5 Replies Latest reply: Sep 6, 2012 3:13 PM by Bill Hunt RSS
    Stop Premiere Elements from downloading
    fyip Community Member
      I use a cellular Internet connection and pay per MB
      Every time I open Premiere Elements it uses 25 MB
      Updating is disabled but it has not stopped Premiere Elements
      This does not happen with Photoshop Elements
      This does not happen with any other application
      All application Updating is disabled
      I do Manual Updates for everything
      I have a Wireless Watcher that shows every byte used
      I have tested this with every application
      This only happens with Premiere Elements
      Just to be sure I disabled all Adobe applications
      It does not download anything, Just uses up 25 MB each time
      How can I stop Premiere Elements from using up my MB
        • 1. Re: Stop Premiere Elements from downloading
          Steve Grisetti CommunityMVP
          It might be worth contact Adobe about this.
          The program is designed to be in regular contact Adobe and, when necessary, download updates. Disabling those features might mean doing something that's a bit deeper than we would know about.
          • 2. Re: Stop Premiere Elements from downloading
            Thanks for the reply:
            In Preferences you can choose to not be notified about updates.
            However there is no option not to check for updates.
            So that is what is happening, it is always checking for updates.
            There should be a option to disable checking for updates.
            I disabled updates in Adobe Reader X and Flash Player and
            it does not check for updates for those.
            I check manually for updates because of my connection but
            mainly because when there is a update available I will go to the source
            and download the update and install it myself which is the better way.
            I will look for a way to disable the automatic checking for updates by
            Premiere Elements and if not found I will contact Adobe as you suggested.
            • 3. Re: Stop Premiere Elements from downloading
              Bill Hunt CommunityMVP
              Things might have changed, but Open PrE, and go to Help>Updates. It will run, and if updated, will show that no updates are available. Then, you can Quit, or go to Preferences (or similar syntax). There, you can set how Auto Updates are run, and for which programs.
              Might be worth a try.
              Good luck,
              Hunt
              • 4. Re: Stop Premiere Elements from downloading
                Thanks for the reply, I already tried this, it does work for photoshop Elements but does not work for Premiere Elements.
                • 5. Re: Stop Premiere Elements from downloading
                  You say that it does not work for PrE. Do you mean that that Updates function is missing from your copy, or that it does not stick?
                  Good luck,
                  Hunt
