Show 6 replies
1. Re: Cannot set up connection in Contribute using SFTP
Anit_Kumar Sep 14, 2012 4:20 PM (in response to anna0550)Please check the private message sent to you.
2. Re: Cannot set up connection in Contribute using SFTP
uhhilo Sep 18, 2012 4:00 PM (in response to anna0550)I've been getting the same error. Were you able to resolve the issue, anna0550?
3. Re: Cannot set up connection in Contribute using SFTP
Anit_Kumar Sep 18, 2012 4:28 PM (in response to uhhilo)Please check the private message sent to you
4. Re: Cannot set up connection in Contribute using SFTP
anna0550 Sep 20, 2012 1:43 PM (in response to uhhilo)Yes, edit /etc/ssh/sshd_config and make sure you have this setting:
PasswordAuthentication yes
Also make sure that the user has access to the directory he/she is connecting to.
5. Re: Cannot set up connection in Contribute using SFTP
anna0550 Sep 20, 2012 1:44 PM (in response to Anit_Kumar)Thank you. I have fixed the issue.
6. Re: Cannot set up connection in Contribute using SFTP
uhhilo Sep 20, 2012 2:47 PM (in response to anna0550)On my OS X server, I changed both /etc/ssh_config and /etc/sshd_config to have the
This seems to have done the trick; I'm able to create a connection to the server within Contribute.
Thanks anna0550 and Anit_Kumar for your assistance!
