I am using CF builder 2.01 on Mac OS X, and I am trying to add a server and I am using ColdFusion 10. I am using port 80, not that it should matter the port.
I add "/Applications/ColdFusion10" for the server home and CF builder tells me "Server home is not valid" , but I know it is.
I used the same settings with CF 9. I hope somebody can help me, as I want o start using CF Builder again.
Here is a video of me setting up the server - http://www.screencast.com/t/f4TgszTdY
thank you,
Johnny
What is the Apllication Server used for the server?
For CF10 it should be CF+Tomcat Bundle.
I am using ColdFusion 10, but with JRun on port 80, and not using the default ort 8500 with tomcat.
The location of the server would not be different in either case I don't think.
thanks,
Johnny
I tried using CF+Tomcat Bundle and was able to set up the server
thanks!
Johnny
Have you just tried tabbing out of the Server Home field? I read elsewhere that gets you past the reported error. Be prepared for other issues in your Mac setup, as I can not get past RDS connectivity issues. Good luck.
Oh, yeah. Try specifying the 'cfusion' folder.
/Applications/ColdFusion10/cfusion
Using the CF + Tomcat Bundle is working for me, including RDS. The only thing I can't set up is the web root, glad I can use localhost, but i tried to set up my sites folder, but could not set up the url, so it does not work.
