I searched Google and it didn't come up with any results for the error, so I thought I would try to post it here.
That is the error message I receive. I have no idea what is causing it, but the Flash Player installer fails after that.
Has anybody seen this error or have any idea what is causing it? Any help would be greatly appreciated.
Donavan
Moving this thread to the Installing Flash Player forums.
Could you please let us know the Windows version you use?
Sunil
The computer is a Dell Latitude D620 running Windows XP SP3. Its got 2 GB of RAM, so that should be enough to install and run Adobe Flash Player.
I tried installing Adobe Flash Player 11 and when that failed I tried Flash Player 10, which also failed with the same error above.
That is an error I have never seen before.
What is the file version of KERNEL32.dll in C:\Windows\system32 ?
Can you post the contents of the FlashInstall.log file in C:\Windows\system32\Macromed\Flash
Also, can you try to run this alternate (MSI) installer: http://download.macromedia.com/get/flashplayer/current/licensing/win/install_flash_player_11_active_...
