
          for (var optionName in optionsObj)
              if (ignoreUndefinedProps && optionsObj[optionName] == undefined)
                  continue;
              obj[optionName] = optionsObj[optionName];
      })(); // EndSpryComponent
      __________________________________________________________________________
      If anyone could possibly steer me on the right direction with this, I'd be very grateful! I've been struggling with this for about a month now and I feel like I may have only made the situation worse.
      I'm not sure if I have to keep making a new spry assets folder in my website or not or if I have to drag and drop the spry assets into the root folder. I have restarted my website over at least a dozen times by now. I have tried changing folders, dragging and dropping various spry assets folders everywhere and I have also uninstalled and reinstalled my copy of Dreamweaver CS5 in the hopes of getting my spry horizontal menu bar to act normal. I am completely new at Dreamweaver and I really, really need some help with this.
