Question: My spry menu bar is not displaying correctly in Dreamweaver
alrosales Sep 1, 2012 10:56 PMHello,
I am new to Dreamweaver CS5, so coding isn't my area of expertise. My problem with my spry menu bar is that it does not display the tabs on the menu bar correctly. When I try to apply new changes to the CSS of the horizontal menu bar, half of the tabs will change and the other half will not. Also, I am unable to drag and move the menu bar itself around, a function that I was once able to do before. At times, only one tab of the menu bar will display itself, without any of the other tabs as well.
I have a hunch that my problems stem from some coding errors in the SpryMenuBarHorizontal.css, and possibly in the SpryMenuBar.js. On the CSS Styles panel, my SpryMenuBarHorizontal.CSS list reads as follows:
I also have a hunch that something about this line-up is also incorrect, but I don't exactly know what the problem is.
Here is what my coding for my SpryMenuBarHorizontal.css looks like right now:
____________________________
@charset "UTF-8";
/* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, an auto width box with no margin or padding */
ul.MenuBarHorizontal
margin: 0;
padding: 0;
list-style-type: none;
font-size: 100%;
cursor: default;
width: auto;
text-align: center;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
ul.MenuBarActive
z-index: 1000;
/* Menu item containers, position children relative to this container and are a fixed width */
ul.MenuBarHorizontal li
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: left;
cursor: pointer;
width: 8em;
float: left;
left: 10;
top: 10;
height: 10;
/* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarHorizontal ul
margin: 0;
padding: 0;
font-size: 100%;
z-index: 1020;
cursor: default;
width: 8.2em;
position: absolute;
left: -1000em;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
left: auto;
/* Menu item containers are same fixed width as parent */
ul.MenuBarHorizontal ul li
width: 8.2em;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
ul.MenuBarHorizontal ul ul
position: absolute;
margin: -5% 0 0 95%;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
left: auto;
top: 0;
DESIGN INFORMATION: describes color scheme, borders, fonts
/* Submenu containers have borders on all sides */
border: 1px solid #CCC;
text-align: left;
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarHorizontal a
display: block;
cursor: pointer;
background-color: #000;
padding: 0.5em 0.75em;
color: #FFF;
text-decoration: none;
font-family: Futura;
float: none;
/* Menu items that have mouse over or focus have a blue background and white text */
ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
background-color: #C00;
color: #FFF;
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
color: #FFF;
SUBMENU INDICATION: styles if there is a submenu under a given menu item
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarDown.gif);
background-repeat: no-repeat;
background-position: 95% 50%;
text-align: center;
ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
background-image: url(SpryMenuBarRight.gif);
/* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarDownHover.gif);
ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
background-image: url(SpryMenuBarRightHover.gif);
BROWSER HACKS: the hacks below should not be changed unless you are an expert
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarHorizontal iframe
position: absolute;
z-index: 1010;
filter:alpha(opacity:0.1);
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
ul.MenuBarHorizontal li.MenuBarItemIE
display: block;
f\loat: left;
background: #FFF;
_________________________________
And here is what my SpryMenuBar.js coding looks like right now too:
SpryMenuBar.js
This file handles the JavaScript for Spry Menu Bar. You should have no need
to edit this file. Some highlights of the MenuBar object is that timers are
used to keep submenus from showing up until the user has hovered over the parent
menu item for some time, as well as a timer for when they leave a submenu to keep
showing that submenu until the timer fires.
