hi i have a site where an index is feeding what is displayed
in a cftree...so if you click on a, this feeds to the query which
displays the tree
SELECT (music info)
FROM (DATABASE)
WHERE (FIRST LETTER OF ARTIST) =#url.(LETTER)#
SO essentially the index has a href which feeds to the url
when clicked, which then determines what is displayed in the tree.
This works well.
Now on the tree the child nodes are albums relating to the
artist, clicking on the album node displays information dynamically
about that album to the right of the screen.....
this works in the same way as the index in that the href for
the cftree feeds to the url, which then determines which album to
show.
The issue is, that as i have two queries being determined by
the URL, they interfere with one another, so you cant use the index
independantly of the the cftree. See my site here to see what i
mean
click
here
When you click on the child node of the tree to display album
info, the cftree dissapears.......
I have managed to achieve what i want using frames....see
here
click here
but i have heard lots of bad things about frames, and you
also cant refer to a particular configuration of a frameset through
the URL with frames, which makes them bad for navigation...
So i want to achieve what i have here with frames through
some other method...i have heard SSI is the way to achieve this,
but i cant get this to work, as the issue with feeding two queries
through the URL still persists here
Any help would be massively appreciated
