4 Replies Latest reply: Sep 10, 2012 3:29 AM by wayne greensill RSS
    Code:25 Not enough disc space Help!!!!!
    wayne greensill Community Member
      Hi there,
      Can someone help me before I smash my PC up!
      Adobe you need to sort issues out with your products before you put your sofware on the market!
      For the last four days I have been trying to create a Blue Ray disc, which has been sent from Premiere CS5.2 to Encore via dynamic link.
      The project is 2hrs 36mins in length.Transcode settings are set at Transcode Default Settings. Dimenions of project are 1440x1080, Frame Rate 25.
      I have 398Gb free space on my drive and 2Gb free space on disc.
      Start to bulid the project in Encore, this takes another 10hrs to transcode, then it attempts to write onto disc then I get "CODE 25" Error not enough disc space?????? What the **** is this ?
      I have gone through the forums on here which have mentioned deleting the session files, done all this and still no luck.
      I would appreciate it if anyone has managed to solve this problem and pass their findings on to me.
      Thank you
      Wayne
        • 1. Re: Code:25 Not enough disc space Help!!!!!
          Stan Jones CommunityMVP
          What is the exact error message?
          Is this a dual layer BD?
          Do you run Encore "as administrator"? (Not just a user with administrative privileges.)
          When you right click on the dynamic linked sequence (not the timeline) in the project panel, and select "transcode settings," what does it say?
          Have you set chapters in the sequence in Premiere or in Encore?
          • 3. Re: Code:25 Not enough disc space Help!!!!!
            Ramesh_Encore Adobe Employee
            Which version of Encore are you using?
            Do you have any motion menu in your project? If yes, what is its duration and size?
            Also any slideshows?
            What is the disc info that is shown in the Build tab?
            -Ramesh.
            • 4. Re: Code:25 Not enough disc space Help!!!!!
              Hi Guys,
              I have finally managed to burn the project onto Blu-Ray but I have a slight issue with the Audio being slightly distorted. What would be the best settings for the audio?
              This is what I did to get it onto disc:
              Exported my project from Premiere CS5.2 through AME then imported into Encore 5.1. I did change the Administrator settings as advised and it looks like this did the trick.
              My Encore Project Settings were set at: Codec H.264, Dimensions 1440X1080, Frame Rate 25, Upper Field First.
              Export Settings from Premiere were set at:
              Video
              T.V Standard: Automatic (based on source) (PAL)
              Frame Dimensions: 1440x1080
              Frame Rate: Automatic
              Field Order: Automatic
              Pixel Aspect Ratio: Automatic
              Profile: Main
              Level: 4.1
              Bitrate Settings
              Bitrate Encoding: VBR, 1 Pass
              Bitrate Lever: High
              Target Bitrate: 18.75
              Maximum Bitrate 22.5
              Audio
              Codec: Dolby Digital
              Audio Layer: Dolby Digital Stereo
              Frequency: 48 KHz
              Bitrate Settings
              Bitrate (kbps) 192
              Do I need to up the audio bitrate for better sound as I'm getting distortion. If so what is the best setting for this?
              Thank you all for your help
              Wayne
