I'm having trouble, I want my animation to be able to go full screen, but it doesn't seem to be working. I don't know if the problem is in the actionscript or html. Thanks for any help
FullScreenBut.addEventListener(MouseEvent.CLICK, goFullScreen);
function goFullScreen(event:MouseEvent):void
setFullScreen();
function setFullScreen():void
if (stage.displayState== "normal")
stage.displayState="fullScreen";
stage.scaleMode = StageScaleMode.NO_SCALE;
else
stage.displayState="normal";
///////HTML/////////
<body>
<object id="FlashID" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="400" height="200">
<param name="movie" value="animation.swf" />
<param name="quality" value="high" />
<param name="wmode" value="opaque" />
<param name="swfversion" value="15.0.0.0" />
<param name="allowFullScreen" value="true" />
<!-- This param tag prompts users with Flash Player 6.0 r65 and higher to download the latest version of Flash Player. Delete it if you don’t want users to see the prompt. -->
<param name="expressinstall" value="Scripts/expressInstall.swf" />
<!-- Next object tag is for non-IE browsers. So hide it from IE using IECC. -->
<!--[if !IE]>-->
<object type="application/x-shockwave-flash" data="civilWarEraTest12.swf" width="1920" height="1080">
<!--<![endif]-->
<!-- The browser displays the following alternative content for users with Flash Player 6.0 and older. -->
<div>
<h4>Content on this page requires a newer version of Adobe Flash Player.</h4>
<p><a href="http://www.adobe.com/go/getflashplayer"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" width="112" height="33" /></a></p>
</div>
<!--[if !IE]>-->
</object>
<!--<![endif]-->
</object>
<script type="text/javascript">swfobject.registerObject("FlashID");</script>
</body>
oh wait, that html is totally screwed up and can't possibly be something published by flash.
start over. open your fla in flash and publish an html (with allow fullscreen selected) and swf. open the html.
any problems?
if so, copy and paste the html.
try:
<body>
<!--[if !IE]>-->
<!--<![endif]-->
<div>
<p><a href="http://www.adobe.com/go/getflashplayer"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.g if" alt="Get Adobe Flash player" width="112" height="33" /></a></p>
</div>
<!--[if !IE]>-->
</object>
<!--<![endif]-->
</object>
</body>
I published from flash and it works to full screen, but when you click it again it seems to be aligning wrong. I tried top, bottom, middle, but it doesn't change. Is it something else?
any problems?
Thanks worked great. Didn't know that was there.
you're welcome.
Is there a way to resize the stage to 500 width 281 height instead of: stage.displayState="normal"
you can make it look like the stage is 500x281 but you cannot actually change the stage size unless you publish for 100%, use a scalemode of noscale and use javascript to resize the browser window (which you can only do if the window was opened using javascript).
Thank you
you're welcome.
What do you mean? Do I need to change any of the actionScript , because I already published at 100% and I have a function for no scale here.
setFullScreen();
else
As for javaScript, I know know a little bit but not much. Could you point the way? Do I need to remove my button for fullscreen in flash?
so, you want to start with a 400x200 stage and then make the stage appear to be 500x281 after returning from fullscreen?
No I have a 1920x1080 stage that needs to fit in a 500x281 place on a webpage. The problem is that when I go fullscreen the screen is bigger than the moniter and when I exit "normal" == 1920x1080. (I need "normal" to == 500x281 and "fullscreen" == 100% width and 100% height) So the animation is bigger than 500x281, so it looks cropped
when you go fullscreen, your stage should occupy the entire screen (unless you have an flvplayback component somewhere).
does fullscreen look like you expect?
and, copy and paste your the html code you're using to embed your swf.
On some moniters fullscreen is bigger than the screen. I don't think I have a flv playback comp. I check their resolution and if their browser was zoomed in, both neg.
//////////////////////HTML
<div id="flashContent">
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="500" height="281" id="civilWarEraTest12" align="left">
<param name="movie" value="civilWarEraTest12.swf" />
<param name="bgcolor" value="#ffffff" />
<param name="play" value="true" />
<param name="loop" value="true" />
<param name="wmode" value="window" />
<param name="scale" value="showall" />
<param name="menu" value="true" />
<param name="devicefont" value="false" />
<param name="salign" value="" />
<param name="allowScriptAccess" value="sameDomain" />
<!--[if !IE]>-->
<object type="application/x-shockwave-flash" data="civilWarEraTest12.swf" width="500" height="281">
<!--<![endif]-->
<a href="http://www.adobe.com/go/getflash"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" /></a>
<!--[if !IE]>-->
</object>
<!--<![endif]-->
</object>
</div>
try:
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="25%" height="25%" id="civilWarEraTest12" align="left">
<!--[if !IE]>-->
<object type="application/x-shockwave-flash" data="civilWarEraTest12.swf" width="25%" height="25%">
<!--<![endif]-->
<a href="http://www.adobe.com/go/getflash"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.g if" alt="Get Adobe Flash player" /></a>
<!--[if !IE]>-->
</object>
<!--<![endif]-->
</object>
</div>
It's blank. Nothing is there
I believe I fixed the problem by right clicking and checking show all. How do I make it stay and make it automatic for everyone else? (Automatic by they don't have to right click and show all)
click file>publish settings>html and select flash with fullscreen for your template, size percent and select 25 percent width and 25 percent height and for the bottom 4 comboboxes select default, default, center and center.
if that fails, attach a screen shot of that publish settings panel.
Didn't work.
that looks good. now, what is the url to that embedding html?
comment out that scaleMode or change it when returning to normal:
setFullScreen();
//stage.scaleMode = StageScaleMode.NO_SCALE;
else
also, change those percents from 25% to 500/1920 x 100% ~= 26%
Sorry I don't understand
"also, change those percents from 25% to 500/1920 x 100% ~= 26%"
do you mean
25% == 480x270
26% == 500x281
if so it still doesn't work. Samething happens either dimension would fit fine on the page. So I don't think that should really matter.
in your publish settings change 25% to 26%.
the only problem i see at https://dl.dropbox.com/u/72608572/test1.html
is when returning from fullscreen. that problem is caused by your scalemode.
what problem(s) do you see with test1.html?