(function() { // BeginSpryComponent
if (typeof Spry == "undefined") window.Spry = {}; if (!Spry.Widget) Spry.Widget = {};
Spry.BrowserSniff = function()
var b = navigator.appName.toString();
var up = navigator.platform.toString();
var ua = navigator.userAgent.toString();
this.mozilla = this.ie = this.opera = this.safari = false;
var re_opera = /Opera.([0-9\.]*)/i;
var re_msie = /MSIE.([0-9\.]*)/i;
var re_gecko = /gecko/i;
var re_safari = /(applewebkit|safari)\/([\d\.]*)/i;
var r = false;
if ( (r = ua.match(re_opera))) {
this.opera = true;
this.version = parseFloat(r[1]);
} else if ( (r = ua.match(re_msie))) {
this.ie = true;
} else if ( (r = ua.match(re_safari))) {
this.safari = true;
this.version = parseFloat(r[2]);
} else if (ua.match(re_gecko)) {
var re_gecko_version = /rv:\s*([0-9\.]+)/i;
r = ua.match(re_gecko_version);
this.mozilla = true;
this.windows = this.mac = this.linux = false;
this.Platform = ua.match(/windows/i) ? "windows" :
(ua.match(/linux/i) ? "linux" :
(ua.match(/mac/i) ? "mac" :
ua.match(/unix/i)? "unix" : "unknown"));
this[this.Platform] = true;
this.v = this.version;
if (this.safari && this.mac && this.mozilla) {
this.mozilla = false;
Spry.is = new Spry.BrowserSniff();
// Constructor for Menu Bar
// element should be an ID of an unordered list (<ul> tag)
// preloadImage1 and preloadImage2 are images for the rollover state of a menu
Spry.Widget.MenuBar = function(element, opts)
this.init(element, opts);
Spry.Widget.MenuBar.prototype.init = function(element, opts)
this.element = this.getElement(element);
// represents the current (sub)menu we are operating on
this.currMenu = null;
this.showDelay = 250;
this.hideDelay = 600;
if(typeof document.getElementById == 'undefined' || (navigator.vendor == 'Apple Computer, Inc.' && typeof window.XMLHttpRequest == 'undefined') || (Spry.is.ie && typeof document.uniqueID == 'undefined'))
// bail on older unsupported browsers
return;
// Fix IE6 CSS images flicker
if (Spry.is.ie && Spry.is.version < 7){
try {
document.execCommand("BackgroundImageCache", false, true);
} catch(err) {}
this.upKeyCode = Spry.Widget.MenuBar.KEY_UP;
this.downKeyCode = Spry.Widget.MenuBar.KEY_DOWN;
this.leftKeyCode = Spry.Widget.MenuBar.KEY_LEFT;
this.rightKeyCode = Spry.Widget.MenuBar.KEY_RIGHT;
this.escKeyCode = Spry.Widget.MenuBar.KEY_ESC;
this.hoverClass = 'MenuBarItemHover';
this.subHoverClass = 'MenuBarItemSubmenuHover';
this.subVisibleClass ='MenuBarSubmenuVisible';
this.hasSubClass = 'MenuBarItemSubmenu';
this.activeClass = 'MenuBarActive';
this.isieClass = 'MenuBarItemIE';
this.verticalClass = 'MenuBarVertical';
this.horizontalClass = 'MenuBarHorizontal';
this.enableKeyboardNavigation = true;
this.hasFocus = false;
// load hover images now
if(opts)
for(var k in opts)
if (typeof this[k] == 'undefined')
var rollover = new Image;
rollover.src = opts[k];
Spry.Widget.MenuBar.setOptions(this, opts);
// safari doesn't support tabindex
if (Spry.is.safari)
this.enableKeyboardNavigation = false;
if(this.element)
this.currMenu = this.element;
var items = this.element.getElementsByTagName('li');
for(var i=0; i<items.length; i++)
if (i > 0 && this.enableKeyboardNavigation)
items[i].getElementsByTagName('a')[0].tabIndex='-1';
this.initialize(items[i], element);
if(Spry.is.ie)
this.addClassName(items[i], this.isieClass);
items[i].style.position = "static";
if (this.enableKeyboardNavigation)
var self = this;
this.addEventListener(document, 'keydown', function(e){self.keyDown(e); }, false);
