This question was posted in response to the following article: http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/ui/Mouse.html
There is no information about errors thrown, e.g. cursor will throw an error when not supported cursor id is given.
ArgumentError: Error #2008: Parameter cursor must be one of the accepted values.
Hi All,
I am facing an issue with mouse hiding. In my as3 app i am trying to load an as2 swf using Local connection.
after 3-5 times loaded/unloaded its getting hidden the mouse cursor.i tried to call the Mouse.show() methode. but no results found.
I am trying to load a print2flash as2 doc swf.Help me if anybody have a solution for this.
thanks in advance.
Arunraj.
you can't load anything using localconnection. you use localconnection to communicate between two swfs open at the same time on the same host computer.
Mouse.hide() doesn't seem to work on Mac in the Debugger or in a Projector.
It will not hide the cursor until the mouse moves out of and back into the window (or starts outside the window). That means that in the case of a large window, it will not be reliable, and in fullscreen, it will not work at all.
