I want to use the blog function with BC but I want to remove the horizontal line... I thought that it is a simple <hr> tag, so I removed them in the "Overall Blog Layout" template but it doesn't work.
Does anyone know how to remove this line?
alex
Hi Alex,
Depends on if your using stock BC or a template etc. Likely to be a border-bottom in the css on one of the elements you will need to remove.
Hi Alex,
I just use {tag_blogpostbody} and it makes the line...
I went through all the css files and found now the argument in the css file to remove it...
thank you
cheers