if(Spry.is.ie)
if(this.hasClassName(this.element, this.verticalClass))
this.element.style.position = "relative";
var linkitems = this.element.getElementsByTagName('a');
for(var i=0; i<linkitems.length; i++)
linkitems[i].style.position = "relative";
Spry.Widget.MenuBar.KEY_ESC = 27;
Spry.Widget.MenuBar.KEY_UP = 38;
Spry.Widget.MenuBar.KEY_DOWN = 40;
Spry.Widget.MenuBar.KEY_LEFT = 37;
Spry.Widget.MenuBar.KEY_RIGHT = 39;
Spry.Widget.MenuBar.prototype.getElement = function(ele)
if (ele && typeof ele == "string")
return document.getElementById(ele);
return ele;
Spry.Widget.MenuBar.prototype.hasClassName = function(ele, className)
if (!ele || !className || !ele.className || ele.className.search(new RegExp("\\b" + className + "\\b")) == -1)
return false;
return true;
Spry.Widget.MenuBar.prototype.addClassName = function(ele, className)
if (!ele || !className || this.hasClassName(ele, className))
return;
ele.className += (ele.className ? " " : "") + className;
Spry.Widget.MenuBar.prototype.removeClassName = function(ele, className)
if (!ele || !className || !this.hasClassName(ele, className))
return;
ele.className = ele.className.replace(new RegExp("\\s*\\b" + className + "\\b", "g"), "");
// addEventListener for Menu Bar
// attach an event to a tag without creating obtrusive HTML code
Spry.Widget.MenuBar.prototype.addEventListener = function(element, eventType, handler, capture)
try
if (element.addEventListener)
element.addEventListener(eventType, handler, capture);
else if (element.attachEvent)
element.attachEvent('on' + eventType, handler);
catch (e) {}
// createIframeLayer for Menu Bar
// creates an IFRAME underneath a menu so that it will show above form controls and ActiveX
Spry.Widget.MenuBar.prototype.createIframeLayer = function(menu)
var layer = document.createElement('iframe');
layer.tabIndex = '-1';
layer.src = 'javascript:""';
layer.frameBorder = '0';
layer.scrolling = 'no';
menu.parentNode.appendChild(layer);
layer.style.left = menu.offsetLeft + 'px';
layer.style.top = menu.offsetTop + 'px';
layer.style.width = menu.offsetWidth + 'px';
layer.style.height = menu.offsetHeight + 'px';
// removeIframeLayer for Menu Bar
// removes an IFRAME underneath a menu to reveal any form controls and ActiveX
Spry.Widget.MenuBar.prototype.removeIframeLayer = function(menu)
var layers = ((menu == this.element) ? menu : menu.parentNode).getElementsByTagName('iframe');
while(layers.length > 0)
layers[0].parentNode.removeChild(layers[0]);
// clearMenus for Menu Bar
// root is the top level unordered list (<ul> tag)
Spry.Widget.MenuBar.prototype.clearMenus = function(root)
var menus = root.getElementsByTagName('ul');
for(var i=0; i<menus.length; i++)
this.hideSubmenu(menus[i]);
this.removeClassName(this.element, this.activeClass);
// bubbledTextEvent for Menu Bar
// identify bubbled up text events in Safari so we can ignore them
Spry.Widget.MenuBar.prototype.bubbledTextEvent = function()
return Spry.is.safari && (event.target == event.relatedTarget.parentNode || (event.eventPhase == 3 && event.target.parentNode == event.relatedTarget));
// showSubmenu for Menu Bar
// set the proper CSS class on this menu to show it
Spry.Widget.MenuBar.prototype.showSubmenu = function(menu)
if(this.currMenu)
this.clearMenus(this.currMenu);
if(menu)
this.addClassName(menu, this.subVisibleClass);
if(typeof document.all != 'undefined' && !Spry.is.opera && navigator.vendor != 'KDE')
