Premiere Pro CS6 importing .mp4 = "The file has no audio or video streams."
RobertHorn2012 Sep 5, 2012 5:49 PMHi,
When I import an MP4 clip into Adobe Premiere Pro CS6, I get the following message:
"File Import Failure
151_0010_01.mp4
Error Message
I have the latest Quicktime, and I have reinstalled Premiere Pro CS6 a few times already. If anyone knows a fix for this, I would greatly appreciate it. My system and clip info are found below. Thank you, Robert.
OPERATING SYSTEM
Win 7 Ultimate 64bit
CLIP INFO
Complete name \BPAV\CLPR\151_0009_01\151_0009_01.MP4
Format : MPEG-4
Commercial name : XDCAM EX 35
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 1.76 GiB
Duration : 7mn 5s
Overall bit rate mode : Variable
Overall bit rate : 35.6 Mbps
Encoded date : UTC 2009-07-19 04:22:10
Tagged date : UTC 2009-07-19 04:22:10
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Codec ID : 61
Duration : 7mn 5s
Bit rate mode : Variable
Bit rate : 34.0 Mbps
Maximum bit rate : 35.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 1.231
Stream size : 1.68 GiB (96%)
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Codec ID : twos
Duration : 7mn 5s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 77.9 MiB (4%)
Language : English
