1. Re: Hardware Update
JEShort01 Sep 8, 2012 7:19 AM (in response to Fabio Pis)Fabio,
Awesome new build! A 138 net time (1st place time for CS5.5 submissions) for CS5.5 on PPBM5 shows that not only is your hardware scorching, but that you have tuned / tweaked your system very well too. Great job!
Comments / questions:
- regarding submitting PPBM5 result multiple times, yes that is common; just give your new submission a new name (fabio-pc2, fabio-pc x79, etc.).
- regarding retiring a pretty darn fast 6-core PC, I have to ask why? (for fun, need to edit RED 4k, etc.)
- please explain why you think turning on pci-e 3.0 helps when you seem to be running all drives to your motherboard controllers? Does it help the video card performance in ways that help Premiere?
- do you have 5 total drives now? And where do you put what files when you ran PPBM5 (i.e. projects/media/scratch on 2x600 R0, media cache/exports on 2nd 2x600GB, Win7 swap on, etc.)?
Jim
2. Re: Hardware Update
Bill Gehrke Sep 8, 2012 8:39 AM (in response to JEShort01)That really is a great system and as Jim said please do submit those results.
And yes, it would be very interesting to know the results with just your GTX 680 on PCIe 2.0 versus PCIe 3.0 at any given clock speed. Also do not forget that any result is subject to at least +/-1 second because we only have a 1 second resolution clock. Also with disk drives because they are asynchronous, on repeated testing runs with Arrays you will find +/- 2 seconds typical variance and as the drives fill up the Disk I/O performance will decrease.
3. Re: Hardware Update
Fabio Pis Sep 8, 2012 10:00 AM (in response to Bill Gehrke)Hello Jim and Bill.
My config:
Corsair 950 Tx
case Cooler master 690 II advanced
i7 3960X @ 4.4 Ghz (automatic asrock oc tweaker)
32 gb Kingston cl9 (9 9 9 27) 1600 DDR3
Mb asrock x79 extreme9
Phanteks PH-TC14PE cpu cooler (2 140 fans)
Soundcard included with Mb in pci -e slot
Corsair Force GT 240 gb
2 Hd velociraptor 600 Gb each configured in in raid 0
2 hd Wd 2Tb (crap ears version)
Lg BH10ls30 bluray recorder
Gainward GTX 680 2gb (for testing no overclock on this)
Windows 7 ultimate 64 bit sp1 all updated
Production Creative Suite CS 5.5 updated
All mb drivers installed and Nvidia Geforce 306.02 beta installed
A basic tweaking with msconfig (disabled acrobat and other unusefull services)
No antivirus
No other software installed.
My system in this config had passed 1 hour of limpak in OCCT and standard prime 95
Boot disk (corsair force GT 240 gb)is installed on sata 3 intel connector
Raid 0 disk is installed on marvel 9220 connector
With aida 64 disk benchmark I had best result with ssd drive than raid0 drive setup but worst in PPBM5.
Os and creative suite disk, and swap disk:
Corsair force gt
Project disk:
Raid0
With these settings I achieved previous posted results.
The only differents I noticed in pci-e 3.0 vs 2.0 are related in the first values
48-55 vs 49-51
With ssd drivers for project disk I have the total benchmark 6 points greater than raid 0
For Jim,
Thank you
In a chat session with a guy at adobe international I have asked a link for old premiere 5.04 topush my system limits( I am a production premium legit user, but he says that it is not possible to do with my serials..)
i am used to name may pc with my name fabio, windows add -PC, But as you say I can modify name in benchmark submitting
I am a pc entusiast and a 3d stereoscopic expert for a part of my job. As I can, I update my pc. I did some test with a Xeon 2687w but it is not a good choice for premiere and also with 3dsmax because the lack of overclocking part, with the same motherboard I achieved only minimal (from 100 to 102 for fsb) overclock. So I decided for 3960x
I would like to test in a future Intel sata 3 connector for my raid 0, but I have to restore my clean image. Now, I have installed avg free antivirus and some other drivers for stereoscopic and phisique, by the way, stereoscopic service in my previous test with 980X processor had a bad influence in PPBM5 benchmark results
For Bill,
I have submitted yesterday my tests two time because in first submit I did an error with files.