if(!this.hasClassName(this.element, this.horizontalClass) || menu.parentNode.parentNode != this.element)
menu.style.top = menu.parentNode.offsetTop + 'px';
if(Spry.is.ie && Spry.is.version < 7)
this.createIframeLayer(menu);
this.addClassName(this.element, this.activeClass);
// hideSubmenu for Menu Bar
// remove the proper CSS class on this menu to hide it
Spry.Widget.MenuBar.prototype.hideSubmenu = function(menu)
if(menu)
this.removeClassName(menu, this.subVisibleClass);
menu.style.top = '';
menu.style.left = '';
this.removeIframeLayer(menu);
// initialize for Menu Bar
// create event listeners for the Menu Bar widget so we can properly
// show and hide submenus
Spry.Widget.MenuBar.prototype.initialize = function(listitem, element)
var opentime, closetime;
var link = listitem.getElementsByTagName('a')[0];
var submenus = listitem.getElementsByTagName('ul');
var menu = (submenus.length > 0 ? submenus[0] : null);
if(menu)
this.addClassName(link, this.hasSubClass);
if(!Spry.is.ie)
// define a simple function that comes standard in IE to determine
// if a node is within another node
listitem.contains = function(testNode)
// this refers to the list item
if(testNode == null)
return false;
if(testNode == this)
return true;
else
return this.contains(testNode.parentNode);
// need to save this for scope further down
var self = this;
this.addEventListener(listitem, 'mouseover', function(e){self.mouseOver(listitem, e);}, false);
this.addEventListener(listitem, 'mouseout', function(e){if (self.enableKeyboardNavigation) self.clearSelection(); self.mouseOut(listitem, e);}, false);
this.addEventListener(link, 'blur', function(e){self.onBlur(listitem);}, false);
this.addEventListener(link, 'focus', function(e){self.keyFocus(listitem, e);}, false);
Spry.Widget.MenuBar.prototype.keyFocus = function (listitem, e)
this.lastOpen = listitem.getElementsByTagName('a')[0];
this.addClassName(this.lastOpen, listitem.getElementsByTagName('ul').length > 0 ? this.subHoverClass : this.hoverClass);
this.hasFocus = true;
Spry.Widget.MenuBar.prototype.onBlur = function (listitem)
this.clearSelection(listitem);
Spry.Widget.MenuBar.prototype.clearSelection = function(el){
//search any intersection with the current open element
if (!this.lastOpen)
return;
if (el)
el = el.getElementsByTagName('a')[0];
// check children
var item = this.lastOpen;
while (item != this.element)
var tmp = el;
while (tmp != this.element)
if (tmp == item)
return;
try{
tmp = tmp.parentNode;
}catch(err){break;}
item = item.parentNode;
this.hideSubmenu(item.parentNode);
var link = item.getElementsByTagName('a')[0];
this.removeClassName(link, this.hoverClass);
this.removeClassName(link, this.subHoverClass);
this.lastOpen = false;
Spry.Widget.MenuBar.prototype.keyDown = function (e)
if (!this.hasFocus)
return;
if (!this.lastOpen)
return;
var e = e|| event;
var listitem = this.lastOpen.parentNode;
var link = this.lastOpen;
var hasSubMenu = (menu) ? true : false;
var opts = [listitem, menu, null, this.getSibling(listitem, 'previousSibling'), this.getSibling(listitem, 'nextSibling')];
if (!opts[3])
opts[2] = (listitem.parentNode.parentNode.nodeName.toLowerCase() == 'li')?listitem.parentNode.parentNode:null;
var found = 0;
switch (e.keyCode){
case this.upKeyCode:
found = this.getElementForKey(opts, 'y', 1);
break;
case this.downKeyCode:
found = this.getElementForKey(opts, 'y', -1);
break;
case this.leftKeyCode:
found = this.getElementForKey(opts, 'x', 1);
break;
case this.rightKeyCode:
