quote:"Page2.htm" is totally independent of "page3.htm" and "page4.htm". What I was trying to do was use the example of "page1.htm" and "page2.htm" to show how the TOC synchronisation works in some cases but not others. I guess the help I need is for someone to explain to me why "page2.htm" is synchronised with the TOC, but "page4.htm" is not.
Why should the TOC entry for "page2.htm" have any effect on TOC synchronisation for "page3.htm" or "page4.htm"? From your scenario, pages 3 and 4 are not linked to page 2. Was it a typo, or is this a separate problem?
quote:Yes. The TOC links work too (ie if I click the TOC link for "page4.htm", then "page4.htm" will open.
Following on from that, can you confirm that all four pages actually have entries in the TOC.
quote:What browser are you using, and what version of it? Internet Explorer Version 6
Originally posted by: AuthorAnne
quote:Thanks for your advice on handling multiple calls in the TOC to the same topic - I have some deliberately duplicated topic links so this will be useful. However, I don't think this is the cause of problem. I built the TOC myself and there are only 5 duplicated TOC entries, but the problem I am having is occurring with non-duplicated TOC entries.
Originally posted by: MergeThis
Gary, I suspect that you might have multiple calls in the TOC to the same topic, as alluded to when you say:
"It doesn't seem to matter if there are two TOC entries for "page2.htm" - Robohelp will just expand to the first one.[/li]"). That's the default behavior for Webhelp.