Message was edited by: Fabio Pis
4. Re: Hardware Update
Fabio Pis Sep 9, 2012 4:53 AM (in response to Fabio Pis)All my tests with simbols to understand better
symbols:
gt= Corsair Force GT 240 Gb
Raid 0= 2 Velociraptor 600 Gb each
clean= OS clean installation with CS 5.5 and all system and CS 5.5 updated
pcie2 .0= gfx in pcie2.0
pcie3.0= gfx in pcie3.0
BV= black viper optimization
CR1= ddr3 command rate set1
no MPE= no mercury engine
GFX oc= gtx 680 overclocked with custom dynamic clock table
pcie 2.0:
gt clean pcie2.0 = "51","55","36","4"
gt clean pcie2.0 no MPE = "51","55","36","55"
Raid 0 clean pcie2.0 = "49","55","35","5"
Raid 0 clean pcie2.0 no MPE = "49","55","35","54"
pcie3 enabled with nvidia enabler:
gt clean pcie3.0= "49","52","35","4"
gt clean pcie3.0 no MPE= "49","52","35","55"
Raid 0 clean pcie3.0= "49","52","36","4"
Raid 0 clean pcie3.0 no MPE= "49","52","36","54"
gt clean pcie3.0 BV= "50","53","36","5"
gt clean pcie3.0 BV no MPE= "50","53","36","56"
Raid 0 cleanpcie3.0 BV= "49","53","35","4"
Raid 0 cleanpcie3.0 BV no MPE= "49","53","35","56"
gt clean pcie3.0 BV CR1= "51","53","35","5"
gt clean pcie3.0 BV CR1 no MPE= "51","53","35","55"
Raid 0 cleanpcie3.0 BV CR1= "48","51","34","4"
Raid 0 cleanpcie3.0 BV no MPE CR1= "48","51","34","55"
gt cleanpcie3.0 BV CR1 GFX oc= "50","48","34","4"
gt cleanpcie3.0 BV CR1 GFX oc no MPE= "50","48","34","54"
Raid 0 cleanpcie3.0 BV CR1 GFX oc= "49","48","35","4"
Raid 0 cleanpcie3.0 BV CR1 GFX oc no MPE= "49","48","35","55"
So my best score is 136
5. Re: Hardware Update
Fabio Pis Sep 12, 2012 8:00 AM (in response to Fabio Pis)This is the last test I'll submit.. I am happy butI think there are some problems with adobe premiere newest version mpeg dvd encoding.
I have the chance to try on my system a legit 5.03 version (5.0 then updated at 5.03)
My result:
"57","22","39","60" with no mpe
"57","22","39","4" with gtx 680 added in cuda_supported_cards.txt file
122??
Is it possible?
6. Re: Hardware Update
JEShort01 Sep 12, 2012 10:01 AM (in response to Fabio Pis)Congrats again Fabio, a great score indeed (rank #1 on PPBM5 and beating out the massive SR-2 system from ADK)! I certainly believe it; the X79 CPU really seems to crank on Blu-ray encoding compared with the earlier generation CPUs.
Regarding CS5 appearing faster than CS5.5/6 on the PPBM5 benchmark, it is my understanding that this has something to do with changes Adobe made to caching in the different versions. I suspect that this is a PPBM5 artifact however, and would not really benefit CS5 doing real work where video clips are not repeated on a given timeline. Perhaps Harm or Bill have more to add.
Jim
7. Re: Hardware Update
Fabio Pis Sep 12, 2012 10:30 AM (in response to JEShort01)Thank you Jim,
Maybe I could achieve better results If I had used Black Viper windows optimization services config but I didn't in 5.03.
In my system there is no different at all if I use raid 0 (two velociraptor 600 gb each one) or a single ssd 240gb for project disk.
By the way, installation was clean and I forgot to set pci-e 3.0 nvidia enabler ( I have to add to my clean os and drivers image), default gfx clocks
Yes blu ray encoding is very fast, but in disk's test I have 10 seconds delay after encoding is finished, this result can change about 10 seconds in different start(from 57 to 67 s in cs 5.0 suite)
I have tried a xeon 2687w with a similar setup of my test configuration and it is slower.
I would like to hear some comments from Harm and Bill also.
For me the secret is to keep clean OS with less services installed .
In my dayly use ( with 3dvision driver,3dsmax satellite, itunes and other programs installed) my result are greater about 7 points also disabling related services....
ciao
Fabio