found = this.getElementForKey(opts, 'x', -1);
break;
case this.escKeyCode:
case 9:
this.clearSelection();
default: return;
switch (found)
case 0: return;
case 1:
//subopts
this.mouseOver(listitem, e);
break;
case 2:
//parent
this.mouseOut(opts[2], e);
break;
case 3:
case 4:
// left - right
this.removeClassName(link, hasSubMenu ? this.subHoverClass : this.hoverClass);
break;
var link = opts[found].getElementsByTagName('a')[0];
if (opts[found].nodeName.toLowerCase() == 'ul')
opts[found] = opts[found].getElementsByTagName('li')[0];
this.addClassName(link, opts[found].getElementsByTagName('ul').length > 0 ? this.subHoverClass : this.hoverClass);
this.lastOpen = link;
opts[found].getElementsByTagName('a')[0].focus();
//stop further event handling by the browser
return Spry.Widget.MenuBar.stopPropagation(e);
Spry.Widget.MenuBar.prototype.mouseOver = function (listitem, e)
if(this.bubbledTextEvent())
// ignore bubbled text events
return;
if (listitem.closetime)
clearTimeout(listitem.closetime);
if(this.currMenu == listitem)
// move the focus too
if (this.hasFocus)
link.focus();
// show menu highlighting
this.addClassName(link, hasSubMenu ? this.subHoverClass : this.hoverClass);
if(menu && !this.hasClassName(menu, this.subHoverClass))
var self = this;
listitem.opentime = window.setTimeout(function(){self.showSubmenu(menu);}, this.showDelay);
Spry.Widget.MenuBar.prototype.mouseOut = function (listitem, e)
return;
var related = (typeof e.relatedTarget != 'undefined' ? e.relatedTarget : e.toElement);
if(!listitem.contains(related))
if (listitem.opentime)
clearTimeout(listitem.opentime);
this.currMenu = listitem;
// remove menu highlighting
if(menu)
var self = this;
listitem.closetime = window.setTimeout(function(){self.hideSubmenu(menu);}, this.hideDelay);
if (this.hasFocus)
link.blur();
Spry.Widget.MenuBar.prototype.getSibling = function(element, sibling)
var child = element[sibling];
while (child && child.nodeName.toLowerCase() !='li')
child = child[sibling];
return child;
Spry.Widget.MenuBar.prototype.getElementForKey = function(els, prop, dir)
var found = 0;
var rect = Spry.Widget.MenuBar.getPosition;
var ref = rect(els[found]);
var hideSubmenu = false;
//make the subelement visible to compute the position
if (els[1] && !this.hasClassName(els[1], this.MenuBarSubmenuVisible))
els[1].style.visibility = 'hidden';
this.showSubmenu(els[1]);
hideSubmenu = true;
var isVert = this.hasClassName(this.element, this.verticalClass);
var hasParent = els[0].parentNode.parentNode.nodeName.toLowerCase() == 'li' ? true : false;
for (var i = 1; i < els.length; i++){
//when navigating on the y axis in vertical menus, ignore children and parents
if(prop=='y' && isVert && (i==1 || i==2))
continue;
//when navigationg on the x axis in the FIRST LEVEL of horizontal menus, ignore children and parents
if(prop=='x' && !isVert && !hasParent && (i==1 || i==2))
continue;
if (els[i])
var tmp = rect(els[i]);
if ( (dir * tmp[prop]) < (dir * ref[prop]))
ref = tmp;
found = i;
// hide back the submenu
if (els[1] && hideSubmenu){
this.hideSubmenu(els[1]);
els[1].style.visibility = '';
return found;
Spry.Widget.MenuBar.camelize = function(str)
if (str.indexOf('-') == -1){
return str;
var oStringList = str.split('-');
var isFirstEntry = true;
var camelizedString = '';
for(var i=0; i < oStringList.length; i++)
if(oStringList[i].length>0)
if(isFirstEntry)
camelizedString = oStringList[i];
isFirstEntry = false;
else
var s = oStringList[i];
camelizedString += s.charAt(0).toUpperCase() + s.substring(1);
return camelizedString;
Spry.Widget.MenuBar.getStyleProp = function(element, prop)
var value;
try
if (element.style)
value = element.style[Spry.Widget.MenuBar.camelize(prop)];
if (!value)
if (document.defaultView && document.defaultView.getComputedStyle)
var css = document.defaultView.getComputedStyle(element, null);
value = css ? css.getPropertyValue(prop) : null;
else if (element.currentStyle)
value = element.currentStyle[Spry.Widget.MenuBar.camelize(prop)];
catch (e) {}
return value == 'auto' ? null : value;
Spry.Widget.MenuBar.getIntProp = function(element, prop)
var a = parseInt(Spry.Widget.MenuBar.getStyleProp(element, prop),10);
if (isNaN(a))
return 0;
return a;
Spry.Widget.MenuBar.getPosition = function(el, doc)
doc = doc || document;
if (typeof(el) == 'string') {
el = doc.getElementById(el);
if (!el) {
return false;
if (el.parentNode === null || Spry.Widget.MenuBar.getStyleProp(el, 'display') == 'none') {
//element must be visible to have a box
return false;
var ret = {x:0, y:0};
var parent = null;
var box;
if (el.getBoundingClientRect) { // IE
box = el.getBoundingClientRect();
var scrollTop = doc.documentElement.scrollTop || doc.body.scrollTop;
var scrollLeft = doc.documentElement.scrollLeft || doc.body.scrollLeft;
ret.x = box.left + scrollLeft;
ret.y = box.top + scrollTop;
} else if (doc.getBoxObjectFor) { // gecko
box = doc.getBoxObjectFor(el);
ret.x = box.x;
ret.y = box.y;
} else { // safari/opera
ret.x = el.offsetLeft;
ret.y = el.offsetTop;
parent = el.offsetParent;
if (parent != el) {
while (parent) {
ret.x += parent.offsetLeft;
ret.y += parent.offsetTop;
parent = parent.offsetParent;
// opera & (safari absolute) incorrectly account for body offsetTop
if (Spry.is.opera || Spry.is.safari && Spry.Widget.MenuBar.getStyleProp(el, 'position') == 'absolute')
ret.y -= doc.body.offsetTop;
if (el.parentNode)
parent = el.parentNode;
else
parent = null;
if (parent.nodeName){
var cas = parent.nodeName.toUpperCase();
while (parent && cas != 'BODY' && cas != 'HTML') {
ret.x -= parent.scrollLeft;
ret.y -= parent.scrollTop;
if (parent.parentNode)
parent = parent.parentNode;
else
parent = null;
return ret;
Spry.Widget.MenuBar.stopPropagation = function(ev)
if (ev.stopPropagation)
ev.stopPropagation();
else
ev.cancelBubble = true;
if (ev.preventDefault)
ev.preventDefault();
else
ev.returnValue = false;
Spry.Widget.MenuBar.setOptions = function(obj, optionsObj, ignoreUndefinedProps)
if (!optionsObj)
return;
for (var optionName in optionsObj)
if (ignoreUndefinedProps && optionsObj[optionName] == undefined)
continue;
obj[optionName] = optionsObj[optionName];
})(); // EndSpryComponent
__________________________________________________________________________
If anyone could possibly steer me on the right direction with this, I'd be very grateful! I've been struggling with this for about a month now and I feel like I may have only made the situation worse.
I'm not sure if I have to keep making a new spry assets folder in my website or not or if I have to drag and drop the spry assets into the root folder. I have restarted my website over at least a dozen times by now. I have tried changing folders, dragging and dropping various spry assets folders everywhere and I have also uninstalled and reinstalled my copy of Dreamweaver CS5 in the hopes of getting my spry horizontal menu bar to act normal. I am completely new at Dreamweaver and I really, really need some help with this.
